-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DVDFab 13 (https://forum.cdrinfo.pl/f11/dvdfab-13-a-98881/)
czary2mary 17.12.2024 08:56
DVDFab 13.0.3.2
https://www.dvdfab.cn/download.htm
DVDFab 13.0.3.2 Changelog
Fix: A conversion failure when using NVIDIA AI Enhancer to output 4K HDR10 videos in the Ripper module in some cases.
Fix: A conversion failure when using NVIDIA AI Enhancer to output 4K HDR10 format in the UHD Creator module in some cases.
czary2mary 30.11.2024 23:58
DVDFab 13.0.3.0
DVDFab 13.0.3.0 Changelog
New: Added support for some new Java protections.
czary2mary 11.11.2024 09:42
DVDFab 13.0.2.9
DVDFab 13.0.2.9 Changelog
New: Added support for some new Japanese adult DVDs.
czary2mary 26.10.2024 10:02
DVDFab 13.0.2.8
DVDFab 13.0.2.8 Changelog
New: Optimized the conversion engine and improved conversion stability.
czary2mary 12.09.2024 19:11
DVDFab 13.0.2.6
DVDFab 13.0.2.6 Changelog
Fix: The problem that DVDFab can't detect the optical drive in some cases.
Fix: The problem that DVDFab failed to read the disk in some cases.
Fix: The problem of disc reading errors encountered when using "Copy" and "Ripper" modules in some cases.
czary2mary 22.08.2024 08:12
DVDFab 13.0.2.5
DVDFab 13.0.2.5 Changelog
New: Added support for some new Java protection.
New: Optimized the display window of Fab365 info.
czary2mary 13.08.2024 11:33
DVDFab 13.0.2.4
DVDFab 13.0.2.4 Changelog
Fix: An audio sync problem when using the MKV Passthrough profile in the Ripper module.
czary2mary 10.08.2024 07:39
DVDFab 13.0.2.3
DVDFab 13.0.2.3 Changelog
Fix: A problem that the conversion speed was slow when using hardware acceleration in the Ripper module in some cases.
czary2mary 18.07.2024 07:02
DVDFab 13.0.2.1
DVDFab 13.0.2.1 Changelog
New: Added Blu-ray After Editor module, support adding or replacing audio and subtitles and lossless output to Blu-ray format.
For more information: https://www.dvdfab.cn/blu-ray-after-editor.htm
New: Added UHD After Editor module, support adding or replacing audio and subtitles and lossless output to UHD format.
For more information: https://www.dvdfab.cn/uhd-after-editor.htm
czary2mary 28.06.2024 08:18
DVDFab 13.0.2.0
DVDFab 13.0.2.0 Changelog
Fix: A problem that DVD Ripper failed to convert when the file name contains carriage return characters.
czary2mary 09.06.2024 09:07
DVDFab 13.0.1.9
DVDFab 13.0.1.9 Changelog
New: Optimized the interface of the License Info window.
Fix: A problem that HDR10/Dolby Vision sources are shown as SDR in UHD Copy module.
Fix: A problem that no subtitles are in ripped video after using "Remux into File" mode to process external .SRT subtitles in Ripper modul
czary2mary 26.05.2024 10:42
DVDFab 13.0.1.7
DVDFab 13.0.1.7 Changelog
New: Added support for displaying the update file size in the Updater window.
Fix: A problem that Blu-ray Creator cannot create more than four thumbnails with Streaming menu template.
Fix: A problem that Blu-ray Creator cannot change the source files' order by dragging and dropping.
Fix: A problem that the custom thumbnails will be replaced by default ones in Blu-ray Creator's menu panel.
Fix: A problem the aspect ratio of the output DVD is wrong after converting from Blu-ray to DVD.
Fix: A problem that the output file size still exceeds the capacity even though "Fit to Disc" was selected in DVD Creator.
czary2mary 25.04.2024 17:14
DVDFab 13.0.1.6
DVDFab 13.0.1.6 Changelog
New: Optimized DVDFab Products panel.
New: Added support for installing UniFab in the background under the original Video Converter module for faster download speed.
Fix: A problem that you can't select No Menu mode in the Advanced Settings in Copy -> Customize mode.
czary2mary 13.04.2024 08:07
DVDFab 13.0.1.5
DVDFab13 13.0.1.5 Changelog
Fix: A conversion failure problem when converting with "No Menu" mode in Blu-ray Creator.
czary2mary 01.04.2024 10:22
DVDFab 13.0.1.4
DVDFab13 13.0.1.4 Changelog
New: Added support for Menu thumbnail preview in the main interface of Creator, so that users can visualize the Menu they are using.
Fix: A problem that setting H265 as A/V codec in Common Settings does not take effect after restarting DVDFab.
Fix: A problem that the Creator templates are not displaying correctly when the laptop resolution is set to 1920*1080 and the DPI is set to 150%.
Fix: A problem that the setting for 'Play sound when event occurs' cannot be remembered correctly in DVDFab13.
Fix: Some other GUI display problems.
Wszystkie czasy w strefie CET. Aktualna godzina: 22:56.
