-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DVDFab 11 (https://forum.cdrinfo.pl/f11/dvdfab-11-a-97553/)
czary2mary 30.04.2019 07:16
DVDFab 11.0.2.8
https://www.dvdfab.cn/download.htm
New: Added the support for some new Java protections.
New: Added the support to a new copy protection found on the DVD version of The Dictator.
New: Added the support for the BS4K & CS4K (4K BDAV) contents recorded by Sharp devices in the Clone mode of the UHD Copy module.
Fix: An estimation error problem on the output file size if the Same as Source option is selected at the Advanced Settings panel of the Creator module.
czary2mary 27.04.2019 09:25
DVDFab 11.0.2.7
New: Added the APE audio conversion profile in the Ripper and Converter modules.
New: Improved the compatibility on non-standard Blu-rays.
New: Improved the Video Downloader utility tool.
Fix: A failure problem when converting certain files with Passthrough processing mode in the UHD Creator module.
Fix: An output file oversize problem in the Blu-ray Ripper module.
czary2mary 20.04.2019 09:47
DVDFab 11.0.2.6
New: Added the new conversion profile for Huawei P30 smart phone in the Ripper and Converter modules.
New: Added some new audio conversion profiles in the Ripper and Converter modules.
New: Introduced the new feature to convert an audio file from one format to another in the Converter module.
New: Introduced the free versions of the DVD Copy, DVD Ripper, Blu-ray Copy and Blu-ray Ripper modules.
New: Some minor improvements on GUI and UE.
Fix: A problem that the UHD Ripper module cannot select conversion profiles in certain cases.
czary2mary 19.04.2019 09:27
DVDFab 11.0.2.5
czary2mary 14.04.2019 08:42
DVDFab 11.0.2.4
New: Added the support to remove the Cinavia watermark as found on the US version of 4K Ultra HD Blu-ray Resident Evil: The Final Chapter (2016).
New: Added the new conversion profiles for some major Huawei smart phones including the Mate X/20/10 series, P20 series, Nova series and more in the Ripper and Converter modules.
New: Added the support to delete the finished tasks without the need of a program restart.
Fix: A crash problem when clearing history in certain cases.
czary2mary 29.03.2019 02:17
DVDFab 11.0.2.2
DVDFab 11.0.2.2
New: Added the auto crop feature to the Video Converter module.
Fix: A freeze problem if the Audio Copy option is selected when converting 3D Blu-rays with 3D.MKV.MVC profile.
Fix: A problem that two empty video folders are created in the output directory if 2 separate files 3D format is selected when converting 2D 4K videos to 3D 4K videos in the Video Converter module.
Fix: A problem that conversion fails immediately upon startup under 2-pass encoding method in the Video Converter module.
Fix: A crash problem upon the finish of a single conversion task if there are multiple tasks in the queue in the Video Converter module.
Fix: Improved the user experience of the YouTube to MP3 utility.
Fix: Some minor GUI improvements.
czary2mary 23.03.2019 10:40
DVDFab 11.0.2.1
New: Added the support for more DVDs and Blu-rays in the free HD Decrypter.
New: Added the support to remove the Cinavia watermark found on the Blu-ray version of Don***8217;t Be Afraid of the Dark.
Fix: A problem that the Sakura skin cannot be applied.
Fix: A problem that the current conversion will fail if a new source is loaded and the Video Edit panel is opened while that conversion is in progress.
czary2mary 22.03.2019 14:33
DVDFab 11.0.2.0
DVDFab 11.0.2.0
New: Added the support to remove the Cinavia watermark found on the DVD version of Trainwreck (2015) and American Ultra (2015).
New: Added the option to retain the HDR 10 contents in certain profiles of the Converter module.
New: Added the conversion profiles for the Samsung Galaxy S10/S10 Plus in the Converter and Ripper modules.
New: Introduced the newly designed sakura skin.
Fix: A problem that using command lines to exit DVDFab does not work properly.
Fix: A conversion failure problem if AC-3/5.1 audio track is selected when ripping the 4K UHD version of Rampage with MKV Passthrough profile.
Fix: A problem that the DTS-HD Master audio does not play back correctly after the Cinavia watermark is removed from the Blu-ray version of La La Land.
Fix: A problem that the Video Converter module does not display the correct runtime for certain TS videos.
Fix: An incomplete conversion problem in the DVD Ripper module.
Fix: A problem that the backup discs of the recorded Korean BDAV discs with multiple titles cannot play back in order.
Fix: A conversion failure problem of the Japanese adult DVDs in the Ripper module.
czary2mary 15.03.2019 08:45
DVDFab 11.0.1.9
DVDFab 11.0.1.9
New: Added the support to remove the Cinavia watermark found on the DVD version of Burlesque and Unfriended.
Fix: A failure problem when opening certain video files.
Fix: A problem that the other display languages except English are missing from YouTube to MP3.
Fix: Some minor UI display issues.
czary2mary 07.03.2019 08:37
DVDFab 11.0.1.8
New: Added the support for some new Japanese adult DVDs.
Fix: A problem that the subtitles of the UHD Ripper converted videos are improperly positioned.
Fix: A playback repetition problem of the Hi-Fi Audio Converter produced audio files if Split by Chapter is enabled when converting with the Flac Stereo profile.
Fix: A crash problem if the Copy Audio option is enabled at the Advanced Settings panel when converting DVDs containing 3.1 audio tracks.
Fix: A crash problem when converting certain AVI videos with the MKV.Passthrough profile.
czary2mary 25.02.2019 12:13
DVDFab 11.0.1.7
New: Added the support to remove the Cinavia watermark as found on the Blu-ray version of Take Shelter.
New: Added the PCM codec support to the MKV profile in the Ripper and Converter modules.
New: Added the support to subscribe and automatically download the updated music in YouTube to MP3 utility.
More Info: https://www.dvdfab.cn/faq/?type=youtube_to_mp3#faq_1
New: Added the support to set the output audio quality as 320/256/192/128/96 kbps in YouTube to MP3 utility.
czary2mary 20.02.2019 11:05
DVDFab 11.0.1.6
Fix: A problem that the source switcher is toggled off after loading the 2nd disc when handling multiple discs.
Fix: A subtitles previewing problem on certain Blu-rays.
Fix: A problem the merge feature in the Video Converter can only process two sources.
Fix: A problem that DVD to Blu-ray Converter can only burn to one disc even the number of copies is set as 2.
Fix: Some minor changes and improvements on the UHD Drive Tool utility.
Fix: Some minor GUI changes and improvements.
czary2mary 26.01.2019 09:15
DVDFab 11.0.1.5
New: Added the support to remove the Cinavia watermark found on the Blu-ray version of Lockout (2012).
New: Added the support to retain the playlist information when converting BDAV discs in the Ripper module.
New: Added the BD100 1080p and BD66 1080p output support to the UHD to Blu-ray Converter module (only x64 version).
New: Introduced the UHD Drive Tool utility to downgrade the backup-unfriendly firmware on a UHD Drive.
More Info: https://www.dvdfab.cn/uhd-drive-tool.htm
New: Added the Passkey driver support at the Common Settings > Drives > Read > IO Mode (only x86 version).
New: Improved the module icons at the top tab bar.
Fix: A failure problem when opening certain DVDFab ripped DVD & Blu-ray folders released by Disney (USA) in the Ripper module.
Fix: A failure problem when converting certain DVDs to WAV audios in the Ripper module.
Fix: A failure problem when opening certain video files in the Video Converter module.
Fix: A problem that the Saturation setting at the Video Edit panel of the Video Converter module does not work.
Fix: A problem that the timestamp of the playback progress bar is not correct if rendering subtitles when converting certain MKV videos in the Video Converter module.
Fix: A failure problem when converting the VOB files directly from certain DVD folders in the Video Converter module.
Fix: A problem that the video files with runtime less than 1s can be loaded to the Video Converter module but fail to convert.
Fix: A failure problem when analyzing certain URLs in the YouTube to MP3 utility.
czary2mary 10.01.2019 18:48
DVDFab 11.0.1.4
New: Introduced the brand-new non-linear video editing feature in the Video Converter module.
Fix: A crash problem when deleting previously saved custom profiles in the Ripper module.
Fix: A noise problem when playing back the resulting videos produced by the Video Converter module.
Fix: An audio ***** and distortion problem if the DTS tracks in the source videos are converted to AAC or AC3 by the Video Converter module.
Fix: A problem that the CRF encoding method does not work properly if VP9 is selected at the Advanced Settings > Video > Codec of the Video Converter module.
Fix: A problem that the file title is cut short after being handled by the DRM Removal module.
czary2mary 02.01.2019 19:58
DVDFab 11.0.1.1
New: Added the support for the 4K Ultra HD Blu-rays containing HDR10+ contents in the UHD Copy module.
New: Added the support for the 4K Ultra HD Blu-rays containing HDR10+ contents in the BDInfo tool.
Fix: A crash problem when converting iTunes movies with MKV Passthrough profile in certain cases.
Fix: A failure problem when converting MKV videos with Tivo profile.
Wszystkie czasy w strefie CET. Aktualna godzina: 06:55.
