Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD Tematy poświęcone nagrywarkom i nagrywaniu płyt Blu-ray, HD DVD |
Data rejestracji: 21.07.2023
Vinpower WH16NS58 1.V8 does not support disc quality check??!!!! Please help!
Hello everyone,
I bought a new burning drive: "Vinpower WH16NS58" and found i fout that it does not support measuring the quality of BD-R, DVD amd CD media! According to the reviews on this forum, it was said that this drive has modified firmware from the company: "Vinpower Digital", which can measure the quality of burned BD-R media (LDC/BIS). The burn drive was purchased at: "https://labelprinter.pl/". The drive came in a "bulk" version without the Plextools software, so I can't measure media quality in any software. Where can the problem be? Thank you... ![]() ![]() ![]() ![]() |
Contact your dealer or Vinpower support. They have already had mistakes with the uploaded firmware.
Also ask about PlexTools - they send it to your e-mail address for those who bought it and did not receive it on a CD. The series with firmware 1.V5 tests discquality. |
Data rejestracji: 12.02.2024
Hello,
I have solved this problem for a long time with the technical support of Vinpowerdigital.com, where I was told that the "58D and version robot" models can measure the quality (disc quality check), so I ordered the model: "robot" for more money and I received an identical model from: "labelprinter.pl", which also cannot measure the quality of burned media. I returned both models back to: "Labelprinter.pl" and I am currently waiting for a refund. I do not know if it was a mistake on the side of the labelprinter.pl or directly to the vigpowerdigital.com, but on the following models: "DUP versions" cannot measure the quality of burned media in any programs. I tested the firmware upgrade to version 1. V9 and downgrade on version 1. V5. Interestingly, the second unit purchased had the same identification labels, but different firmware: Drive no.1: "WH16NS58 1V8" Firmware. Drive no. 2: (Reportedly Robot version): "WH16NS58 TSTK Firmware. Pics (Comparison of drives): https://postimg.cc/DmrtH0V0 https://postimg.cc/1fVBk4Fs ![]() ![]() I am currently staying at my recently purchased new drive: Liteon IHBS 212 changed to Plexor PX-LB950SA (CrossFlash). |
Good night.
thanks for the info, was just thinking of buying one on amazon for $74. Maybe your computer's SATA controller is interfering? Just a guess. By the way, where did you get the 1.v9 FW? Maybe you came across a description of what they changed in their firmware after 1.v5? |
#6 | |
Question no. 1:
It's not by the SATA controller. I tried to connect the drive also via an external USB box: "OWC Mercury Pro": https://www.owc.com/solutions/mercury-pro-optical I was also thinking about buying from Amazon.com People in the discussion for this product write that this drive supports quality measurement. Link Amazon product: Digital LG HLDS WH16NS58DUP If you would ask Vinpower Digital directly via Amazon.com about this function with a link on this forum and this problem, maybe you will be succeed. Then I would definitely buy this drive from Amazon.com as well. Question no. 2: Firmware 1.V9 I received from technical support: VINPOWER Digital (Germany's Office). Question no. 3: I did not receive a list of changes, but if you request it, they will surely give it to you. I have this firmware available. Cytat:
Data rejestracji: 16.08.2023
if you can upload a fw updater to 1.v9 or a valid dump in .bin format please upload it. vinpower stop publish updates for this drive
#8 | |
PIC: SDFtool Flasher (Downgrade to firmware v 1.5 non encrypted) demonstration. ![]() Download link (EXE Update Firmware): https://bestfile.io/hcgxv2UVijJ1FMp/file Note: If anyone can give information where to buy this drive with Disc Quality Scan function, I would be grateful. Thank you... ![]() |
#9 | |
it seems strange official Vinpower device does not support quality scan , but crossflashed LG/ASUS -> vinpower v1.v5 support |
ive crosflased my drive with wh16ns60 firmware to makemkv 1.v5 via SDFtool Flasher then using the 1.v9 updater.exe and upgrade my drive. but now it doesnt read any media. reflashing back to wh16ns60 didnt help. any ideas??
#11 | |
I had similar issue with 1.v5, but flashed another 1.v5 (MK) and drive became read, write and scan |
#12 |
no its a brick now dosnt recognise any media
#13 |
All solved!
![]() I ordered before Christmas the drive on Amazon.com and that can measure the quality of burned media. !!! ![]() I asked the seller on Amazon.com several times and was told that the drive has this feature. Note: Otherwise, as far as the label and inscription: "Support Quality Scan" are concerned, this is a designation only for the European market. The American label on the drive does not have this marking, but the drive have this function (quality measurement). You will get 5x BD-R disc (Plexdisc 25 GB) and 1x CD-R with PlexTools software with the drive. Note: BD-R and CD-R (without plastic cover see, photos below), the covers is mine. ![]() Link to purchase: LG HLDS WH16NS58DUP 16X Blu-ray - Amazon.com Pictures: ![]() ![]() ![]() Panasonic BD-RE 2x (Quality Scan). ![]() I wish everyone who is interested in buying this drive a pleasant and trouble-free purchase. ![]() |
#14 |
I also bought Vinpower WH16NS58 DUP 1.v9 made 08.2022 it's a bit used from Japan. I already have crossflashed ASUS drives with FW 1.v5, 1.v7 and now I bought a factory version 1.v9 version.
Strange but original 1.v9 it seems is not working with VPtools, but does quality scan in Opti Drive Control ![]() My drive also has "Support Quality Scan" on a sticker Ostatnio zmieniany przez Stingray : 25.04.2025 o godz. 18:30 |
#15 |
I found a solution - Vptools works via SATA directly
MakeMKV info: Drive Information Manufacturer: HL-DT-ST Product: BD-RE WH16NS58 Revision: 1.V9 Serial number: KL....... Firmware date: 2122-03-30 14:54 Bus encryption flags: 17 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 Ostatnio zmieniany przez Stingray : 25.04.2025 o godz. 23:40 |
Tagi |
1.v8, check, disc, quality, support, vinpower, wh16ns58 |
