And now with jadburner;s help (Thank you so much), i have successfully flashed it to version 1.02 and it is LibreEnabled now. but it cannot rip or playback 4K UHD Discs, the maximum it can rip and play is Blurays.
Drive Information OS device name: \Device\CdRom4 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-TD05 Revision: 1.02 Serial number: LIDL068881WL Firmware date: 2014-06-19 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8211 Firmware name: PIONEER BDR-TD05 Firmware type: Original (unpatched) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Disc Information Label: DUNKIRK Timestamp: 2017-11-07 14:20:04 Protection: AACS v50 Data capacity: 30.1 Gb Disc type: BD-ROM Number of layers: 2 Channel bit length: 74,5 nm (25.0 GB max. per layer) |
Hi Jadburner, attached below are the Pioneer BDR-UD02 and Pioneer BDR-TD04 readouts from MakeMKV.
Drive Information OS device name: \Device\CdRom5 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD02 Revision: 1.00 Serial number: LJDL050094WL Firmware date: 2012-08-23 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8410 Firmware name: PIONEER BDR-US02 Firmware type: Original (unpatched) Firmware version: 1.00/ID19 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Disc Information Label: DUNKIRK Timestamp: 2017-11-07 14:20:04 Protection: AACS v50 Data capacity: 30.1 Gb Disc type: BD-ROM Number of layers: 2 Channel bit length: 74,5 nm (25.0 GB max. per layer) Drive Information OS device name: \Device\CdRom5 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-TD04D Revision: 1.00 Serial number: LFDL062967WL Firmware date: 2012-01-27 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Possible, but very unlikely to happen Drive platform: Pioneer RS1040 Firmware version: ID84 Disc Information Label: DUNKIRK Timestamp: 2017-11-07 14:20:04 Protection: AACS v50 Data capacity: 30.1 Gb Disc type: BD-ROM Number of layers: 2 Channel bit length: 74,5 nm (25.0 GB max. per layer) |
For the Pioneer BDR-TD04, i do know its totally impossible to rip or play 4K UHD Disc's, just hope that it can be flashed for "Ripping and Playback of Regular Blu-Rays", just as the Pioneer BDR-TD05 was able to be successfully flashed for "Ripping and Playback of Regular Blu-Ray's"
No. For the TD04 is not possible to enable Libredrive but the UD02 has more potential.
Read here: https://forum.makemkv.com/forum/view...p?f=19&t=27378 |
yes buddy coopervid, because the td05 was able to be flashed for ripping and playback of "Blu-rays" so i was hoping that the td04 can also be flashed for "Blu-rays too"
its only a wish. i do understand its not able to read 4K UHD Disc's but just wanting it to rip and play blu-rays only. |
in this thread in MakeMKV forums, there was a guy that had a firmware version 1.01 of the TD04... and eventually he got it working to read blu-rays.
in my td04 the firmware version is 1.00. https://forum.makemkv.com/forum/view...yle=10&t=25615 |
this is the copy and paste of that guys TD04 drive with a version 1.01 firmware.
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-TD04 Revision: 1.01 Serial number: LGDL134787WL Firmware date: 2012-11-05 Bus encryption flags: 13 Highest AACS version: 52 LibreDrive Information Status: Might be supported in future, keep fingers crossed Drive platform: Pioneer RS1040 Firmware version: ID01 No disc inserted |
i replied to you (Coopervid) via the conversation pm tab, but i guess it wasnt sent out to you. so i am using the regular pm.
No. It's also not supported. RS1xxx firmware doesn't work with libredrive.
Wszystkie czasy w strefie CET. Aktualna godzina: 08:58. |
