DVDFab 12.0.8.1 + DVDFab Passkey 9.4.4.1
DVDFab 12.0.8.1
https://www.dvdfab.cn/download.htm DVDFab 12.0.8.1 Changelog New: Added support for some new Java protections. Fix: A problem that the estimated output file size is incorrect when the MKV (Dolby Vision) conversion profile is used. Fix: A GUI display problem under certain displays with different resolution settings. DVDFab Passkey 9.4.4.1 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.4.1 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.7.9 + DVDFab Passkey 9.4.4.0
DVDFab 12.0.7.9
https://www.dvdfab.cn/download.htm DVDFab 12.0.7.9 Changelog New: Added support for some new Java protections. DVDFab Passkey 9.4.4.0 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.4.0 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.7.7 + DVDFab Passkey 9.4.3.9
DVDFab 12.0.7.7
https://www.dvdfab.cn/download.htm DVDFab 12.0.7.7 Changelog New: Added the support for some new Java protections. DVDFab Passkey 9.4.3.9 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.3.9 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.7.5 + DVDFab Passkey 9.4.3.8
DVDFab 12.0.7.5
https://www.dvdfab.cn/download.htm DVDFab 12.0.7.5 Changelog New: Added support for some new Java protections. Fix: A freeze problem when using the Enlarger AI module to upscale the VOB videos recorded by VHS camera devices. Fix: A crash problem when loading more than 6 DVD sources in the DVD to Blu-ray Converter module. Fix: A problem that the output Blu-rays created by the Blu-ray Creator module only display one line of subtitles despite there are two lines in the source files. Fix: A problem that the output M2TS videos converted from MP4 videos by the Video Converter module cannot play back normally. DVDFab Passkey 9.4.3.8 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.3.8 Changelog New: Added the support for some new Java protections. |
DVDFab Passkey 9.4.3.7
Passkey 9.4.3.7 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.7.3 + DVDFab Passkey 9.4.3.6
DVDFab 12.0.7.3
https://www.dvdfab.cn/download.htm DVDFab 12.0.7.3 Changelog New: Added support for some new Java protections. New: Added a new Enlarger AI training model Real-CUGAN in the Ripper and Converter modules. New: Added the M2TS Passthrough conversion profile in the Video Converter module. DVDFab Passkey 9.4.3.6 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.3.6 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.7.1 + DVDFab Passkey 9.4.3.5
DVDFab 12.0.7.1
https://www.dvdfab.cn/download.htm DVDFab 12.0.7.1 Changelog Fix: An update failure problem in certain cases. Fix: A crash problem when making DVDs with certain video files in the DVD Creator module. DVDFab Passkey 9.4.3.5 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.3.5 Changelog New: Added the support for some new Java protections. __________________ |
DVDFab 12.0.6.8 + DVDFab Passkey 9.4.3.3
DVDFab 12.0.6.8
https://www.dvdfab.cn/download.htm DVDFab 12.0.6.8 Changelog New: Added support for some new Java protections. DVDFab Passkey 9.4.3.3 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.3.3 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.6.7
DVDFab 12.0.6.7 Changelog New: Added support for some new Java protections. |
DVDFab 12.0.6.4
https://www.dvdfab.cn/download.htm DVDFab 12.0.6.4 Changelog New: Added support for some new Java protections. New: Added support to enable IQS (Intel Quick Sync) hardware acceleration with the 12th-gen Intel CPUs. Fix: A crash problem when cropping the Tubi videos downloaded with StreamFab in certain cases. |
DVDFab 12.0.6.2
DVDFab 12.0.6.2 Changelog Fix: A startup crash problem due to altered DVDFab host information in the system hosts file. Fix: A startup crash problem on machines installed with AMD Radeon RX 480 video card. Fix: A subtitle display problem after burning the videos downloaded from Netflix to BD25 discs in the Blu-ray Creator module. |
DVDFab 12.0.6.1
DVDFab 12.0.6.1 Changelog Fix: A failure problem when copying certain Japanese DVDs in the Full Disc mode of the DVD Copy module. Fix: A problem that Japanese subtitles contain messy codes after burning to BD discs. |
DVDFab Passkey 9.4.3.1
Passkey 9.4.3.1 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.5.8 + DVDFab Passkey 9.4.3.0
DVDFab 12.0.5.8
https://www.dvdfab.cn/download.htm DVDFab 12.0.5.8 Changelog New: Added the H265 encoding support when converting videos with the TS conversion profile in the Video Converter module. New: Some improvements on GUI display under higher DPI settings. Fix: A problem that the live update window still pops up after uninstalling all the DVDFab related products. Fix: A problem that the text introduction in the Streaming menu template of the Blu-ray Creator module can be manually removed. Fix: A problem that the cloned ISO files of the 4K Blu-rays recorded by Panasonic DMR-4CW200 cannot play back. DVDFab Passkey 9.4.3.0 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.3.0 Changelog New: Added support for some new Java protections. Fix: A problem that the cloned ISO files of the 4K Blu-rays recorded by Panasonic DMR-4CW200 cannot play back. |
DVDFab Passkey 9.4.2.9
Passkey 9.4.2.9 Changelog New: Added the support for some new Java protections. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:02. |
