DVDFab 13.0.1.3
https://www.dvdfab.cn/download.htm
DVDFab13 13.0.1.3 Changelog New: Added support for deleting and editing the text information of Metadata in Blu-ray Creator. Fix: A failure problem when output to DVD5 using DVD Creator and DVD Copy module |
DVDFab 13.0.1.2
DVDFab13 13.0.1.2 Changelog New: Added support for the new Streaming menu template in Blu-ray Creator. - Support searching Meta information automatically for movies or TV Shows. - Support setting the poster of the video as a Menu background automatically. - Including Root Menu, Scense, and Set Up pages, closer to the original disc menu. New: Added support for displaying the conversion progress on the DVDFab icon in the system taskbar when the task is processing. Fix: A problem that the tasks are not saved in the Archived section after the conversion is finished and the program is restarted. Fix: Some GUI display problems. |
DVDFab 13.0.1.1
DVDFab 13.0.1.1 changelog: New: Added support for some new Java protections. Fix: A problem that the burning process is slow. Fix: A failure problem when dealing with special paths (such as Japanese usernames or Japanese paths) when using Creator. |
WAŻNA INFORMACJA odnośnie DVDFab 13.
Program DVDFab w wersji 13 nie wspiera zewnętrznej nagrywarki Verbatim Ultra HD / 4K. Zgłosiłem sprawę do supportu programu. Także osoby, które mają filmy Ultra HD muszą nabyć odpowiednią nagrywarkę w celu skopiowania filmu! |
DVDFab 13.0.0.8
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.8 Changelog New: Added support to authorize DVDFab 13 with Google accounts. Fix: A problem that a DVD-9 disc is required despite selecting DVD-5 when burning to DVD discs in the DVD Creator module. Fix: A problem that the system taskbar is disabled if DVDFab 13 interface is maximized. Fix: Some other GUI display issues. |
DVDFab 13.0.0.6
DVDFab 13.0.0.6 Changelog New: Added support to access system fonts when adding external subtitles and watermarks. New: Added support to choose 16:9 or 4:3 aspect ratio when creating DVDs in the DVD Creator module. Fix: A problem that the modified width of the source information column after opening the source is not remembered upon next startup. Fix: A GUI display problem on BDFix feature in certain cases. Fix: Some other GUI display issues. |
DVDFab 13.0.0.5
DVDFab 13.0.0.5 Changelog Fix: A problem that the duration of the output file and the duration displayed at the main interface are not correct after using the Trim feature in the Ripper modules. Fix: A problem that the titles of certain video files are messed up after being loaded into the software. Fix: A problem that the software exited abruptly when converting certain videos in the DVD Creator module. Fix: A problem that the aspect ratio of the output DVDs from the DVD Creator module is not correct. Fix: A problem that the custom thumbnail in the menu of the Blu-ray Creator module cannot be saved. Fix: A problem that the failed tasks in the DVD to Blu-ray Converter module cannot be restarted from the Processing queue. Fix: Some known GUI display issues. |
DVDFab 13.0.0.3
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.3 Changelog New: Added support to downgrade UHD drives with the UHD Drive Tool module. New: Added the DRM Removal for Apple module (available only to existing paid users). New: Added support to use DVDFab 13 offline for 30 days after online authorization. Fix: Some minor issues when downgrading Buffalo UHD drives with the UHD Drive Tool. Fix: A crash problem in certain cases. Fix: Some known GUI display issues. |
DVDFab 13
Ilość załączników: 3
1.11.2023 została zaprezentowana nowa odsłona popularnego programu do zaawansowanej edycji i kopiowania materiałów audio i video .Zmiany i nowości oraz poradniki i prezentacje poszczególnych modułów programu zaprezentowane na stronie programu :
https://www.dvdfab.cn/resource/dvd/dvdfab13-review Producent wyróżnia i zwraca uwagę na następujące nowości 1. Najnowsze aktualizację dla nowych zabezpieczenia przed kopiowaniem 2. Nowe funkcje edycji wideo Nowa funkcja Video Editor w modułach Ripper jest znacznie prostsza i łatwiejsza w użyciu. Możesz teraz edytować, przycinać, łączyć, obracać, dodawać napisy i znaki wodne oraz dostosowywać do swojego stylu. 3. Zupełnie nowy konwerter audio Hi-Fi w modułach Ripper Konwerter audio Hi-Fi jest zintegrowany z modułem Ripper i nie wymaga dodatkowego zakupu. Umożliwia konwersję muzycznych plików Blu-ray na bezstratne pliki audio HI-Fi z wyjściem HD o rozdzielczości 24 bitów i częstotliwości do 192 kHz, co pozwala na tworzenie przyjaznych dla odtwarzania plików CUE. 4. Poprawiona prędkość nagrywania i konwersji Szybkość konwersji i nagrywania płyt według producenta wzrosła średnio o 5% do 10%, Również podobno też sam proces jest teraz bardziej stabilny. (Kto używa zwłaszcza na nowych systemach wie o co chodzi ) 5. Nowo zaprojektowany interfejs użytkownika DVDFab 13 6. Nowy dokładniejszy tryb wyświetlania informacji wejścia-wyjścia DVDFab 13. Wprowadzono nowy i ulepszony sposób wyświetlania informacji o źródle i wyjściu podczas zadań związanych z przetwarzaniem materiału, dzięki czemu wszystko jest dobrze widoczne i pozwala śledzić różne dane wideo, takie jak tytuł, czas trwania, szczegóły rozdziałów, stan HDR, napisy i inne ustawienia wideo i audio. Załącznik 204575 Załącznik 204576 Załącznik 204577 |
| Wszystkie czasy w strefie CET. Aktualna godzina: 09:13. |
