Dane Forum związane z nagrywaniem danych, za pomocą programów - Nero Burning ROM (tylko część o danych), Nero Express (tylko część o danych), Nero BackItUp, Nero InCD |
#21 |
Data rejestracji: 16.08.2007
Log
Dzieki za zainteresowanie moze poradzicie co jest nie tak, a oto log:
Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56 ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 13:54:32 NT-SPTI used Nero Version: 6.6.1.15 Internal Version: 6, 6, 1, 15 Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A106 - HA 1 TA 1 - 6.6.1.15 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <HL-DT-ST DVD-ROM GDR8163B>Version: 0L23 - HA 1 TA 2 - 6.6.1.15 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === CdRomPeripheral : HL-DT-ST CD-RW GCE-8527B atapi Port 0 ID 0 DMA: On DiskPeripheral : Maxtor 6L250S0 atapi Port 2 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 3 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVD-ROM GDR8163B atapi Port 3 ID 1 DMA: On DiskPeripheral : IC35L040AVER07-0 ER4O UlSata Port 4 ID 4 DMA: Off === CDRom-Device-Map === HL-DT-ST DVD-ROM GDR8163B I: CDRom2 HL-DT-ST CD-RW GCE-8527B L: CDRom0 HL-DT-ST DVDRAM GSA-4163B N: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 1022MB (1047272kB) Free physical memory: 376MB (385128kB) Memory in use : 63 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 22.8.2007 Kompilacja ISO 13:54:56 #1 Text 0 File SCSIPTICommands.cpp, Line 403 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 13:54:56 #2 Text 0 File Isodoc.cpp, Line 6494 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 13:54:56 #3 ISO9660GEN -11 File geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 13:54:57 #4 Text 0 File Burncd.cpp, Line 3316 Turn on Disc-At-Once, using DVD media 13:54:58 #5 Text 0 File DlgWaitCD.cpp, Line 281 Last possible write address on media: 4173823 (927:30.73, 8151MB) Last address to be written: 3831887 (851:31.62, 7484MB) 13:54:58 #6 Text 0 File DlgWaitCD.cpp, Line 293 Write in overburning mode: NO (enabled: CD) 13:54:58 #7 Text 0 File DlgWaitCD.cpp, Line 2616 Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R9 Double Layer Disc Manufacturer ID: CMC MAG, Media Type ID: D04, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 13:54:58 #8 Text 0 File DlgWaitCD.cpp, Line 459 >>> Protocol of DlgWaitCD activities: <<< ========================================= 13:54:58 #9 Text 0 File ThreadedTransferInterface.cpp, Line 814 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 3831888 (3831888) = #3831888/851:31.63 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3831888 blocks [HL-DT-ST DVDRAM GSA-4163B] -------------------------------------------------------------- 13:54:58 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1013 Prepare recorder [HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7847706624, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 3831888 | lead-out | 1 | 0x41 | 0x00 13:54:58 #11 Text 0 File SCSIPTICommands.cpp, Line 208 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 13:54:58 #12 Phase 24 File dlgbrnst.cpp, Line 1685 Caching of files started 13:54:58 #13 Text 0 File Burncd.cpp, Line 4158 Cache writing successful. 13:54:58 #14 Phase 25 File dlgbrnst.cpp, Line 1685 Caching of files completed 13:54:58 #15 Phase 36 File dlgbrnst.cpp, Line 1685 Burn process started at 2,4x (3 324 KB/s) 13:54:58 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2717 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 13:54:58 #17 Text 0 File DVDPlusDualLayer.cpp, Line 466 Disc finalized, LBA total Image size: 3831888 (7484MB), Last LBA L0: 1915951 (3742MB) 13:55:05 #18 SPTI -1135 File SCSIPassThrough.cpp, Line 178 CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00 Sense Area: 0x70 00 03 00 00 00 00 10 35 2D 00 0E 0C Buffer x07fc0240: Len xc 0x00 0A 00 00 00 00 00 00 00 1D 3C 30 13:55:05 #19 Text 0 File DVDPlusDualLayer.cpp, Line 642 L0 Data Zone Capacity not set. Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB) 13:55:05 #20 CDR -1135 File ThreadedTransferInterface.cpp, Line 1767 Write error N: HL-DT-ST DVDRAM GSA-4163B 13:55:05 #21 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1767 Could not perform start of Disc-at-once 13:55:05 #22 Phase 38 File dlgbrnst.cpp, Line 1685 Burn process failed at 2,4x (3 324 KB/s) 13:55:05 #23 Text 0 File SCSIPTICommands.cpp, Line 253 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 13:55:09 #24 Text 0 File Cdrdrv.cpp, Line 9945 DriveLocker: UnLockVolume completed 13:55:09 #25 Text 0 File SCSIPTICommands.cpp, Line 403 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02 File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-12-05 07:12:26 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : (Security Option) |
