DVDFab 13.0.1.6
https://www.dvdfab.cn/download.htm
DVDFab 13.0.1.6 Changelog New: Optimized DVDFab Products panel. New: Added support for installing UniFab in the background under the original Video Converter module for faster download speed. Fix: A problem that you can't select No Menu mode in the Advanced Settings in Copy -> Customize mode. |
DVDFab 13.0.1.5
https://www.dvdfab.cn/download.htm DVDFab13 13.0.1.5 Changelog Fix: A conversion failure problem when converting with "No Menu" mode in Blu-ray Creator. DVDFab Passkey 9.4.6.8 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.8 Changelog New: Added the support for some new Java protections. |
DVDFab 13.0.1.4
https://www.dvdfab.cn/download.htm DVDFab13 13.0.1.4 Changelog New: Added support for Menu thumbnail preview in the main interface of Creator, so that users can visualize the Menu they are using. Fix: A problem that setting H265 as A/V codec in Common Settings does not take effect after restarting DVDFab. Fix: A problem that the Creator templates are not displaying correctly when the laptop resolution is set to 1920*1080 and the DPI is set to 150%. Fix: A problem that the setting for 'Play sound when event occurs' cannot be remembered correctly in DVDFab13. Fix: Some other GUI display problems. |
DVDFab 13.0.1.3
DVDFab13 13.0.1.3 Changelog New: Added support for deleting and editing the text information of Metadata in Blu-ray Creator. Fix: A failure problem when output to DVD5 using DVD Creator and DVD Copy module |
DVDFab 13.0.1.2
DVDFab13 13.0.1.2 Changelog New: Added support for the new Streaming menu template in Blu-ray Creator. - Support searching Meta information automatically for movies or TV Shows. - Support setting the poster of the video as a Menu background automatically. - Including Root Menu, Scense, and Set Up pages, closer to the original disc menu. New: Added support for displaying the conversion progress on the DVDFab icon in the system taskbar when the task is processing. Fix: A problem that the tasks are not saved in the Archived section after the conversion is finished and the program is restarted. Fix: Some GUI display problems. |
DVDFab 13.0.1.1 + DVDFab Passkey 9.4.6.7
DVDFab 13.0.1.1
https://www.dvdfab.cn/download.htm DVDFab 13.0.1.1 changelog: New: Added support for some new Java protections. Fix: A problem that the burning process is slow. Fix: A failure problem when dealing with special paths (such as Japanese usernames or Japanese paths) when using Creator. DVDFab Passkey 9.4.6.7 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.7 Changelog New: Added the support for some new Java protections. |
WAŻNA INFORMACJA odnośnie DVDFab 13.
Program DVDFab w wersji 13 nie wspiera zewnętrznej nagrywarki Verbatim Ultra HD / 4K. Zgłosiłem sprawę do supportu programu. Także osoby, które mają filmy Ultra HD muszą nabyć odpowiednią nagrywarkę w celu skopiowania filmu! |
DVDFab 13.0.0.8
DVDFab 13.0.0.8 Changelog New: Added support to authorize DVDFab 13 with Google accounts. Fix: A problem that a DVD-9 disc is required despite selecting DVD-5 when burning to DVD discs in the DVD Creator module. Fix: A problem that the system taskbar is disabled if DVDFab 13 interface is maximized. Fix: Some other GUI display issues. |
DVDFab 13.0.0.6
DVDFab 13.0.0.6 Changelog New: Added support to access system fonts when adding external subtitles and watermarks. New: Added support to choose 16:9 or 4:3 aspect ratio when creating DVDs in the DVD Creator module. Fix: A problem that the modified width of the source information column after opening the source is not remembered upon next startup. Fix: A GUI display problem on BDFix feature in certain cases. Fix: Some other GUI display issues. |
DVDFab 13.0.0.5 + DVDFab Passkey 9.4.6.5
DVDFab 13.0.0.5
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.5 Changelog Fix: A problem that the duration of the output file and the duration displayed at the main interface are not correct after using the Trim feature in the Ripper modules. Fix: A problem that the titles of certain video files are messed up after being loaded into the software. Fix: A problem that the software exited abruptly when converting certain videos in the DVD Creator module. Fix: A problem that the aspect ratio of the output DVDs from the DVD Creator module is not correct. Fix: A problem that the custom thumbnail in the menu of the Blu-ray Creator module cannot be saved. Fix: A problem that the failed tasks in the DVD to Blu-ray Converter module cannot be restarted from the Processing queue. Fix: Some known GUI display issues. DVDFab Passkey 9.4.6.5 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.5 Changelog New: Added the support for some new Java protections. |
DVDFab 13.0.0.3 + DVDFab Passkey 9.4.6.4
DVDFab 13.0.0.3
https://www.dvdfab.cn/download.htm DVDFab 13.0.0.3 Changelog New: Added support to downgrade UHD drives with the UHD Drive Tool module. New: Added the DRM Removal for Apple module (available only to existing paid users). New: Added support to use DVDFab 13 offline for 30 days after online authorization. Fix: Some minor issues when downgrading Buffalo UHD drives with the UHD Drive Tool. Fix: A crash problem in certain cases. Fix: Some known GUI display issues. DVDFab Passkey 9.4.6.4 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.6.4 Changelog New: Added the support for some new Java protections. |
DVDFab 13.0.0.2
https://www.dvdfab.cn/download.htm - New: Added support for some new Java protections. - New: Some improvements on the Advanced Settings panel in the Ripper modules to display more content in one screen. - Fix: A crash problem in certain cases. - Fix: A problem that the feature to resume default when adding subtitles at the Video Edit panel does not work in the Ripper modules. - Fix: A problem that the feature to rename output files does not work in the Ripper modules. - Fix: Some known GUI display issues. |
DVDFab Passkey 9.4.6.3
Passkey 9.4.6.3 Changelog New: Added the support for some new Java protections. |
DVDFab 12.1.1.5
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.5 Changelog New: Added support for some new Java protections. |
DVDFab 12.1.1.4
https://www.dvdfab.cn/download.htm DVDFab 12.1.1.4 Changelog New: Added support for some new Java protections. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 11:25. |
