Instalacja Daemon Tools 4.00
Włącz emulację RMPS Podłącz obraz gry Wyłącz kompa Odepnij taśmy od CD lub DVD(wszystkie!!!) Włącz kompa i graj U mnie tak działa :respect: |
peter jackson's king kong
zna ktos sposób obejscia zabezpieczenia tej gierki?
oto co znalazlem na zagranicznych forach-szkoda ze mi nie dziala: ************ INSTRUCTIONS FOR PLAYING *********** 1. Unrar all files and mount image using Daemon Tools 4. Leave all emulation options ON !!!! 2. Use StarForce Nightmare and select "Disable CD", "Disable Node" and deselect ide channel of your optical devices (Primary and/or Secondary). ¦ 3. Install Game from virtual daemon drive and use serial number provided with this info when StarForce3 protection asks for it. 4. Play the game !!!!! Still get message "ERROR" Please install Peter Jackson King Kong CD1 in another drive 2.STARFORCE 3 PROTECTiON WALKTHOUGH: Tested this on GT LEGENDS and PETER JACKSONS KING KONG! 1: reboot your pc and disconnect your Optical Drives ONLY 2: Once back into windows start up starforce nightmare and select DISABLE CD and DISABLE NODE 3: startup Alcohol 120% and mount the King Kong Example.mds file and in alcohols options select RMPS Emulation then shutdown alchohol. Finaly start the game up enter your cdkey and presto works for me on all starforce 3 games that i have so far tested with. do not use DAEMON TOOLS for Starforce protected games as its pritty crap and caused a shit load of problems for me, all the problems of system auto rebooting without a bluescreen and no error or just erroring out with please enter cd blah blah blah ect, useing alcohol 120% i didnt get one single problem at all, if you follow my instructions your games will indeed work. ps. u kumpla ta wersja(sciagnieta z osloskopu) dziala choc nie wiem dlaczego-a nic nie kombinowal z napedami |
| Wszystkie czasy w strefie CET. Aktualna godzina: 07:24. |
