Stary 03.07.2020, 06:55   #91
DVDFab 11.0.9.5
https://www.dvdfab.cn/download.htm
DVDFab 11.0.9.5 Changelog
New: Added the support to upscale videos with Enlarger AI on PCs installed with the 10th generation Intel i9 CPUs.
New: Added the support to automatically switch to CPU to convert again in case the conversion with hardware acceleration fails.
Fix: A problem that the movie name in the Video Converter module is not updated after applying the metadata to the loaded source using the Search Movie/TV feature.
Fix: A conversion failure problem in the Video Converter module in certain cases.
Stary 05.07.2020, 08:53   #92
DVDFab 11.0.9.6
DVDFab 11.0.9.6 Changelog
Fix: A crash problem when opening sources in certain cases.
Stary 12.07.2020, 11:04   #93
DVDFab 11.0.9.7
DVDFab 11.0.9.7 Changelog
New: Added two new Enlarger AI training models Deblock and Ultra+Deblock in Ripper, Video Converter and DVD to Blu-ray Converter modules.
New: Added the feature to preset AI profiles in Ripper modules at Common Settings > Profiles > Set Profiles for Enlarger AI.
New: Improved the support for the profile preset feature. DVDFab may ask you to reset it again if you used to set profiles in ver. 11.0.9.2 or older.
New: Renamed the default output name for TV Shows from s0xe0x to S0xE0x.
Fix: A problem that html appears in the Task Queue Log viewer.
Fix: Some minor translation problems.
Stary 20.07.2020, 15:51   #94
DVDFab 11.0.9.9
DVDFab 11.0.9.9 Changelog
Fix: A conversion failure problem when upscaling videos with Enlarger AI in the Video Converter module in certain cases.
Fix: A conversion failure problem when converting DVDs using software decoding in certain cases.
Stary 31.07.2020, 07:29   #95
DVDFab 11.1.0.0
DVDFab 11.1.0.0
DVDFab 11.1.0.0 Changelog
New: Added the support for some new Java protections.
New: Added the support to preset conversion profiles for Enlarger AI and Video Converter modules.
New: Improved the feature not to remember the setting of shut down computer upon task completion.
Ostatnio zmieniany przez czary2mary : 17.08.2020 o godz. 18:35
Stary 17.08.2020, 18:35   #96
DVDFab 11.1.0.3
New: Added the support to preview Enlarger AI upscaling results before conversion starts in the Video Converter module. (Ripper and DVD to Blu-ray Converter modules will be supported next).
New: Improved the support for opening Blu-ray and 4K Ultra HD Blu-ray discs.
Fix: A failure problem when opening certain H.265 encoded MKV videos in the Video Converter module.
Fix: A crash problem when copying/converting DVD or Blu-ray discs in certain cases.
Stary 23.08.2020, 08:41   #97
DVDFab 11.1.0.4
DVDFab 11.1.0.4
DVDFab 11.1.0.4 Changelog
Fix: A crash problem when opening certain DVDs.
Stary 27.08.2020, 15:12   #98
DVDFab 11.1.0.5
DVDFab 11.1.0.5 Changelog
New: Added the support to preview Enlarger AI upscaling results before conversion starts in the Ripper and DVD to Blu-ray Converter modules.
Fix: A problem that the title information of the converted files by the Ripper and Video Converter modules is still retained despite the Metainfo feature being disabled.
Fix: A problem that DVDFab switched to the Copy module after restarting from the Ripper module.
Stary 11.09.2020, 08:00   #99
DVDFab 11.1.0.6
DVDFab 11.1.0.6 Changelog
New: Added the support to use Enlarger AI relevant features on computers installed with AMD graphics card.
Fix: A problem the backup disc made by the DVD to Blu-ray Converter module plays incorrect title under the menu playback mode.
Fix: A problem that the output MP4 videos converted by the Ripper modules contain English audio track even Spanish is selected.
Fix: A problem that the Video Converter module cannot identify the HDR10 videos.
Fix: A problem that DVDFab takes too much of CPU power when reading discs.
LiteOn iHBS 112/212/312 slawekj Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD 1266 07.11.2024 15:10
DVDFab: kopia 1:1 czarny ekran na odtwarzaczu stacjonarnym negatyw001 Zabezpieczenia CD/DVD/Blu-ray 30 04.05.2023 08:08
Nero 11 chris996 Nero 1 06.02.2013 15:06
Dyskowy problem. SIWYYY Komputery - oprogramowanie i sprzęt 0 14.05.2009 13:50
9 11 Air Off topic 18 07.07.2004 00:38
Wszystkie czasy w strefie CET. Aktualna godzina: 02:07.
