-   -   McAfee Enterprise 8 - problem (https://forum.cdrinfo.pl/f5/mcafee-enterprise-8-problem-51159/)
Burak_PL 16.04.2005 12:07
dobra to juz niepotrzebne !!! poradziłem sobie tak jak mówiłeś z tym totalem po jakimś 7 razie pomogło!!! a co do antywirusa nie wiem czy go usunąć?? który lepszy?? podajcie linki skąd można zassać + spolszczenie?? ja zawsze pracowałem na mksvirze ale teraz mam McAffe co doradzicie??
wielki dzięki!! @ndy uratowałeś mi skórę !!!!!!!!!! wirtualne ale moze kiedys takie prawdziwe!!:piwo:
andy 16.04.2005 11:47
A kiedy wyskakuje Ci ten blad. Podczas instalacji pebuildera czy tworzenia plytki??
Instrukcja jak stworzyc:
This section will help you create a basic BartPE CD quickly.
  1. Download the latest self-installing package of PE Builder and install it. See the Download section on this page.
  2. Start PE Builder (pebuilder.exe). At the main PE Builder dialog, enter the source path to your original Windows XP/2003 Installation/Setup CD. You can use the "..." button to navigate. If your Windows XP is not integrated with service pack 1 or 2, you must slipstream your files first.
    Please read Slipstreaming files from the help files to do this.
  3. At the main PE Builder dialog, enable the "Create ISO image" and "Burn to CD" option. Select your CD writer device from the Device listbox.
    If you use a CDRW media, also check the "Erase CDRW" option.
  4. At the main PE Builder dialog, hit the "build" button (or press F7). PE Builder will now ask you to create a directory, answer with "yes".
  5. The license for your Windows XP/2003 product is shown. Read it and agree to it to continue.
  6. PE Builder will now start building BartPE. This will take a few minutes.
    You will see a lot of files getting copied and/or decompressed, the ISO image build and the data recorded to your CD writer.
    While burning to your CD writer you will not see any screen changes, just wait for it to finish...
  7. When burned OK, boot from the CD!
Burak_PL 16.04.2005 11:35
no ma tego prebuilder i setupbldr.bin not forund ???
andy 16.04.2005 11:21
@Burak_123 ten program zrobi Ci Windowsa XP CD czyli takiego ktory chodzi z plytki nie trzeba go instalowac. Spod niego usuniesz bez problemu ten plik. Jezeli nie poskutkowala metoda z explorerem.
Co do instalki to wejdz na stronk McAfee i sciagnij;)
Burak_PL 16.04.2005 11:17
zabiłem explorera i usunałem plik Totalem i reseta o on dalej jest!!
Burak_PL 16.04.2005 11:10
problem 1 nie mam instalki
problem 2 po co mi płyta xp???
andy 16.04.2005 11:01
[Problem 1]
Sprobuj odinstalowac tego antyvira i zainstalowac ponownie.
[Problem 2]
Sposob 1. Zabij proces explorer.exe i sprobuj usunac ten plik. Tylko przed zabiciem wlacz Total Commandera, lub inny menadzer plikow.
Sposob 2. Sciagnij pebuildera z tej stronki: http://www.nu2.nu/pebuilder/ . Zrobi Ci XPka startujacego z plytki CD/DVD. Odpalasz kompa z tej plytki i usuwasz plik powergg.
Damianos L 16.04.2005 10:50
ten plik moze sprobuj wywalic w trybie awaryjnym
Burak_PL 16.04.2005 10:32
Witam! Mam mały problem z moim antywirem McAfee Enterprise 8 przy skanowaniu dysku wyskakuje mi cos takiego: http://img29.echo.cx/img29/9305/a9bp.jpg
co zorobić?? cały czas działa a tera costakeigo no i skad ściagnąć spolszczenie do niego??
Problem nr. 2
ściągałem sobie powergg i później przerwałe i usunąłem tą ściągniętą część
a ona znalazła się na pulpicie próbujęją usunąć i coś takiego:
http://img211.echo.cx/img211/2616/aa9yb.jpg
jak siedowiedzieć co to uzywa i jak usunąć??
z góry dzięki :D
Wszystkie czasy w strefie CET. Aktualna godzina: 01:12.
