Stary 31.07.2018, 10:34   #31
gochad0303
Data rejestracji: 26.07.2018
gochad0303 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
W ImgBurn to samo.
Wina płyt to nie jest na bank. Mam jaką starą nagrywarkę LG i się wypala. Do tego próbowałam 3 różnych marek nośników: HP, Maxell i Verbatim.
LOG:
I 10:32:56 ImgBurn Version 2.5.8.0 started!
I 10:32:56 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 10:32:56 Total Physical Memory: 7 285 764 KiB - Available: 4 447 244 KiB
I 10:32:56 Initialising SPTI...
I 10:32:56 Searching for SCSI / ATAPI devices...
I 10:32:57 -> Drive 1 - Info: HL-DT-ST BD-RE BH16NS40 1.03-A0 (D (ATA)
I 10:32:57 -> Drive 2 - Info: ASUS BW-16D1HT 3.03 (E (ATA)
I 10:32:57 Found 2 BD-RE XLs!
I 10:35:50 Operation Started!
I 10:35:50 Source File: F:\obrazy dvd (iso)\piotrus.iso
I 10:35:50 Source File Sectors: 2 119 840 (MODE1/2048)
I 10:35:50 Source File Size: 4 341 432 320 bytes
I 10:35:50 Source File Volume Identifier: piotrus
I 10:35:50 Source File Volume Set Identifier: 4CF9ABB9________piotrus
I 10:35:50 Source File Implementation Identifier: VsoSoftware
I 10:35:50 Source File File System(s): ISO9660; UDF (1.02)
I 10:35:51 Destination Device: [1:1:0] ASUS BW-16D1HT 3.03 (E (ATA)
I 10:35:51 Destination Media Type: DVD+R (Disc ID: RITEK-F16-01)
I 10:35:51 Destination Media Supported Write Speeds: 8x; 16x
I 10:35:51 Destination Media Sectors: 2 295 104
I 10:35:51 Write Mode: DVD
I 10:35:51 Write Type: DAO
I 10:35:51 Write Speed: 8x
I 10:35:51 DVD+R Reserve Track: No
I 10:35:51 Link Size: Auto
I 10:35:51 Lock Volume: Yes
I 10:35:51 Test Mode: No
I 10:35:51 OPC: No
I 10:35:51 BURN-Proof: Enabled
I 10:35:51 Write Speed Successfully Set! - Effective: 11 080 KB/s (8x)
I 10:35:52 Filling Buffer... (80 MiB)
I 10:35:52 Writing LeadIn...
I 10:36:04 Writing Session 1 of 1... (1 Track, LBA: 0 - 2119839)
I 10:36:04 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2119839)
W 10:37:52 Failed to Write Sectors 17664 - 17695 - Reason: Write Error
W 10:37:52 Retrying (1 of 20)...
W 10:37:52 Retry Failed - Reason: Invalid Address For Write
W 10:37:52 Retrying (2 of 20)...
W 10:37:52 Retrying (3 of 20)...
W 10:37:52 Retrying (4 of 20)...
W 10:37:52 Retrying (5 of 20)...
W 10:37:52 Retrying (6 of 20)...
W 10:37:52 Retrying (7 of 20)...
W 10:37:52 Retrying (8 of 20)...
W 10:37:52 Retrying (9 of 20)...
W 10:37:52 Retrying (10 of 20)...
W 10:37:52 Retrying (11 of 20)...
W 10:37:52 Retrying (12 of 20)...
W 10:37:52 Retrying (13 of 20)...
W 10:37:52 Retrying (14 of 20)...
W 10:37:52 Retrying (15 of 20)...
W 10:37:52 Retrying (16 of 20)...
W 10:37:52 Retrying (17 of 20)...
W 10:37:52 Retrying (18 of 20)...
W 10:37:53 Retrying (19 of 20)...
W 10:37:53 Retry Failed - Reason: Invalid Address For Write
W 10:37:53 Retrying (20 of 20)...
gochad0303 jest offline   Odpowiedz cytując ten post
Stary 31.07.2018, 12:27   #32
Napisany przez gochad0303 Podgląd Wiadomości
W ImgBurn to samo.
W Log błędy zapisu pod koniec operacji .. może być to problem chipset AMD A68H \kontroler SATA AMD \ sterowniki SATA AMD ...
Jaką dokładnie masz wersje Windows 10 ?
Musisz znaleźć sterowniki chipset \ SATA do tej płyty głównej i systemu ..
Stary 01.08.2018, 09:06   #33
gochad0303
Win 10 home wersja 1803
Z chipsetami sobie nie daję rady, ponieważ nie chcą się zainstalować z tej strony, którą mi podaliście wcześniej.
Chyba, że ja robię coś źle.
Instalkę do SATA uruchamiam poprzez plik rcraid.msi (żadnych exe tam nie mam po ściągnięciu)
Po tym wyskakuje mi błąd, że ta aplikacja nie jest kompatybilna z moim windowsem (a ściągam oczywiście pliki do win10 bo taki posiadam).
Ostatnio zmieniany przez gochad0303 : 01.08.2018 o godz. 09:14
Stary 01.08.2018, 11:16   #34
Pobierz jakiś program który pokaże dokładnie wersje Windows oraz dokładny hardware komputera , typ płyty głównej .. bo inaczej czort go wie do czego szukać sterowników ....
Stary 01.08.2018, 11:19   #35
gochad0303
a Mogę jaśniej?
co mam ściągnąć i jak zainstalować?
Stary 01.08.2018, 13:00   #36
a Mogę jaśniej?
Np: AIDA32-Enterprise System Information
https://www.instalki.pl/programy/dow...formation.html
Stary 01.08.2018, 13:22   #37
gochad0303
ID płyty głównej: 63-0100-000001-00101111-041312-Chipset$F2A68HM-DS2_BIOS DATE: 12/24/15 16:28:30 VER: 04.06.05
Nazwa płyty głównej Gigabyte GA-F2A68HM-DS2
Nazwa systemu operacyjnego Microsoft Windows 10
Wersja systemu operacyjnego 10.0.17134.1
To jest to, co podawałam wcześniej.
Naprawdę mi to już spokoju nie daje.
stara nagrywarka działa jak należy, a dwie nowe Blu/DVD się tak zachowują.
Ostatnio zmieniany przez gochad0303 : 01.08.2018 o godz. 13:32
Stary 01.08.2018, 13:43   #38
Każdy sprzęt ma inny kontroler Sata , sterowniki itp itd ...nie można porównywać że jeden działa to wszystkie będą działać ...nie ma tak ..
Do chipsetu do W10 32\64 są sterowniki dla Gigabyte GA-F2A68HM-DS2
http://download.gigabyte.eu/FileList...plus_win10.zip
Jeżeli nie da się zainstalować to tylko pomoc techniczna Gigabyte może coś podpowiedzieć ,pomóc ... na pewno nie jest to normalne
https://www.gigabyte.com/Support/Technical-Support
Problemy z nagrywarą LG HL-DT-ST CD-RW GCE-8160B Proszę o pomoc!!! Maczeque Napędy optyczne CD 1 05.12.2005 09:30
Problemy z nagrywarką LG GSA-4163B waljo Flashowanie/Firmware/Podkręcanie napędów optycznych 2 15.08.2005 13:51
Problemy z LG 48x24x48x ultur Napędy optyczne CD 7 14.12.2003 19:53
3 problemy zwiazane z nagrywaniem CD BoBsOn Napędy optyczne CD 4 22.08.2002 11:38
Wszystkie czasy w strefie CET. Aktualna godzina: 04:48.
