Stary 19.03.2018, 16:56   #31
DeUHD Ultra HD Blu-ray 1.0.2.5
1.0.2.5 03/19/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
https://www.deuhd.ru/download.html
Stary 26.03.2018, 16:42   #32
DeUHD Ultra HD Blu-ray 1.0.2.6
1.0.2.6 03/26/2018
Removed two discs limitation for all users.
Stary 27.03.2018, 20:32   #33
Blokada DeUHD \ Windows KB4089848
Wyszła następna poprawka blokująca uruchomienie DeUHD (Windows KB4089848)
Stary 03.04.2018, 08:34   #34
DeUHD Ultra HD Blu-ray 1.0.2.7
1.0.2.7 04/02/2018
Stary 10.04.2018, 12:30   #35
DeUHD Ultra HD Blu-ray 1.0.2.8
1.0.2.8 04/09/2018
Stary 21.05.2018, 18:38   #36
DeUHD Ultra HD Blu-ray 1.0.2.9
1.0.2.9 05/21/2018
To install the new version 1.0.2.9, you need to uninstall the old version and restart your computer first.
Fixed ***8216;Errors on DeUHD installation***8217; for Windows 10 user.
Largely increased ripping speed.
Fixed get disc info error.
Added German language.(Thanks for the contributor.)
Stary 11.06.2018, 15:15   #37
DeUHD Ultra HD Blu-ray 1.0.3.0
Lekarstwo na AACS 2.1
1.0.3.0 06/11/2018
Supported AACS 2.1. e.g. Fury. (To play the disc, need to Rip to ISO or hard disc with DeUHD 1.0.3.0, and will support to play it directly soon.)
Stary 19.06.2018, 15:34   #38
DeUHD Ultra HD Blu-ray 1.0.3.1
1.0.3.1 06/18/2018
Supported AACS 2.1 protected disc The Patriot. (To play the disc, need to Rip to ISO or hard disc with DeUHD 1.0.3.1, and will support to play it directly soon.)
Stary 03.07.2018, 18:19   #39
DeUHD Ultra HD Blu-ray 1.0.3.2
1.0.3.2 07/02/2018
Added "Install DeUHD drive" installation option. Unchecking this option will still enable you to rip disc to ISO especially for some Windows 10 users who have "Error Installation" before. If you choose unchecking this option, please uninstall the old version and reboot first
Stary 16.07.2018, 15:57   #40
DeUHD Ultra HD Blu-ray 1.0.3.3
1.0.3.3 07/16/2018
Applied new decryption method to speed up the process of opening new supported discs.
Solved the decryption problem for AACS 2.1 protected discs when rip to hard disk in no driver installation way.
Stary 15.08.2018, 06:18   #41
DeUHD Ultra HD Blu-ray 1.0.3.4
1.0.3.4 08/13/2018
AAdded preview feature to check decryption status.
Stary 22.08.2018, 05:53   #42
DeUHD Ultra HD Blu-ray 1.0.3.5
1.0.3.5 08/20/2018
Added support for AACS 2.1 Fury JP version. Please update to the latest version.
Fixed crash issue in last version.
Stary 07.11.2018, 06:17   #43
DeUHD Ultra HD Blu-ray 1.0.3.6
1.0.3.6 11/05/2018
https://www.deuhd.ru/download/DeUHD1036.exe
Ostatnio zmieniany przez czary2mary : 08.11.2018 o godz. 05:48 Powód: aktuallizacja
Stary 08.11.2018, 05:53   #44
DeUHD Ultra HD Blu-ray 1.0.3.7
1.0.3.7 11/12/2018
Fixed crash issue.
Ostatnio zmieniany przez czary2mary : 15.11.2018 o godz. 08:59
Stary 29.11.2018, 17:16   #45
DeUHD Ultra HD Blu-ray 1.0.3.8
1.0.3.8 11/28/2018
Ultra HD Blu-Ray czary2mary Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD 159 07.11.2026 10:16
Poradnik nagrywania plyt blu ray Domi731 Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD 433 16.04.2015 14:21
problem z nagraniem filmu hd na blu ray aarko1 Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD 2 02.03.2011 23:20
Wszystkie czasy w strefie CET. Aktualna godzina: 02:57.
