Stary 23.12.2017, 14:21   #1
DVDFab Passkey \ DVDFab otrzymuje wsparcie dla UHD \ 4K
New: Added support for external free keys to open some UltraHD Blu-ray discs, using a UHD friendly drive. The key file location can be changed in Settings -> UHD.
More Info: https://forum.dvdfab.cn/forum/uhd-copy-ripper/3463764
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Stary 28.12.2017, 07:15   #2
DVDFab
Również pozostałe programy Fengtao Software Inc. otrzymują oficjalne wsparcie dla Ultra HD \ 4 K
DVDFab x64 10.0.7.6
DVDFab 10.0.7.6 Changelog
New: Added the support to open some 4K Ultra HD Blu-ray discs from certain types of UHD-friendly drives by accepting external key files. The key file location can be changed at Common Settings > Blu-ray > UHD. More Info:https://forum.dvdfab.cn/forum/uhd-copy-ripper/346376
New: Added the enhanced E-AC3 audio support to the Blu-ray Creator module.
Fix: A problem that external subtitles are not displayed when playing the UHD Copy produced copies on some hardware playback devices.
Fix: A freeze problem when copying certain Blu-ray discs in certain cases.
Fix: A memory leak problem when removing Cinavia watermarks from DVDs.
Fix: A video and audio not sync problem when converting some video files with GPU hardware acceleration.
Fix: A green screen problem in the resulting video if HD2000/3000 Intel Quick Sync is enabled during the conversion process.
Fix: Improved the speed with software encoding.
Fix: Some minor changes and improvements.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64
Stary 29.12.2017, 12:30   #3
DVDFab Passkey 9.2.2.3
New: Improved the support for reading Blu-ray discs when ripping to hard disk.
Stary 04.01.2018, 18:46   #4
Passkey 9.2.2.4
Fix: A failure problem when ripping DVD/Blu-ray discs to ISO in certain cases.
Stary 06.01.2018, 08:54   #5
DVDFab 10.0.7.7
New: Added the support to remove Cinavia watermarks of the infected DVDs with the Full Disc mode.
https://www.dvdfab.cn/download.htm
Stary 12.01.2018, 06:47   #6
Passkey 9.2.2.5
New: Added the support for some new Java protections.
Stary 14.03.2018, 09:16   #7
misiozol
Avatar użytkownika misiozol
Data rejestracji: 26.10.2008
Ciekawe jak to cudo sie sprawuje , masz ten program ?
Stary 14.03.2018, 14:48   #8
Obsługuje już około ~~300 kluczy AACS 2 dla UHD DL 66GB \ UHD TL 100GB czyli chyba wszystkie jakie zostały upublicznione \wyciągnięte z wydań oryginalnych filmów \koncertów itp itd .
Stary 14.03.2018, 16:08   #9
misiozol
Hmm... no to tak elegancko, tylko ja widze jedno zastosowanie dla tego softu no moze dwa
Stary 15.03.2018, 08:04   #10
DVDFab 10.0.8.7
Fix: A crash problem by the end of backup process under certain modes of the DVD Copy module.
http://www.dvdfab.cn/download.htm
Stary 15.03.2018, 16:23   #11
Passkey 9.3.0.0
New: Introduced the all new installation procedures.
New: Added the support for a new BD-J protection as found on the Canadian version of Jigsaw.
New: Improved the BluPath feature.
Fix: An installation failure problem if the OS language is Japanese in certain cases.
Stary 20.03.2018, 17:56   #12
Passkey 9.3.0.1
Stary 03.04.2018, 16:09   #13
DVDFab 10.0.8.8 + Passkey 9.3.0.2
DVDFab 10.0.8.8 +
New: Added the support to remove the Cinavia watermarks found on the Blu-ray versions of the Sleight, Saban***8217;s Power Rangers and The Big Sick, and the DVD version of My Little Pony.
New: Ushered in the brand-new decryption technology to decrypt genuine 4K Ultra HD Blu-ray discs. (The disc can be opened but UHD Copy and UHD Ripper availabled only in DVDFab x64 version)
Fix: A problem that the size of the ISO file created by Blu-ray Creator is incorrect.
Fix: A problem that the estimated time for the conversion task is incorrect in the Ripper modules.
Passkey 9.3.0.2
New: Introduced the all new installation procedures. (Note: Installing this version shall automatically uninstall the previous version in the process, and upon the completion of the installation, a computer reboot is required.)
New: Ushered in the brand-new decryption technology to decrypt genuine 4K Ultra HD Blu-ray discs. (It's included in Passkey for Blu-ray option)
Stary 11.05.2018, 06:30   #14
DVDFab 10.0.9.2
New: Added the support to remove the Cinavia protections as found on the DVD versions of The Glass Castle and the Pitch Perfect 3 and the Blu-ray versions of the All Eyez on Me, the Pitch Perfect 3 and the Last Flag Flying.
New: Removed the restriction that the free utility BDFix is available only to those who own a paid version of Blu-ray Copy.
New: Separated the Youtube Video Downloader from the Video Converter module and moved it to the Utilities tab as a free tool.
New: Added the support for the 2-pass encoding method if the video encoder is set to CUDA in the Ripper modules.
Fix: A problem that the sources in the Archived Task list cannot be reloaded to the Current Task list in certain cases.
Fix: A problem that the runtime is shortened when copying the 2D Blu-ray version of Blade Runner 2049 (Germany edition) in Main Movie mode.
Fix: A problem that two audio tracks appear in the output file even only one is selected in the Customize mode of the DVD Copy module.
Fix: A failure problem when converting BDAV discs to MP4/MKV videos in certain cases.
Fix: A problem that the "Display forced subtitle only" option is selected by default when Sweden subtitle is selected in the Ripper module.
Fix: A problem that nothing appears in the output directory when converting videos with hardware acceleration in certain cases.
Fix: Improved the UI support for 4K high DPI displays.
Stary 18.05.2019, 04:33   #15
Passkey 9.3.4.7
Pomoc w wyborze najlepszego TV UHD 4K misiozol Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) 6 05.12.2016 19:23
Błagam o wsparcie dla mojego syna ilona-lackowska Off topic 114 01.04.2007 15:52
Mandat za parkowanie w miejscu dla osoby niepełnosprawnej... przez inwalidę... woitas Off topic 26 28.07.2006 09:41
Dla Was.. i dla Ciebie Kochanie... Martin_TP Off topic 13 10.03.2003 19:38
Wszystkie czasy w strefie CET. Aktualna godzina: 10:44.
