Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD Tematy poświęcone nagrywarkom i nagrywaniu płyt Blu-ray, HD DVD |
31.07.2018, 09:34 | #31 |
Data rejestracji: 26.07.2018
W ImgBurn to samo.
Wina płyt to nie jest na bank. Mam jaką starą nagrywarkę LG i się wypala. Do tego próbowałam 3 różnych marek nośników: HP, Maxell i Verbatim. LOG: I 10:32:56 ImgBurn Version 2.5.8.0 started! I 10:32:56 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200) I 10:32:56 Total Physical Memory: 7 285 764 KiB - Available: 4 447 244 KiB I 10:32:56 Initialising SPTI... I 10:32:56 Searching for SCSI / ATAPI devices... I 10:32:57 -> Drive 1 - Info: HL-DT-ST BD-RE BH16NS40 1.03-A0 (D (ATA) I 10:32:57 -> Drive 2 - Info: ASUS BW-16D1HT 3.03 (E (ATA) I 10:32:57 Found 2 BD-RE XLs! I 10:35:50 Operation Started! I 10:35:50 Source File: F:\obrazy dvd (iso)\piotrus.iso I 10:35:50 Source File Sectors: 2 119 840 (MODE1/2048) I 10:35:50 Source File Size: 4 341 432 320 bytes I 10:35:50 Source File Volume Identifier: piotrus I 10:35:50 Source File Volume Set Identifier: 4CF9ABB9________piotrus I 10:35:50 Source File Implementation Identifier: VsoSoftware I 10:35:50 Source File File System(s): ISO9660; UDF (1.02) I 10:35:51 Destination Device: [1:1:0] ASUS BW-16D1HT 3.03 (E (ATA) I 10:35:51 Destination Media Type: DVD+R (Disc ID: RITEK-F16-01) I 10:35:51 Destination Media Supported Write Speeds: 8x; 16x I 10:35:51 Destination Media Sectors: 2 295 104 I 10:35:51 Write Mode: DVD I 10:35:51 Write Type: DAO I 10:35:51 Write Speed: 8x I 10:35:51 DVD+R Reserve Track: No I 10:35:51 Link Size: Auto I 10:35:51 Lock Volume: Yes I 10:35:51 Test Mode: No I 10:35:51 OPC: No I 10:35:51 BURN-Proof: Enabled I 10:35:51 Write Speed Successfully Set! - Effective: 11 080 KB/s (8x) I 10:35:52 Filling Buffer... (80 MiB) I 10:35:52 Writing LeadIn... I 10:36:04 Writing Session 1 of 1... (1 Track, LBA: 0 - 2119839) I 10:36:04 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2119839) W 10:37:52 Failed to Write Sectors 17664 - 17695 - Reason: Write Error W 10:37:52 Retrying (1 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (2 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (3 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (4 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (5 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (6 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (7 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (8 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (9 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (10 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (11 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (12 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (13 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (14 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (15 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (16 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (17 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:52 Retrying (18 of 20)... W 10:37:52 Retry Failed - Reason: Invalid Address For Write W 10:37:53 Retrying (19 of 20)... W 10:37:53 Retry Failed - Reason: Invalid Address For Write W 10:37:53 Retrying (20 of 20)... W 10:37:53 Retry Failed - Reason: Invalid Address For Write |
31.07.2018, 11:27 | #32 | |
W Log błędy zapisu pod koniec operacji .. może być to problem chipset AMD A68H \kontroler SATA AMD \ sterowniki SATA AMD ... Jaką dokładnie masz wersje Windows 10 ? Musisz znaleźć sterowniki chipset \ SATA do tej płyty głównej i systemu .. |
01.08.2018, 08:06 | #33 |
Win 10 home wersja 1803
Z chipsetami sobie nie daję rady, ponieważ nie chcą się zainstalować z tej strony, którą mi podaliście wcześniej. Chyba, że ja robię coś źle. Instalkę do SATA uruchamiam poprzez plik rcraid.msi (żadnych exe tam nie mam po ściągnięciu) Po tym wyskakuje mi błąd, że ta aplikacja nie jest kompatybilna z moim windowsem (a ściągam oczywiście pliki do win10 bo taki posiadam). Ostatnio zmieniany przez gochad0303 : 01.08.2018 o godz. 08:14 |
01.08.2018, 10:16 | #34 | |
01.08.2018, 10:19 | #35 |
a Mogę jaśniej?
co mam ściągnąć i jak zainstalować? |
01.08.2018, 12:00 | #36 |
Np: AIDA32-Enterprise System Information
https://www.instalki.pl/programy/dow...formation.html |
01.08.2018, 12:22 | #37 |
ID płyty głównej: 63-0100-000001-00101111-041312-Chipset$F2A68HM-DS2_BIOS DATE: 12/24/15 16:28:30 VER: 04.06.05
Nazwa płyty głównej Gigabyte GA-F2A68HM-DS2 Nazwa systemu operacyjnego Microsoft Windows 10 Wersja systemu operacyjnego 10.0.17134.1 To jest to, co podawałam wcześniej. Naprawdę mi to już spokoju nie daje. stara nagrywarka działa jak należy, a dwie nowe Blu/DVD się tak zachowują. Ostatnio zmieniany przez gochad0303 : 01.08.2018 o godz. 12:32 |
01.08.2018, 12:43 | #38 | |
Do chipsetu do W10 32\64 są sterowniki dla Gigabyte GA-F2A68HM-DS2 http://download.gigabyte.eu/FileList...plus_win10.zip Jeżeli nie da się zainstalować to tylko pomoc techniczna Gigabyte może coś podpowiedzieć ,pomóc ... na pewno nie jest to normalne https://www.gigabyte.com/Support/Technical-Support |
Podobne dyskusje | ||||
Problemy z nagrywarą LG HL-DT-ST CD-RW GCE-8160B Proszę o pomoc!!! | Maczeque | Napędy optyczne CD | 1 | 05.12.2005 07:30 |
Problemy z nagrywarką LG GSA-4163B | waljo | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 15.08.2005 12:51 |
Informacje o bananach | IceManSpy | Propozycje, sugestie, błędy forum | 27 | 14.07.2005 20:19 |
Problemy z LG 48x24x48x | ultur | Napędy optyczne CD | 7 | 14.12.2003 17:53 |
3 problemy zwiazane z nagrywaniem CD | BoBsOn | Napędy optyczne CD | 4 | 22.08.2002 10:38 |
