Stary 25.01.2025, 10:53   #1
cashkey1
Data rejestracji: 25.01.2025
cashkey1 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Pioneer BDR-TD05 and Pioneer BDR-UD02
Hi there, i just joined this forum.
i have these 3 Pioneer internal laptop drives.
1) Pioneer BDR-TD05
2) Pioneer BDR-TD04
3) Pioneer BDR-UD02
Was hoping to Flash it to make it LibreEnabled.
Any chance if someone can send the firmwares to me?
Thanks in Advance.
cashkey1 jest online   Odpowiedz cytując ten post
Stary 25.01.2025, 17:39   #2
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez cashkey1 Podgląd Wiadomości
1) Pioneer BDR-TD05
2) Pioneer BDR-TD04
3) Pioneer BDR-UD02
Thanks in Advance.
Greetings, cashkey1. Have you already checked to see if the drives work with MakeMKV? We don't really have any good crossflash options for those older drives.
Stary 25.01.2025, 18:16   #3
Coopervid
Avatar użytkownika Coopervid
Data rejestracji: 04.09.2024
Coopervid w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi jadburner! The UD02 is supposed to be flashable to UD04. The others can't be flashed.
Coopervid jest offline   Odpowiedz cytując ten post
Stary 25.01.2025, 18:30   #4
jadburner
Napisany przez Coopervid Podgląd Wiadomości
Thanks. It might be possible to crossflash the UD02 to an XD04, according to the developer. The UD02->UD04 crossflash is not listed as supported.
Stary 25.01.2025, 18:45   #5
cashkey1
oh, that means there is a possibility to flash a XD04 too? thats another preety old but gold drive from pioneer too.
Stary 25.01.2025, 18:34   #6
Coopervid
Yes it is. In the newest user manual and also tested by Billycar. UD02 <-> UD03<-> UD04.
Stary 25.01.2025, 21:53   #7
jadburner
Thanks for the update.
Stary 25.01.2025, 18:37   #8
cashkey1
thks jadburner and coopervid, its the weekend now, and i have already made plans for an outing, so i will get it done after my short weekend getaway.
thanks.
looking forward to having these drives playing 4k uhd's.
old but gold drives.. Pioneer, the best ever.
Stary 25.01.2025, 19:04   #9
Coopervid
No. I don't think so but I just exchanged some info with jadburner.
Stary 25.01.2025, 22:13   #10
Coopervid
De nada. I think I actually received that from you some time ago. And I also guess you take care of cashkey1 as you are the main contact for those issues in the forum here.
Stary 26.01.2025, 06:15   #11
jadburner
Yes, I will provide assistance to cashkey1.
Stary 27.01.2025, 07:52   #12
cashkey1
Thanks jadburner, i have sent you a PM already.
Stary 28.01.2025, 03:56   #13
cashkey1
Attached below is the screenshot of the Opti Drive Control for the Pioneer BDR-TD05D
File Type: png Drive_info_28-January-2025.png (79.6 KB, 41 oglądane)
Stary 28.01.2025, 06:40   #14
jadburner
Please check your PM.
Stary 28.01.2025, 08:11   #15
cashkey1
this was my MakeMKV readings before flashing my BDR-TD05, it had firmware version 1.00 and was not LibreDrive enabled yet.
Drive Information
OS device name: \Device\CdRom4
Current profile: BD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-TD05D
Revision: 1.00
Serial number: LIDL068881WL
Firmware date: 2012-07-13
Bus encryption flags: 1B
Highest AACS version: 68
LibreDrive Information
Status: Possible, not yet enabled
Drive platform: Pioneer RS8211
Firmware version: ID84
Disc Information
Label: DUNKIRK
Timestamp: 2017-11-07 14:20:04
Protection: AACS v50
Data capacity: 30.1 Gb
Disc type: BD-ROM
Number of layers: 2
Channel bit length: 74,5 nm (25.0 GB max. per layer)
bdr-td05, bdr-ud02, pioneer
Wszystkie czasy w strefie CET. Aktualna godzina: 08:35.
