-   Dane (https://forum.cdrinfo.pl/f59/)
-   -   problem z wypalaniem dvd DL (https://forum.cdrinfo.pl/f59/problem-wypalaniem-dvd-dl-72212/)
NeoFighter 16.06.2007 23:30
sprobuj wypalic trybem TAO track at once, zamiast DAO
insanitarium 16.06.2007 23:18
problem z nagraniem dvd dl
Witam,
mam problem z nagraniem dvd 9 i nie mam pojecia jak go rozwiazac.
Wywala komunikat could not perform start of Disc-at-once,
nagrywarka to lg gsa 4163b, firmware a106 czyli najnowszy, ASPI sprawdzone i zainstalowane, w menedzerze urzadzen w kontrolerach IDE DMA jest wlaczone zarowno w pomocniczych jak i podstawowych
Plytki to EMTEC 9 zeta sztuka wiec raczej firmowe
ktos cos moze poradzic ??
ponizej log
dzieki za pomoc
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A106 - HA 1 TA 0 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <CW1031G YCH794P >Version: 1.0 - HA 1 TA 1 - 7.8.5.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD2000JB-00GVA0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG SP2001H atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST310211A atapi Port 1 ID 1 DMA: On
CdRomPeripheral : CW1031G YCH794P 1.0 aslkin85 Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4163B H: CDRom0
CW1031G YCH794P I: CDRom1
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1535MB (1572384kB)
Free physical memory: 1084MB (1110780kB)
Memory in use : 29 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
16.6.2007
UDF/ISO compilation
22:12:24 #1 SPTI -1033 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 10 00 00 00 00 04 01
22:12:24 #2 SPTI -1033 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x04
Sense Qual: 0x01
22:12:25 #3 Text 0 File SCSIPTICommands.cpp, Line 411
22:12:55 #4 Phase 112 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation started
22:12:55 #5 DVDREALLOC -5 File DVDVideoCompilation.cpp, Line 1317
Violation against DVD specification detected
22:12:55 #6 Phase 115 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation failed
22:12:59 #7 Phase 132 File dlgbrnst.cpp, Line 1762
DVD-Video files compliance ignored
22:12:59 #8 Text 0 File Isodoc.cpp, Line 6608
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
Character set : ISO 9660
Joliet : FALSE
22:12:59 #9 Phase 111 File dlgbrnst.cpp, Line 1762
DVD-Video files sorted
22:12:59 #10 ISO9660GEN -11 File Geniso.cpp, Line 3343
22:12:59 #11 ISO9660GEN -11 File Geniso.cpp, Line 3343
22:12:59 #12 Text 0 File Burncd.cpp, Line 3499
22:13:00 #13 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3425807 (761:17.32, 6691MB)
22:13:00 #14 Text 0 File DlgWaitCD.cpp, Line 319
22:13:00 #15 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RICOHJPN, Media Type ID: D01, Product revision number: 67
Disc Application Code: 0, Extended Information Indicators: 3
22:13:00 #16 Text 0 File DlgWaitCD.cpp, Line 493
22:13:00 #17 Text 0 File ThreadedTransferInterface.cpp, Line 793
0: TRM_DATA_MODE1 ()
original disc pos #0 + 3425808 (3425808) = #3425808/761:17.33
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3425808 blocks [H: HL-DT-ST DVDRAM GSA-4163B]
22:13:00 #18 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [H: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7016054784, ISRC ""
DAO layout:
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3425808 | 0 | 0x00
3425808 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
22:13:00 #19 Text 0 File SCSIPTICommands.cpp, Line 209
22:13:00 #20 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
22:13:00 #21 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
22:13:00 #22 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
22:13:00 #23 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
22:13:01 #24 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 2.4x (3 324 KB/s)
22:13:01 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2721
22:13:07 #26 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00
Sense Area: 0x70 00 03 00 00 00 00 10 35 2D 00 0E 0C
Buffer x077c0cc0: Len xc
0x00 0A 00 00 00 00 00 00 00 1E 5F 40
22:13:07 #27 Text 0 File DVDPlusDualLayer.cpp, Line 653
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
22:13:07 #28 CDR -1135 File ThreadedTransferInterface.cpp, Line 1752
Write error
22:13:07 #29 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
Could not perform start of Disc-at-once
22:13:07 #30 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
22:13:07 #31 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 2.4x (3 324 KB/s)
22:13:07 #32 Text 0 File SCSIPTICommands.cpp, Line 254
22:13:12 #33 Text 0 File Cdrdrv.cpp, Line 11214
22:13:12 #34 Text 0 File SCSIPTICommands.cpp, Line 411
Existing drivers:
Registry Keys:
loki7777 14.06.2007 00:57
edycja posta do 2 godzin po napisaniu go
Kris[HaMaS] 14.06.2007 00:48
jednak to wina plytki byla u kolegi tez nie poszla jakis felerny egzemplarz... ciekawe:)
p.s nie widze tu edycji posta wiec wybaczcie jeden po drugim.
Kris[HaMaS] 13.06.2007 12:56
tak obsluguje ale za duzo zabawy zeby dwie plytki wysmazyc... dobrze przynajmniej wiedziec o co chodzi:)
dzieki!
loki7777 13.06.2007 10:50
ryzyk fizyk MediaCodeSpeedEdit pobaw sie strategia dla dl'ow i dodaj mid'a:)chyba 4163 jest obslygiwana
Kris[HaMaS] 13.06.2007 10:02
no to juz nic nie powalcze, bo mam ostatni firmware jaki jest dostepny a on jest stosunkowo leciwy... wiem ze na nowszej LG, bodajze H10L ida te plytki bez klopotu. dobrze wiedziec ze to nie wina stricte mechaniczna tylko w sumie oprogramowanie wewnetrzne.
mimo wszystko dzieki!
chyba ze ktos cos jeszcze wymysli. co ciekawe widac ten nosnik, doczytuje dobrze jego pojemnosc w discinfo i w pasku w oknie nero.
joujoujou 13.06.2007 03:30
Mo***380;liwe, ***380;e w bazie firmware'u nagrywarki nie ma strategii dla tego no***347;nika, st***261;d Key Medium Error. :idea:
Kris[HaMaS] 12.06.2007 18:54
Moze ktos pomoze w mojej sprawie.
spawarka to GSA-4163B. plytka XDISC DVD+R DL.
usiluje nagrac pliki wideo (*.vob) w ilosci ponad 8 giga. zarowno przy kompilacji DVD-Video jak i DVD-ISO otrzymuje komunikat bledu.
nagrywanie rozpoczyna sie i za chwile pisze ze wykonanie polecenia rozpocznij w trybie DAO nie jest mozliwe.przy wypalaniu nie moge ruszyc opcji DAO bo jest nieaktywna. plytka jest czysta i nie naruszona. system swiezy doslownie z przed godziny, nero w wersji ostatniej tj 7.9.6.0 probowalem wiele razy i nic. tu szczegolowy raport:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A106 - HA 1 TA 0 - 7.9.6.0
CD-ROM: <PN5554I BNU203M >Version: 1.0 - HA 1 TA 2 - 7.9.6.0
DiskPeripheral : ST3160023A atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST340823A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITE-ON LTR-52246S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : PN5554I BNU203M 1.0 augd9pot Port 2 ID 0 DMA: Off
HL-DT-ST DVDRAM GSA-4163B I: CdRom0
LITE-ON LTR-52246S J: CdRom1
PN5554I BNU203M K: CdRom2
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 613MB (628216kB)
Memory in use : 40 %
Use Inquiry : 1
12.6.2007
Kompilacja UDF/ISO
17:49:24 #1 Text 0 File SCSIPTICommands.cpp, Line 424
17:49:25 #2 Phase 112 File dlgbrnst.cpp, Line 1762
17:49:25 #3 Phase 114 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation completed (no file modified)
17:49:25 #4 Text 0 File Isodoc.cpp, Line 6663
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet : FALSE
17:49:26 #5 Phase 111 File dlgbrnst.cpp, Line 1762
17:49:26 #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
17:49:26 #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
17:49:26 #8 Text 0 File Burncd.cpp, Line 3508
17:49:26 #9 Text 0 File DlgWaitCD.cpp, Line 307
Last address to be written: 3968495 (881:53.20, 7750MB)
17:49:26 #10 Text 0 File DlgWaitCD.cpp, Line 319
17:49:26 #11 Text 0 File DlgWaitCD.cpp, Line 2964
17:49:26 #12 Text 0 File DlgWaitCD.cpp, Line 493
17:49:26 #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
original disc pos #0 + 3968496 (3968496) = #3968496/881:53.21
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3968496 blocks [I: HL-DT-ST DVDRAM GSA-4163B]
17:49:26 #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [I: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8127479808, ISRC ""
DAO layout:
0 | 1 | 1 | 0x41 | 3968496 | 0 | 0x00
3968496 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
17:49:26 #15 Text 0 File SCSIPTICommands.cpp, Line 215
17:49:27 #16 Text 0 File Burncd.cpp, Line 4294
17:49:27 #17 Phase 24 File dlgbrnst.cpp, Line 1762
17:49:27 #18 Text 0 File Burncd.cpp, Line 4413
17:49:27 #19 Phase 25 File dlgbrnst.cpp, Line 1762
17:49:27 #20 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 2.4x (3***160;324 KB/s)
17:49:27 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
17:49:34 #22 SPTI -1135 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x0C
Sense Qual: 0x00
Buffer x00000000: Len xc
17:49:34 #23 Text 0 File DVDPlusDualLayer.cpp, Line 670
17:49:34 #24 CDR -1135 File ThreadedTransferInterface.cpp, Line 1752
Write error
17:49:34 #25 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
17:49:34 #26 Text 0 File ThreadedTransfer.cpp, Line 269
17:49:34 #27 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 2.4x (3***160;324 KB/s)
17:49:34 #28 Text 0 File SCSIPTICommands.cpp, Line 261
17:50:03 #29 SPTI -600 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x1B 00 00 00 02 00 00 00 00 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
17:50:05 #30 SPTI -1114 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
Sense Area: 0x70 00 06 00 00 00 00 10 00 00 00 00 29
17:50:05 #31 Text 0 File Cdrdrv.cpp, Line 11185
17:50:05 #32 Text 0 File SCSIPTICommands.cpp, Line 424
Existing drivers:
Registry Keys:
mgit 12.06.2007 17:16
Mia***322;em to samo tyle ***380;e z p***322;ytami DVDR na NEC 3550 ziana na LiteON za***322;atwi***322;a spraw***281; .... :szczerb:
jumper83 12.06.2007 17:04
jest taka sprawa ;) - zakupiłem płytki dvd dl philips-a, wypalanie przebiega normalnie sesja się zamyka nic nadzwyczajnego i tu pojawia się problem - po wypaleniu i ponownym włożeniu płyty do napędy płyta jest ... wg. nagrywary pusta dopiero po odpaleniu jej przez isobustera okazuje się że siedzą na niej wszystkie wypalone dane ale tak "normalnie" to ni cholera nie można nic zobaczyć na tej płycie - właściwie to już kilku płytach, wypalane były dwiema wersjami nero dvddecrypterem i dalej to samo płyta po nagraniu tak jakby była pusta .mam nagrywarke samsung sh-s162a próby z nagraniem były też prowadzone na nagrywardce LG z takim samym skutkiem :/. ma ktoś jakiś pomysł o co chodzi? byłem już w kilku sklepach z kompami i nikt nie ma zielonego pojęcia co się dzieje.
Wszystkie czasy w strefie CET. Aktualna godzina: 11:05.
