Stary 07.09.2011, 09:22   #46
frog
Żabol
Avatar użytkownika frog
Data rejestracji: 27.04.2003
No, cos sie ruszylo z dzwiekiem przestrzennym
3.1.228 released
Added by Andreas Öman about 1 hour ago.
Another release.
This build adds support for multichannel audio output on PS3 (AC-3, DTS and 8 channel linear PCM).
Note that due to how the PS3 audio frameworks applications can not output raw digital bitstreams.
So Showtime still needs to decode the audio and than the PS3 will reencode the audio in the best available encoding mode the user has selected (or don't do any encoding at all if 8 channel PCM is available). Still this is a major step compared to having just 2 channel stereo.
For all you who roll your own builds of Showtime, please note that you need latest version of my PSL1GHT fork for Showtime to build.
I've also fixed a major memory leak that manifested itself when rendering fonts with outline (which is default for subtitles).
So if you watched a movie with subtitles the memory would drain and Showtime would eventually crash.
Another thing is the increase of packet buffer to 40MB in conjunction with some adjustments to socket buffers, etc.
This should hopefully make streaming over lousy wireless connections better.
As always the binaries are available here
Have fun!
/Andreas
NEWS SOURCE: http://www.lonelycoder.com/redmine/p.../showtime/news
HARDSTYLE IS MY STYLE !!!
IMPREZKA ON-LINE (tylko powyzej 18 lat) Remix Off topic 37390 02.12.2011 17:07
Funny fotos, kawaly... itp. - jeszcze sie tak nie usmialem :) Kasprzak Humor 4225 11.07.2005 12:59
Projekt Freeware Calme Komputery - oprogramowanie i sprzęt 0 16.05.2005 20:31
Wszystkie czasy w strefie CET. Aktualna godzina: 19:59.
