Stary 17.03.2011, 10:35   #1
frog
Żabol
Avatar użytkownika frog
Data rejestracji: 27.04.2003
Odtwarzacze multimedialne na PS3
Moze troszke sie rozpedzilem z ta liczba mnoga w temacie ale chyba cos sie ruszylo w tym temacie i raczej napewno na tej jednej aplikacji nie poprzestanie a wiec zakladam.
Showtime Mediaplayer Ported to the PS3!
Originally Posted by andoma
I've ported my opensource mediaplayer called Showtime to PS3 + psl1ght
A quick getting started guide (also include download links to pkg and self files):
Showtime - PS3 usage guide - Home Theater System
It's still in beta stage but should work to some extent. As it relies on FFmpeg for audio / video decoding it should be able to play most files as normal open source media players can do (XBMC, VLC, etc). I've not tested it thoroughly yet (in particular video playback).
If you find files that are not playable or plays with framedrops or loses av-sync etc, please make them available so I can test them.
Extra kudos for filing decent bugs at Showtime's own own bugtracker
Happy media playback!
Zapowiada sie ZAJEFISCIE !!! MKV comming for ya !! ;>
I jeszcze
[B]PS3 usage guide
Getting Started
Download the files from here:download
Full featureset see:This
Most of this should work except for playback of high res. HD videos (basically when the PPU runs out of cycles). There are some methods of fixing them, but no one knows yet. I will update it when they do.
Video output
This has been tested with 576i, 720p and 1080i video resolutions.
People have tried to set reasonable defaults for overscan compensation. But if it not correct for you it can be adjusted under Settings -> Display and UI settings
Buttons on controller (Controls)
***10005; Enter current item
***9675; Go back (exit)
***9651; Show options / playcontrol menu
***9633; Screensaver (Until something better has been figured out)
***9658; Play/Pause
***9644; Home menu
***10012; Navigate it
L3 ***8211; Get playback info (During video playback)
R3 ***8211; Get log console
Keyboard
-The only current way to input characters is by using a standard keyboard.
- Virtual keyboards are supported at the moment.
Things that do NOT work
-TV-style remote controller has not been tested. No idea if it works or not.
-BD/DVD/CD Discs ***8211; No idea how that works
-Digital pass thru audio (AC3, DTS, etc)
HARDSTYLE IS MY STYLE !!!
Ostatnio zmieniany przez frog : 17.03.2011 o godz. 12:01
Stary 17.03.2011, 12:49   #2
ethar
Herbaciarz^^
Data rejestracji: 19.09.2008
ethar zaczyna zdobywać reputację <1 - 49 pkt>
No to jeszcze czekamy na obsługę kontenerów *.mkv i wielokanałowych audio
https://www.facebook.com/CzytelnikPlakalJakKupowal - moja osobista misja.
https://www.facebook.com/ZakonBrowardynow - wytłumaczenie mojego uwielbienia do piwa.
kubacki.deviantart.com
ethar jest offline   Odpowiedz cytując ten post
Stary 17.03.2011, 13:33   #3
M@X
Get a Mac!
Avatar użytkownika M@X
Data rejestracji: 18.04.2003
Bez obslugi DTS/AC3 passthrough i dyskow wizyjnych to na razie nic nie warte...
Stary 17.03.2011, 15:48   #4
ethar
Herbaciarz^^
No i NTSF...
Stary 17.03.2011, 16:24   #5
M@X
Get a Mac!
...i HFS+
Wiadomo***347;***263; wys***322;ana z ***63743; iPhone przy u***380;yciu Tapatalk
Stary 17.03.2011, 23:49   #6
Wolałbym port XBMC na PPC. Taki grymaśny jestem. ;P Oczywiście cieszę się. Wreszcie coś się ruszyło w temacie - i to nawet szybko, w jeden kwartał już odtwarzacz.
Dawno temu był taki projekt jak "Mega", nawet chyba ktoś to wskrzesił przy okazji bumu na dongle. Jeszcze wcześniej zdaje się jakiś niby XBMC dla Other OS. Szkoda, że z nich nic nie wyszło.
Stary 18.03.2011, 10:13   #7
obibox
Data rejestracji: 10.09.2010
obibox zaczyna zdobywać reputację <1 - 49 pkt>
a ja się ciesze że w końcu mogę FLAC sobie słuchać bez konwertowania do WAV , czekałem na to i się doczekałem. Oby więcej takich HB
edit// czy ktoś wie jak w "keymapper" przypisać funkcje playera do pada?
mój diy PsGroove (HID BTL) na PIC18F2550
Ostatnio zmieniany przez obibox : 18.03.2011 o godz. 10:48
obibox jest offline   Odpowiedz cytując ten post
Stary 19.03.2011, 00:01   #8
szczuru
eŁDeZet Ma(j)ster
Avatar użytkownika szczuru
Data rejestracji: 05.04.2005
I działa MKV z wyborem ścieżki audio i napisów
Stary 19.03.2011, 11:21   #9
ethar
Herbaciarz^^
Oooo to bajera Tylko by jeszcze czytał NTSF by oglądać *.mkv powyżej 4GB...
Stary 19.03.2011, 15:45   #10
Są scenowe moduły do odczytu NTFS, więc to raczej kwestia najbliższego buildu (o ile już nie obsługuje, nie czytałem readme ).
Stary 19.03.2011, 20:19   #11
szczuru
eŁDeZet Ma(j)ster
Prośba o obsługę NTFS trafiła do autora Doda ją w najbliższej przyszłości.
Stary 19.03.2011, 20:48   #12
obibox
szczuru - działa Ci master volume? bo mi działa tylko animacja ale nie ma to wpływu niestety na głośność dźwięku wychodzącego z konsoli ani na wyjściu analogowym ani optycznym, na hdmi nie mam jak sprawdzić:/ moja konsola to CECH2104B
Stary 20.03.2011, 00:00   #13
szczuru
eŁDeZet Ma(j)ster
Nie mam klawiatury na usb (czyt. nie chce mi sie z kompa przepinać ) żeby podbindować klawisze
Stary 21.03.2011, 12:51   #14
obibox
to może wypowie się ktoś mniej leniwy, mający do powiedzenia coś w temacie?
edit down: bardzo proszę, ciekaw jestem wyniku
Ostatnio zmieniany przez obibox : 21.03.2011 o godz. 13:10
Stary 21.03.2011, 12:56   #15
Ja mam klawiaturę, mogę sprawdzić.
IMPREZKA ON-LINE (tylko powyzej 18 lat) Remix Off topic 37390 02.12.2011 17:07
Funny fotos, kawaly... itp. - jeszcze sie tak nie usmialem :) Kasprzak Humor 4225 11.07.2005 12:59
Projekt Freeware Calme Komputery - oprogramowanie i sprzęt 0 16.05.2005 20:31
Wszystkie czasy w strefie CET. Aktualna godzina: 14:43.
