Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD Tematy poświęcone nagrywarkom i nagrywaniu płyt Blu-ray, HD DVD |
Data rejestracji: 13.12.2017
Log z ImgBurn z nagrywania płyty RITEK BD-R DL 50GB
Kod:
I 21:08:53 Calculating Totals... I 21:08:53 Preparing Image... I 21:08:54 Contents: 5 888 Files, 44 Folders I 21:08:54 Content Type: Data I 21:08:54 Data Type: MODE1/2048 I 21:08:54 File System(s): UDF (2.50) I 21:08:54 Volume Label: ZDJECIA_ARCHIWUM_4 I 21:08:54 Size: 49 446 347 424 bytes I 21:08:54 Sectors: 24 146 671 I 21:08:54 Image Size: 49 478 434 816 bytes I 21:08:54 Image Sectors: 24 159 392 I 21:08:57 Operation Successfully Completed! - Duration: 00:00:04 I 21:08:57 Operation Started! I 21:08:57 Source File: -==/\/[BUILD IMAGE]\/\==- I 21:08:57 Source File Sectors: 24 159 392 (MODE1/2048) I 21:08:57 Source File Size: 49 478 434 816 bytes I 21:08:57 Source File Volume Identifier: ZDJECIA_ARCHIWUM_4 I 21:08:57 Source File Volume Set Identifier: 4B8DA91701708C4F I 21:08:57 Source File Application Identifier: ImgBurn v2.5.8.0 I 21:08:57 Source File Implementation Identifier: ImgBurn I 21:08:57 Source File File System(s): UDF (2.50) I 21:08:57 Destination Device: [1:0:0] HL-DT-ST BD-RE BH16NS55 1.02 (E:) (RAID) I 21:08:57 Destination Media Type: BD-R (Disc ID: RITEK-DR3-000) I 21:08:57 Destination Media Supported Write Speeds: 2x; 4x; 6x I 21:08:57 Destination Media Sectors: 24 438 784 I 21:08:57 Write Mode: BD I 21:08:57 Write Type: DAO I 21:08:57 Write Speed: 6x I 21:08:57 Hardware Defect Management Active: No I 21:08:57 BD-R Verify Not Required: Yes I 21:08:57 Link Size: Auto I 21:08:57 Lock Volume: Yes I 21:08:57 Test Mode: No I 21:08:57 OPC: No I 21:08:57 BURN-Proof: Enabled I 21:08:57 Write Speed Successfully Set! - Effective: 26 976 KB/s (6x) I 21:09:27 Filling Buffer... (80 MiB) I 21:09:30 Writing LeadIn... I 21:09:31 Writing Session 1 of 1... (1 Track, LBA: 0 - 24159391) I 21:09:31 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 24159391) I 21:09:31 Writing Layer 0... (LBA: 0 - 12219391) I 21:25:14 Writing Layer 1... (LBA: 12219392 - 24159391) I 21:40:33 Synchronising Cache... I 21:40:34 Closing Track... I 21:40:35 Finalising Disc... I 21:40:53 Exporting Graph Data... I 21:40:53 Graph Data File: C:\Users\mslus\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BH16NS55_1.02_ŚRODA-13-GRUDZIEŃ-2017_21-08_RITEK-DR3-000_6x.ibg I 21:40:53 Export Successfully Completed! I 21:40:53 Operation Successfully Completed! - Duration: 00:31:55 I 21:40:53 Average Write Rate: 25 949 KiB/s (5.9x) - Maximum Write Rate: 26 802 KiB/s (6.1x) I 21:40:53 Cycling Tray before Verify... W 21:41:01 Waiting for device to become ready... I 21:41:16 Device Ready! I 21:41:21 Operation Started! I 21:41:21 Source Device: [1:0:0] HL-DT-ST BD-RE BH16NS55 1.02 (E:) (RAID) I 21:41:21 Source Media Type: BD-R (Disc ID: RITEK-DR3-000) I 21:41:21 Source Media Supported Read Speeds: 2x; 4x; 6x; 8x I 21:41:21 Source Media Supported Write Speeds: 2x; 4x; 6x I 21:41:21 Source Media Sectors: 24 159 392 I 21:41:21 Source Media Size: 49 478 434 816 bytes I 21:41:21 Image File: -==/\/[BUILD IMAGE]\/\==- I 21:41:21 Image File Sectors: 24 159 392 (MODE1/2048) I 21:41:21 Image File Size: 49 478 434 816 bytes I 21:41:21 Image File Volume Identifier: ZDJECIA_ARCHIWUM_4 I 21:41:21 Image File Volume Set Identifier: 4B8DA91701708C4F I 21:41:21 Image File Application Identifier: ImgBurn v2.5.8.0 I 21:41:21 Image File Implementation Identifier: ImgBurn I 21:41:21 Image File File System(s): UDF (2.50) I 21:41:21 Read Speed (Data/Audio): MAX / MAX I 21:41:22 Read Speed - Effective: 3x - 8x; 8x - 3x I 21:41:22 Verifying Session 1 of 1... (1 Track, LBA: 0 - 24159391) I 21:41:22 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 24159391) I 21:41:22 Verifying Layer 0... (LBA: 0 - 12219391) I 21:57:29 Verifying Layer 1... (LBA: 12219392 - 24159391) W 22:11:22 Failed to Read Sectors 23389216 - 23389247 - Reason: L-EC Uncorrectable Error W 22:11:27 Failed to Read Sector 23389216 - Reason: L-EC Uncorrectable Error W 22:11:27 Sector 23389216 maps to File: \@Tene\IMG_6337.JPG E 22:12:40 Failed to Read Sector 23389216 - Reason: L-EC Uncorrectable Error E 22:12:40 Sector 23389216 maps to File: \@Tene\IMG_6337.JPG E 22:12:40 Failed to Verify Sectors! I 22:12:41 Exporting Graph Data... I 22:12:41 Graph Data File: C:\Users\mslus\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BH16NS55_1.02_ŚRODA-13-GRUDZIEŃ-2017_21-08_RITEK-DR3-000_6x.ibg I 22:12:41 Export Successfully Completed! E 22:12:41 Operation Failed! - Duration: 00:31:19 I 22:12:41 Average Verify Rate: 24 908 KiB/s (5.7x) - Maximum Verify Rate: 36 215 KiB/s (8.2x) Ostatnio zmieniany przez scav666 : 14.12.2017 o godz. 12:05 |
Problem z nagrywaniem na LG RH177 80gb | lukaso93lw | Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) | 0 | 17.01.2010 10:31 |
LG GSA-H10N problem z nagrywaniem | koozyn | Napędy optyczne DVD | 6 | 15.11.2006 13:22 |
Problem z nagrywaniem płyt większych niż 700MB na LG 8520B | mirmol | Napędy optyczne CD | 8 | 27.11.2003 21:01 |
problem z nagrywaniem na lg gce8400b 1.03 | thc | Napędy optyczne CD | 3 | 25.10.2002 19:30 |
Lg 16x i problem z nagrywaniem audio | czajnior | Napędy optyczne CD | 4 | 21.03.2002 07:43 |
