Nero Oficjalne forum poświęcone aplikacjom ze stajni Nero AG |
Data rejestracji: 28.03.2009
Ponizej przedstawiam Log z Nero:
TOSHIBA 1K22-0867-0795-66M4-5749-8189-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 8.1.1.4 Internal Version: 8, 1, 1, 4 (Nero Express) Recorder: <MATSHITA DVD-RAM UJ-850S>Version: 1.10 - HA 1 TA 0 - 8.1.1.4 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default CD-ROM: <MATSHITA DVD-RAM UJ-850S >Version: 1.10 - HA 1 TA 0 - 8.1.1.4 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === === CDRom-Device-Map === MATSHITA DVD-RAM UJ-850S F: CdRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 2038MB (2087680kB) Free physical memory: 1397MB (1430784kB) Memory in use : 31 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 29.3.2009 Kompilacja ISO 15:03:43 #1 Text 0 File SCSIPTICommands.cpp, Line 450 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 15:03:43 #2 Text 0 File Isodoc.cpp, Line 6671 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 15:03:44 #3 ISO9660GEN -11 File Geniso.cpp, Line 3347 First writeable address = 0 (0x00000000) 15:03:44 #4 Text 0 File Burncd.cpp, Line 3530 Turn on Disc-At-Once, using DVD media 15:03:44 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142 FS Settings: using validator 'CUDFSettingsValidatorDVD' ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical' Changing UDF revision from '1.02' to '1.02' 15:03:44 #6 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2134879 (474:25.04, 4169MB) 15:03:44 #7 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 15:03:44 #8 Text 0 File DlgWaitCD.cpp, Line 2972 Recorder: MATSHITA DVD-RAM UJ-850S, Media type: DVD+R Disc Manufacturer ID: <CMC MAG>, Media Type ID: <M01>, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 15:03:44 #9 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 15:03:44 #10 Text 0 File ThreadedTransferInterface.cpp, Line 785 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2134880 (2134880) = #2134880/474:25.5 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2134880 blocks [F: MATSHITA DVD-RAM UJ-850S] -------------------------------------------------------------- 15:03:44 #11 Text 0 File ThreadedTransferInterface.cpp, Line 986 Prepare [F: MATSHITA DVD-RAM UJ-850S] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4372234240, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 2134880 | 0 | 0x00 2134880 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 15:03:44 #12 Text 0 File SCSIPTICommands.cpp, Line 240 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 15:03:44 #13 Text 0 File Burncd.cpp, Line 4316 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 15:03:44 #14 Phase 24 File dlgbrnst.cpp, Line 1764 Caching of files started 15:03:44 #15 Text 0 File Burncd.cpp, Line 4435 Cache writing successful. 15:03:44 #16 Phase 25 File dlgbrnst.cpp, Line 1764 Caching of files completed 15:03:44 #17 Phase 36 File dlgbrnst.cpp, Line 1764 Burn process started at 8x (11 080 KB/s) 15:03:44 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2735 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 15:03:44 #19 Text 0 File Cdrdrv.cpp, Line 10026 ---- Disc Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 7 h Disc Manufacturer ID: CMC.MAG. Media type ID: M01 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..783]: 00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38 ...CMC.MAG.M01.8 23 54 37 18 00 3E 6E 00 - 70 62 15 15 0B 0B 08 08 #T7..>n.pb...... 01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................ 01 00 38 38 00 1D 62 35 - 07 30 22 10 08 20 1C 01 ..88..b5.0"..... 00 00 00 1D 62 35 07 30 - 22 10 08 20 1C 01 00 00 ....b5.0"....... 02 00 54 70 02 38 5F 56 - 20 14 0B 0B 01 18 00 00 ..Tp.8_V........ 00 00 02 3D 5D 7A 20 14 - 0C 0A 01 18 00 00 00 10 ...=]z.......... 03 00 54 DF 02 1F 65 5A - 20 14 0C 0A 01 18 00 00 ..T...eZ........ 00 00 02 06 67 86 20 14 - 0C 0A 01 18 00 00 00 89 ....g........... 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 15:03:44 #20 SPTI -1066 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 Buffer x09df0040: Len x648 15:03:44 #21 Text 0 File DVDPlusRW.cpp, Line 675 Start write address at LBA 0 DVD high compatibility mode: Yes 15:03:44 #22 Text 0 File ThreadedTransfer.cpp, Line 268 Pipe memory size 83836800 15:14:52 #23 SPTI -1 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x03 Sense Qual: 0x01 CDB Data: 0x2A 00 00 1D 85 80 00 00 20 00 00 00 Sense Area: 0xF1 00 04 00 1D 82 90 0A 00 32 00 00 03 01 Buffer x0c4d62c0: Len x10000 0x95 41 25 EC 92 4E 0E F5 B6 03 91 9A 14 CA B4 98 0x9F 42 33 0D F6 94 69 B9 11 5E 9A 5C 1E 29 55 1A 0xE0 EA 49 2E D4 85 E1 12 7E A2 18 8B F4 25 32 94 15:14:52 #24 CDR -1 File Writer.cpp, Line 306 Unspecified Recorder Error F: MATSHITA DVD-RAM UJ-850S 15:14:52 #25 SPTI -1046 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 83 00 00 30 05 15:14:52 #26 SPTI -1046 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x5B 01 06 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 83 00 00 30 05 15:14:52 #27 Text 0 File DVDPlusRW.cpp, Line 935 EndDAO: Last written address 1934720 15:14:52 #28 CDR -1046 File WriterStatus.cpp, Line 162 Illegal disc F: MATSHITA DVD-RAM UJ-850S 15:14:52 #29 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 15:14:52 #30 Phase 38 File dlgbrnst.cpp, Line 1764 Burn process failed at 8x (11 080 KB/s) 15:14:52 #31 Text 0 File SCSIPTICommands.cpp, Line 287 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 15:14:56 #32 Text 0 File Cdrdrv.cpp, Line 11276 DriveLocker: UnLockVolume completed 15:14:56 #33 Text 0 File SCSIPTICommands.cpp, Line 450 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon |
LG GSA-h55L i problem z nagrywaniem plyt DVD | quiet | Napędy optyczne DVD | 15 | 30.12.2007 13:03 |
LG GSA-4166B Problem z nagrywaniem DVD | Zabuzasan | Napędy optyczne DVD | 4 | 02.12.2006 23:01 |
Problem z nagrywaniem DVD | Str4ngeR | Napędy optyczne DVD | 2 | 16.03.2006 20:48 |
problem z nagrywaniem DVD Alcoholem120% | p911 | Napędy optyczne DVD | 1 | 21.02.2006 17:56 |
problem z nagrywaniem plyt dvd | buncol555 | Napędy optyczne DVD | 3 | 11.01.2006 18:59 |
