Stary 25.04.2017, 06:13   #1
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Verbatim 8x DVD+R DL
Branded
MKM 003 (Made in UAE)
SW-5583 (1049)
@ 6x --> 2.4x
Stary 25.04.2017, 06:16   #2
jadburner
Branded
SW-5583 (1049)
@ 8x --> 4x
Stary 25.04.2017, 16:25   #3
Branded
SW-5583 (1049)
@ 6x --> 2.4x
Branded
SW-5583 (1049)
@ 8x --> 4x
Maybe MEI \ Panasonic has overdone the specification?
Stary 25.04.2017, 17:25   #4
jadburner
Thanks, czary2mary. You're right - they clearly overstated it.
Stary 01.05.2017, 06:38   #9
jadburner
Finally found my extra SW-5583.
Branded
SW-5583 (1.03)
@ 2.4x
Stary 01.05.2017, 07:19   #10
Found a second factory copy.
Has the latest firmware 1.03 already?
By the way, did you find the HP CD-Writer + 8100?
Stary 01.05.2017, 17:24   #11
jadburner
Yes, the drive already had the 1.03 firmware on it. I'm curious how 1.03 burns compared to 1049, so I'll probably post results from both as I have time.
I bought the HP CD-Writer + 8100 a while ago from someone who was getting rid of a bunch of HP drives. As I recall, there were 12 or so drives in the bunch I bought. Most were still in boxes. As I find them I'll post test results from them.
Stary 01.05.2017, 19:13   #12
On the factory software records faster Verbatim DVD + R DL MKM003 but much worse on the x8 transmission.
It may be that Primera has specifically lowered the speed index for the DVD DL in its firmware.?
Stary 01.05.2017, 19:30   #13
jadburner
That's my guess too. The drive doesn't seem to burn DL media well at 8x.
Stary 01.05.2017, 06:40   #14
jadburner
Branded
SW-5583 (1.03)
@ 4x --> 2.4x
Stary 01.05.2017, 06:42   #15
jadburner
Branded
SW-5583 (1.03)
@ 6x
Panasonic DVD+R (MBIPG101) dune2 Nośniki optyczne 0 02.04.2013 23:49
Panasonic DMR-E50 i problem z dyskami DVD-RAM piotrdeska Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) 4 21.02.2012 15:50
LG GSA-H20L nie nagrywa Panasonic DVD-RAM? tanja Napędy optyczne DVD 2 03.08.2006 20:32
Zlecę Upgrade Firmware'u W Panasonic Dmr-e500h mariusz44 Napędy optyczne DVD 1 08.09.2005 00:05
LiteOn CDRW 48x + DVD Panasonic SR-8588 Problem !!! cdwriter21 Napędy optyczne CD 1 22.03.2003 00:23
Wszystkie czasy w strefie CET. Aktualna godzina: 10:30.
