-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DVDFab 11 (https://forum.cdrinfo.pl/f11/dvdfab-11-a-97553/)
czary2mary 26.12.2018 12:52
DVDFab 11.0.1.0
DVDFab 11.0.1.0
New: Added the support for some new Java protections.
Fix: An opening failure problem on the bus encrypted Blu-ray discs.
Fix: A wrong color space problem when converting with profile MKV.4K.H265.12bit.
https://www.dvdfab.cn/download.htm
czary2mary 22.12.2018 14:04
DVDFab 11.0.0.9
DVDFab 11.0.0.9
New: Introduced the Cloud Decryption Service 3.0 to improve the decryption speed on Blu-rays.
New: Added the MP4 Passthrough and MP4.4K.H365.10bit conversion profiles to the UHD Ripper module.
Fix: A problem that the number of copies behind the output destination box is missing under the Clone mode of the Copy module.
Fix: A problem that File Transfer does not launch up after the conversion finishes when outputting to mobile devices.
Fix: Some minor UI display issues.
czary2mary 14.12.2018 07:02
DVDFab 11.0.0.8
New: Added the support to choose how to display task queue at Common Settings > General.
New: Added the Copy Video option to MP4/MKV relevant conversion profiles at the Advanced Settings panel of Video Converter module.
Fix: A problem that the output size at the main interface is not remembered next time upon restart.
Fix: A problem that the created DVDs deliver no sound if the source videos contain 7.1 multi-channel audios.
czary2mary 02.12.2018 12:08
DVDFab 11.0.0.7
New: Added the support for some new protections as found on certain DVDs produced by PBS.
New: Added the 12Bit support to certain MP4/MKV relevant conversion profiles in Ripper and Converter modules.
New: Added the support to preset output size at the Main Interface of Ripper and Converter modules.
Fix: A problem that the movie titles of certain Japanese discs are not displayed.
Fix: A problem that the edited title names in Ripper module are reverted if switching to Copy module and then switch back.
Fix: A conversion failure problem with MP4.passthrough profile in Video Converter module.
Fix: A conversion failure problem with certain AVI videos in DVD Creator module.
Fix: A conversion freeze problem with certain videos in DVD Creator module if external subtitles are added.
Fix: Improved the UI display under high DPI settings.
czary2mary 23.11.2018 05:11
DVDFab 11.0.0.5
New: Added the conversion profiles for Samsung Galaxy Tab S4, iPad Pro, Nokia 8/7.1/6.1/5/3.1/2 and Google Pixel 3/3 XL/2/2 XL in the Ripper and Converter modules.
New: Added the Deinterlacing Method option at Common Settings > Conversion > Convert.
Fix: A problem that the subtitles are placed at the top of the video screen after conversion.
Fix: A conversion failure problem when authoring DVDs from certain AVI videos.
Fix: Improved the File Transfer and the way to display the task queue.
Fix: Improved some UI display issues.
czary2mary 16.11.2018 07:32
DVDFab 11.0.0.4
New: Improved the UI display.
New: Added back the skin of Light of Hope.
New: Added the support to customize the way to display dialog/message boxes at Common Settings > General.
New: Added the DTS codec support to MP4 relevant profiles at the Audio section of Ripper and Video Converter modules.
Fix: An output oversize problem when shrinking certain Blu-rays to DVD5 size.
Fix: A noisy problem when playing back the MP4 videos converted by the Blu-ray Ripper module.
Fix: A problem that a 00099.m2ts file is created even No Menu option is selected while authoring Blu-rays.
Fix: A conversion failure problem when 2-pass encoding method is selected in the Video Converter module.
czary2mary 02.11.2018 09:38
DVDFab 11.0.0.2
New: Added the support to remove the Cinavia watermarks found on the following discs: Men In Black 3 (BD version) and Salt (BD version).
New: Added the support to display the detailed codec information for hardware accelerations.
New: Added the conversion profiles for iPhone XS, iPhone XS Max and iPhone XR in Ripper and Video Converter modules.
New: Improved the user experience of the File Transfer utility tool.
New: Improved the user experience of the DVDFab Remote utility tool.
New: Improved the Task Queue Manager when processing multiple tasks.
New: Improved some UI display problems.
Fix: A problem that Intel HD Graphics hardware acceleration cannot be enabled on NUC8i7HNK.
Fix: A problem that the desktop shortcut icon is created by default when updating via the Live Update feature.
Fix: A problem that user interface displays abnormally if switching the DPI setting to 150% or 175%.
Fix: A problem that the module user selected is not remembered upon next startup.
Fix: A problem that the Pattern value cannot be saved at Common Settings -> Conversion -> Output -> File Source.
Fix: A problem that DVDFab cannot burn to rewritable blank medium.
Fix: A problem that the ISO file creation process is not displayed when copying DVD and Blu-ray discs to ISO files.
Fix: A problem that certain Blu-rays are missing the DTS-HD MA 5.1 audios after being copied by the Blu-ray Copy module.
Fix: A problem that switching output path requires a program restart to take effect.
Fix: A problem that the videos converted from certain TS and WMV videos cannot playback.
Fix: A problem that the edited title name of previous season switches back after loading another season of the same TV show in Ripper modules.
Fix: A problem that the videos converted by the Video Converter module are missing the chapter markers.
Fix: A problem that the MKV 4K 10bit profile in the Video Converter module cannot passthrough Dolby Atmos audios.
Fix: A problem that the SRT subtitles are positioned at the top part of the screen after being converted by Video Converter module.
Fix: A problem that the Video Converter module produces incorrect file extensions in certain cases.
Fix: A problem that the function icons in the Menu templates of the Creator modules are missing.
Fix: A problem that changing names for Scenes in the Blu-ray Creator does not work.
Fix: A problem that the Blu-ray Creator created videos do not contain any subtitles if users add external subtitles or the source already contains internal subtitles.
czary2mary 28.10.2018 03:13
DVDFab 11.0.0.1
DVDFab 11.0.0.1
A quick glance of the new features in DVDFab 11:
All-new flat design, brand-new user interface, plain and simple;
Redesigned prompt dialog floating in from the bottom of main interface;
Integrated the Task Queue Manager to the main interface;
Introduced the YouTube Uploader in Ripper and Converter modules, which allows users to upload the resulting videos directly to YouTube channel. Note: Please make sure your YouTube channel works normally and you've verified your account (if you want to upload videos longer than 15 mins) in YouTube before uploading the video.
Introduced the Mobile Video Loader to transfer videos from smartphones or tablets directly to DVDFab 11; improved the File Transfer to transfer the edited videos directly back to smartphones or tablets, WITHOUT THE DATA CABLE ANYMORE. Note: DVDFab Remote 1.2.3 is required on your smartphone or tablet, which is available in iOS App Store and Google Play.
Introduced the redesigned Video Edit feature in Ripper and Converter modules.
Introduced the all-new Turbo Conversion Engine that supports the latest HW acceleration technologies from NVIDIA, AMD and Intel.
Added the support for some new Japanese adult DVDs.
Added the support to remove the Cinavia watermarks found on the following discs: Hotel Transylvania 2 (BD version), The Shack (2017 BD version), The Equalizer (2014 BD version) and Jason Bourne (4K UHD version).
Added the DTS codec support to the MKV/M2TS relevant profiles at the Audio section of the Advanced Settings panel.
Added the VP9/VP8 codec support to the MKV relevant profiles at the Video section of the Advanced Settings panel of Ripper and Converter modules.
Added the OPUS codec support to the MKV relevant profiles at the Audio section of the Advanced Settings panel of Ripper and Converter modules.
Fixed a low speed problem when outputting ISO files to NAS devices.
Fixed a problem that not all the user selected audio tracks are retained in the final results created by Blu-ray and UHD Creator modules.
x32
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB11
x64
czary2mary 19.10.2018 06:21
DVDFab 11
Producent DVDFab.\Fengtao Software Inc. przedstawił pierwszą wersję Beta najnowszej edycji DVDFab 11 :)
Introduced the Mobile Video Loader to transfer videos from smartphones or tablets directly to DVDFab 11; improved the File Transfer to transfer the edited videos directly back to smartphones or tablets, WITHOUT THE DATA CABLE ANYMORE. Note: DVDFab Remote 1.2.2 is required on your smartphone or tablet, which is available in iOS App Store and Google Play.
Some more improvements and changes.
Online Instalator (~3MB) :
http://download.dvdfab.cn/setup/DVDF...Downloader.exe
Pełny instalator exe.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB11_x64
Wszystkie czasy w strefie CET. Aktualna godzina: 02:22.
