| Zabezpieczenia CD/DVD/Blu-ray Forum związane z tematem zabezpieczania płyt i ich odbezpieczania :) Nie dotyczy zabezpieczeń filmów DVD (dział DVD Video). |
#556 |
DVDFab 12.1.1.0 + AnyDVD 8.6.5.0
DVDFab 12.1.1.0
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.0 Changelog New: Added support for some new Java protections. Fix: A failure problem when starting up DVDFab Mini. AnyDVD 8.6.5.0 https://download.redfox.bz/download/SetupAnyDVD8650.exe Changelog AnyDVD 8.6.5.0 2023-07-12 New (Blu-ray): Support for new discs New (UHD): Added keydb.cfg import Fix (Blu-ray): Crash with some discs |
#557 |
DVDFab 12.1.1.1 + DVDFab Passkey 9.4.6.1 + AnyDVD 8.6.5.3 Beta
DVDFab 12.1.1.1
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.1 Changelog New: Added support for some new Java protections. DVDFab Passkey 9.4.6.1 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.1 Changelog New: Added the support for some new Java protections. AnyDVD 8.6.5.3 Beta https://download.redfox.bz/download/...AnyDVD8653.exe Changelog AnyDVD 8.6.5.3 2023-07-24 - New (Blu-ray): Support for new discs - New (Blu-ray): Workaround for authoring error on "CASE IS CLOSED FORGET IT V2" (UK) |
#558 |
AnyDVD 8.6.5.4 Beta
https://download.redfox.bz/download/...AnyDVD8654.exe
Changelog AnyDVD 8.6.5.4 2023-07-26 - New (Blu-ray): Support for new discs - New (Blu-ray): Workaround for authoring error on "CASE IS CLOSED FORGET IT V2" (UK) - Fix (UHD): Incorrect keydb filename setting |
#559 |
DVDFab 12.1.1.3 + DVDFab Passkey 9.4.6.2
DVDFab 12.1.1.3
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.3 Changelog New: Added support for some new Java protections. DVDFab Passkey 9.4.6.2 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.2 Changelog New: Added the support for some new Java protections. |
#560 |
DVDFab 12.1.1.4 + AnyDVD 8.6.6.0
DVDFab 12.1.1.4
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.4 Changelog New: Added support for some new Java protections. AnyDVD 8.6.6.0 https://download.redfox.bz/download/SetupAnyDVD8660.exe Changelog AnyDVD 8.6.6.0 2023-08-24 New (Blu-ray): Support for new discs New (Blu-ray): Workaround for authoring error on "CASE IS CLOSED FORGET IT V2" (UK) Fix (UHD): Incorrect keydb filename setting |
#561 |
DVDFab 12.1.1.5 + AnyDVD 8.6.6.1 Beta
DVDFab 12.1.1.5
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.5 Changelog New: Added support for some new Java protections. AnyDVD 8.6.6.1 Beta https://download.redfox.bz/download/...AnyDVD8661.exe Changelog AnyDVD 8.6.6.1 2023-09-05 - New (Blu-ray): Support for new discs - New (UHD): Improved key search in keydb.cfg |
#562 |
DVDFab Passkey 9.4.6.3 + AnyDVD 8.6.6.2 Beta
Passkey 9.4.6.3 Changelog New: Added the support for some new Java protections. AnyDVD 8.6.6.2 Beta 8.6.6.2 2023-09-25 - New (Blu-ray): Support for new discs - New (UHD): Improved key search in keydb.cfg - New (UHD): Added option to disable / modify key search method in keydb.cfg - Fix (UHD): Incorrect keydb filename setting, 2nd try |
#563 |
AdvancedNet.pl - hosting
Data rejestracji: 12.04.2005
Leawo Prof. Media 13
![]() Kompleksowy zestaw narzędzi do konwertowania multimediów zapewnia wiele rozwiązań w zakresie filmów do 4K, DVD, Blu-ray, 4K Blu-ray, plików audio i zdjęć, z zadziwiającymi dodatkowymi funkcjami. - Konwertuj wideo 4K/HD/SD, 4K Blu-ray/Blu-ray/DVD, audio dla różnych urządzeń i odtwarzaczy itp. - Nagrywaj wideo na zawartość DVD/Blu-ray/Blu-ray, korzystając z ponad 40 modeli menu płyty i gotowych szablonów. - Kopiuj filmy 4K Blu-ray/Blu-ray/DVD na komputer lub czystą płytę w trybie kopii zapasowej 1:1 lub zawierającej tylko filmy. - Z łatwością zamieniaj zdjęcia w pokaz slajdów lub nagrywaj zdjęcia na zawartość Blu-ray/Blu-ray/DVD 4K. - Twórz filmy 3D z maksymalnie 6 różnymi dostępnymi efektami 3D, edytuj menu płyty i efekty wideo. Ostatnio zmieniany przez chris996 : 30.10.2023 o godz. 21:51 |
#564 |
Tak troszkę z innej beczki, czy da się zgrać do pliku srt napisy z filmu blu-ray i jak to zrobić? Proszę o odpowiedź.
#565 |
DVDFab 13.0.0.3 + DVDFab Passkey 9.4.6.4 + AnyDVD 8.6.6.7 Beta
DVDFab 13.0.0.3
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.3 Changelog New: Added support to downgrade UHD drives with the UHD Drive Tool module. New: Added the DRM Removal for Apple module (available only to existing paid users). New: Added support to use DVDFab 13 offline for 30 days after online authorization. Fix: Some minor issues when downgrading Buffalo UHD drives with the UHD Drive Tool. Fix: A crash problem in certain cases. Fix: Some known GUI display issues. DVDFab Passkey 9.4.6.4 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.4 Changelog New: Added the support for some new Java protections. AnyDVD 8.6.6.7 Beta https://download.redfox.bz/download/...AnyDVD8667.exe Changelog AnyDVD 8.6.6.7 2023-10-30 - New (Blu-ray): Support for new discs - New (Blu-ray): Try to avoid using LibreDrive with non-UHD discs - New (Blu-ray & UHD): Check, if bus decryption was successful - New (Blu-ray & UHD): Check, if protected disc / iso is corrupt - New (UHD): Improved key search in keydb.cfg - New (UHD): Added option to disable / modify key search method in keydb.cfg - Fix (UHD): Incorrect keydb filename setting, 2nd try - Some minor fixes and improvements |
#566 |
DVDFab 13.0.0.5 + DVDFab Passkey 9.4.6.5 + AnyDVD 8.6.7.0 /8.6.7.2 Beta
DVDFab 13.0.0.5
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.5 Changelog Fix: A problem that the duration of the output file and the duration displayed at the main interface are not correct after using the Trim feature in the Ripper modules. Fix: A problem that the titles of certain video files are messed up after being loaded into the software. Fix: A problem that the software exited abruptly when converting certain videos in the DVD Creator module. Fix: A problem that the aspect ratio of the output DVDs from the DVD Creator module is not correct. Fix: A problem that the custom thumbnail in the menu of the Blu-ray Creator module cannot be saved. Fix: A problem that the failed tasks in the DVD to Blu-ray Converter module cannot be restarted from the Processing queue. Fix: Some known GUI display issues. DVDFab Passkey 9.4.6.5 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.5 Changelog New: Added the support for some new Java protections. AnyDVD 8.6.7.0 https://download.redfox.bz/download/SetupAnyDVD8670.exe Changelog AnyDVD 8.6.7.0 2023-11-14 New: Workaround for "VSO Downloader 6" destroying Windows' wininet settings, causing some programs using wininet (like AnyDVD) to stop working. New (Blu-ray): Support for new discs New (Blu-ray): Added debug registry value to disable removal of structural protections New (Blu-ray): Try to avoid using LibreDrive with non-UHD discs New (Blu-ray & UHD): Check, if bus decryption was successful New (Blu-ray & UHD): Check, if protected disc / iso is corrupt New (UHD): Improved key search in keydb.cfg New (UHD): Added option to disable / modify key search method in keydb.cfg Fix (UHD): Incorrect keydb filename setting, 2nd try Some minor fixes and improvements AnyDVD beta 8.6.7.2 https://download.redfox.bz/download/...AnyDVD8672.exe Changelog AnyDVD 8.6.7.2 2023-11-19 - New (Blu-ray): Support for new discs - New (Blu-ray & UHD): Improved MakeMKV "Libre Drive" integration - New (Blu-ray & UHD): Check, if bus encryption is present - Updated French language |
#567 |
DVDFab 13.0.0.6
DVDFab 13.0.0.6 Changelog New: Added support to access system fonts when adding external subtitles and watermarks. New: Added support to choose 16:9 or 4:3 aspect ratio when creating DVDs in the DVD Creator module. Fix: A problem that the modified width of the source information column after opening the source is not remembered upon next startup. Fix: A GUI display problem on BDFix feature in certain cases. Fix: Some other GUI display issues. |
#568 |
DVDFab 13.0.0.8 + AnyDVD 8.6.7.3 Beta
DVDFab 13.0.0.8
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.8 Changelog New: Added support to authorize DVDFab 13 with Google accounts. Fix: A problem that a DVD-9 disc is required despite selecting DVD-5 when burning to DVD discs in the DVD Creator module. Fix: A problem that the system taskbar is disabled if DVDFab 13 interface is maximized. Fix: Some other GUI display issues. AnyDVD 8.6.7.3 Beta https://download.redfox.bz/download/...AnyDVD8673.exe Changelog AnyDVD 8.6.7.3 2023-12-13 - New (Blu-ray): Support for new discs - New (Blu-ray & UHD): Improved MakeMKV "Libre Drive" integration - New (Blu-ray & UHD): Check, if bus encryption is present - Fix (UHD): AACS 2.1 detection was broken in previous beta - Debug (Blu-Ray): Added "UseLibreDriveNonUHD" registry value. Set to 1 to force LibreDrive use for standard Blu-Ray discs. Default is off (0) - Debug (UHD): Added "RemoveUHDRegion" registry value. Set to 1 to enable region code processing for UHD. Default is off (0) - Updated French language |
#569 |
DVDFab 13.0.1.1 + DVDFab Passkey 9.4.6.7 + AnyDVD Beta 8.6.8.3
DVDFab 13.0.1.1
https://www.dvdfab.cn/download.htm DVDFab 13.0.1.1 changelog: New: Added support for some new Java protections. Fix: A problem that the burning process is slow. Fix: A failure problem when dealing with special paths (such as Japanese usernames or Japanese paths) when using Creator. DVDFab Passkey 9.4.6.7 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.7 Changelog New: Added the support for some new Java protections. AnyDVD Beta 8.6.8.3 https://download.redfox.bz/download/...AnyDVD8683.exe Changelog AnyDVD 8.6.8.3 2024-01-21 - New (Blu-ray): Support for new discs - Fix (Blu-ray): Crash with some discs, e.g. "Sommer der Gaukler", Germany |
#570 |
DVDFab 13.0.1.2
DVDFab13 13.0.1.2 Changelog New: Added support for the new Streaming menu template in Blu-ray Creator. - Support searching Meta information automatically for movies or TV Shows. - Support setting the poster of the video as a Menu background automatically. - Including Root Menu, Scense, and Set Up pages, closer to the original disc menu. New: Added support for displaying the conversion progress on the DVDFab icon in the system taskbar when the task is processing. Fix: A problem that the tasks are not saved in the Archived section after the conversion is finished and the program is restarted. Fix: Some GUI display problems. |
| Tagi |
| blu-ray, kopia, kopiowanie, płyta, płyta blu-ray |
| nagrywanie płyt Bluray | macies | High Definition | 20 | 05.01.2017 09:45 |
| Problem z odczytem starszych płyt dvd+r - dziwny przypadek - ogromna prośba o pomoc.. | ivesher | Napędy optyczne DVD | 9 | 25.01.2011 12:12 |
| Jak zmusić 1633S do odczytu nagranych przez siebie płyt DVD-R? | MKJ | Napędy optyczne DVD | 12 | 20.03.2005 01:20 |
| Cześć.potrzebuje kopie EEPROMA do LiteONa 1633S . po przeróbce na 1653 nie czyta płyt | tom106 | Napędy optyczne DVD | 3 | 07.12.2004 08:40 |
| Szukam płyt poniżej 1 zł (kontaktu do producenta CD-R) | VVirOOs | Napędy optyczne CD | 15 | 20.03.2002 23:16 |
