Ok, I see.
Funny thing is, I actually bought this exact type of spindle as a test, 5 years ago (Nov 2018)... :D But concluded they were shite vs the 43812 version I had at the time (which scanned much better). So never looked at those Mitsubishi ones after that (until now). |
Regarding Verbatims and Mediarange CMC BD-Rs to my personal observation, usually the Mediarange discs have a higher quality range than Verbatims, i.e. the differences between good and bad discs are higher, but I had Mediarange CMC BD-Rs with better quality than Verbatims, so you never know. Other thing I noticed is that up to 2 or 3 years ago a 50 pack had mostly same quality discs, with a few better a worse, nowadays it goes up and down all the time within the same 50 pack. And that's even visible, because some discs are darker than others, so if you look at the 50 pack from the side you can see the different darkness of the discs going up and down through the entire 50 pack, as if they mix the discs from different production lines more than in the past.
I am not allowed writing any links here yet, but put that number in a fleabay search, and plenty show up (?). Or are those 'different' ? |
Załącznik 203194 They seem to have been discontinued, and are VERY hard to find now. For a while MediaRange had the same MID and same quality, but I don't think they still do. |
(or the American product code?) And, what year were these from you think ? Or, bought when and in/from what country ? As some of these look very close to average Panasonic scans! At least at 2x. But much cheaper discs and not to mention still in production. So I wonder if similar quality is available today in Europe webshops. (and if 43838/non-printable would be better?) |
Panasonic 6x BD-R printable
MEIRA1 BDR-S13U (1.04) (manufactured December 2022 in China) burned @ 6x (P-CAV) Pretty good result as usual with Pioneer writers. :) https://forum.cdrinfo.pl/attachment....1&d=1688057780 |
Są jakieś informacje, kiedy seria S13 pojawi się w Europie?
Mediarange labled 6x BD-R DL (out of MR508 25pack)
VERBATIMf BDR-S13U (1.04) (manufactured December 2022 in China) burned @ 4x (CLV) Pretty normal result for VERBATIMf. https://forum.cdrinfo.pl/attachment....1&d=1680794443 |
Verbatim labled 6x BD-R (out of #43742 10 pack)
VERBATIMe BDR-S13U (1.04) (manufactured December 2022 in China) burned @ 8x (P-CAV) Really bad batch of VERBATIMe :( https://forum.cdrinfo.pl/attachment....1&d=1677677910 |
Mediarange labled 6x BD-R (out of MR514 25 pack)
CMCMAGBA5 BDR-S13U (1.04) (manufactured December 2022 in China) burned @ 6x (P-CAV) Basically the same result as 8x. :) https://forum.cdrinfo.pl/attachments...-104-6x-eb.png |
CMCMAGBA5 BDR-S13U (1.04) (manufactured December 2022 in China) burned @ 8x (P-CAV) Pretty nice result for 8x. :) Looks like Pioneer finally produced a series of BD writers that can deliver good results even at higher write speeds. https://forum.cdrinfo.pl/attachments...-104-8x-am.png |
Ilość załączników: 10
That's 4x BD-R DL
White inkjet hub printable TDKBLD-RFB BDR-2213 (1.03) OPC off @ 8x Załącznik 197424 Załącznik 197425 Załącznik 197426 Załącznik 197427 Załącznik 197428 Załącznik 197429 Załącznik 197430 Załącznik 197431 Załącznik 197432 Załącznik 197433 |
That's 4x BD-R DL
White inkjet hub printable TDKBLD-RFB BDR-2213 (1.03) OPC off @ 6x Załącznik 197414 Załącznik 197415 Załącznik 197416 Załącznik 197417 Załącznik 197418 Załącznik 197419 Załącznik 197420 Załącznik 197421 Załącznik 197422 Załącznik 197423 |
| Wszystkie czasy w strefie CET. Aktualna godzina: 02:19. |
