-   -   Pioneer BDR-X213 / X13 (https://forum.cdrinfo.pl/f107/pioneer-bdr-x213-x13-98599/)
Stingray 09.09.2024 22:13
Napisany przez jadburner (Post 1469736)
We appreciate you sharing that information. Are the LDC/BIS results comparable from all three drives for the same MIDs?
Your point about OPC off giving better results is also true most of the time. There are a few drive/MID exceptions, but you're generally better off leaving OPC set to off/no.
Multisession, opc off and 5 drives
1 Pioneer S12 1.03 2x
2 Pioneer 205 1.12 2x
3 ASUS16->lg 58 1v5 4x
4 Asus16 3.11 4x
5 Pioneer S12 1.03 4x
6 Pioneer 205 1.12 4x
7 Pioneer S12 1.03 6x
8 Pioneer 205 1.12 6x
9 Pioneer S12 1.03 8x
10 Pioneer 205 1.12 8x
11 Asus16 3.11 6x
12 Sony 5300 2.03 6x hypertuning on
https://i.ibb.co/F6yTV9g/verb-25-multi5.jpgupload image
Pioneer 205 glued sessions to compare (higher speed - lower jitter :-):
https://i.ibb.co/pL4D9fp/205.jpgfree image hosting
Pioneer S12JX (a positive correlation - jitter/LDC with speed):
https://i.ibb.co/H7kJFvk/s12jx.jpg
jadburner 09.09.2024 21:53
Napisany przez Stingray (Post 1469735)
I'm not arguing, I was just surprised that ASUS/LG writes with better jitter
Stingray 09.09.2024 21:19
Napisany przez jadburner (Post 1469732)
Coopervid is correct. Jitter does not seem to affect the readability of a Blu-ray disc. This is also my conclusion after burning and testing several thousand Blu-ray discs.
jadburner 09.09.2024 21:06
Napisany przez Quintam (Post 1469729)
Millenniata M-DISC 4x BD-R
MID: MILLENMR1 (000)
BDR-X213 (1.04) (QUALITY MODE)
OPC = Yes
@ 4x
Załącznik 210414
Załącznik 210415
Załącznik 210416
Your CMCMAGBA5 and MILLENMR1 tests look excellent, Quintam. :spoko:
jadburner 09.09.2024 21:04
Napisany przez Stingray (Post 1469717)
YES, but without OPC I received constantly lower LDC|BIS.
as about LG, recently I checked also a jitter and was surprised ASUS 16 FW3.11 on 4x has better jitter with CMCMAGBA5 than 2 my Pioneers at any speed
based on my table for CMCMAGBA5:
ASUS16 4x - Jitter avg 9,1%
Pio205 6x -10,1% (at lower speed jitter is higher for example for 2x -12,2%), but LDC|BIS are better at 2x
PioS12 2x - 9,6% (at higher speed jitter is higher)
Coopervid is correct. Jitter does not seem to affect the readability of a Blu-ray disc. This is also my conclusion after burning and testing several thousand Blu-ray discs. The far more relevant and useful tests are LDC/BIS and a read test (TRT).
Quintam 09.09.2024 19:47
Ilość załączników: 3
OPC = Yes
@ 4x
Załącznik 210414
Załącznik 210415
Załącznik 210416
Stingray 09.09.2024 18:41
Napisany przez Coopervid (Post 1469720)
I never noticed read failures based on jitter. Only based on LDC / BIS. We had some discussions about critical LDC / BIS values on a PM base in the other forum.
Yes I remember thank you.
I also found this recommendation:
https://i.postimg.cc/w3Mf0TdV/BIS.jpg
Coopervid 09.09.2024 17:52
Stingray 09.09.2024 15:10
Napisany przez Coopervid (Post 1469708)
Discs w/o layer break (25GB) are usually a no brainer for any BD drive. Even using a LG drive.
Coopervid 09.09.2024 00:32
Napisany przez Stingray (Post 1469703)
I've recently recorded about 100 discs with this MID code on 2 Pioneers.
it seems for me OPC better to switch off and all quality options in Pioneer utility also off.
Stingray 08.09.2024 21:47
Quintam 06.09.2024 14:34
HP 6x BD-R
MID: CMCMAGBA5
OPC = Yes
@ 4x
https://forum.cdrinfo.pl/attachment....1&d=1725622166
https://forum.cdrinfo.pl/attachment....1&d=1725622252
https://forum.cdrinfo.pl/attachment....1&d=1725622425
misiozol 06.09.2024 13:11
No, fiu, fiu elegancka ;)
Quintam 06.09.2024 13:00
Ilość załączników: 10
Załącznik 210313
Załącznik 210314
Załącznik 210315
Załącznik 210316
Załącznik 210317
Załącznik 210318
Załącznik 210319
Załącznik 210320
Załącznik 210321
Załącznik 210322
czary2mary 03.04.2022 08:43
Pioneer BDR-X13J-S fw.1.01
https://www.cdrinfo.pl/bios/22093072948
Wszystkie czasy w strefie CET. Aktualna godzina: 20:55.
