-   -   Komunikatory, newsy, porady, problemy... (https://forum.cdrinfo.pl/f113/komunikatory-newsy-porady-problemy-71355/)
NeoFighter 06.07.2007 17:19
nie masz przypadkiem ustawionego jakiegos schematu w IEview?
moze to powoduje wyswietlanie 'x'
gdzie to sie wogole pojawia?
daj innego screena
uzywaj clist_modern, daje wieksze mozliwosci
IceManSpy 06.07.2007 15:20
Ok, przeszed***322;em na unicode. A co z tym X? I na li***347;cie do wyboru dost***281;pny/zaraz wracam itd. mam tylko tlena i gg, a gdzie jabber? Jest on w***322;***261;czony, bo mog***281; przez niego rozmawia***263;.
NeoFighter 06.07.2007 14:53
zeby poprawnie dzialaly Ci pluginy Unicode MUSISZ miec mirande Unicode
zgadza sie masz ansi "Unicode core: No"
IceManSpy 06.07.2007 12:38
CPU: AMD Sempron(tm) Processor 2800+ [x86 Family 15 Model 44 Stepping 2] [DEP enabled]
Installed RAM: 1023 MBytes
Operating System: Microsoft Windows XP [version: 5.1.2600 Dodatek Service Pack 2]
Shell: Explorer.exe, Internet Explorer 6.0.2900
Administrator privileges: Yes
OS Languages: (UI | Locale (User/System)) : Polish/Polish | Polish/Polish
Free disk space on Miranda partition: 11675 MBytes
Miranda path: C:\Documents and Settings\IceMan\Pulpit\miranda\miranda-v070a33
Miranda IM version: 0.7.0 alpha build #33
Build time: 20:49:56 on 02 July 2007
Profile size: 64.00 KBytes
Profile creation date: 04 Jul 2007 at 18:28:13
Language pack: No language pack installed
Nightly: Yes
Unicode core: No
Active Plugins (17):
¤ advaimg.dll v.0.0.1.0 [02 Jul 2007] - Miranda Image services
¤ avs.dll v.0.0.3.0 [02 Jul 2007] - Avatar service
¤ chat.dll v.0.7.0.1 [02 Jul 2007] - Chat
¤ clist_nicer.dll v.0.7.2.0 [02 Jul 2007] - CList Nicer+
¤ dbx_mmap.dll v.0.7.4.0 [02 Jul 2007] - Miranda mmap database driver
¤ GG.dll v.0.0.4.5 [02 Jul 2007] - Gadu-Gadu Protocol
gmailm.dll v.0.3.1.0 [23 Mar 2007] - Gmail Multiple Notifier
¤ IEHistory.dll v.0.0.1.4 [22 Apr 2007] - IEView History Viewer
¤ ieview.dll v.1.0.9.10 [13 Jun 2007] - IEView
¤ import.dll v.0.9.2.2 [02 Jul 2007] - Import contacts and messages
¤ jabber.dll v.0.7.0.10 [02 Jul 2007] - Jabber Protocol
mContacts.dll v.0.0.1.1 [21 Aug 2004] - mContacts
¤ scriver.dll v.2.5.9.18 [02 Jul 2007] - Scriver
simpleaway.dll v.1.6.1.1 [13 Apr 2005] - SimpleAway
¤ smileyaddw.dll v.0.1.12.14 [05 Jul 2007] - SmileyAdd Unicode
tlen.dll v.0.1.0.2 [19 Aug 2003] - Tlen Protocol
¤ VersionInfo.dll v.1.4.2.0 [22 Jun 2007] - Version Information
To jest chyba ANSI. I XP + SP2, tylko styl z Visty. Już sobie poradziłem z mafią, teraz jak i gdzie usunąć ten krzyżyk z okna rozmowy?
NeoFighter 06.07.2007 12:06
@IceManSpy
wklej calego loga z versioninfo, nie tylko pluginy
uzywasz wersji testowej Unicode?
masz Viste, czy tylko taki styl?
***347;Vista lubi psuc mirande
IceManSpy 06.07.2007 11:22
Tutaj s***261; wszystkie moje pluginy:
***164; advaimg.dll v.0.0.1.0 [02 Jul 2007] - Miranda Image services
***164; avs.dll v.0.0.3.0 [02 Jul 2007] - Avatar service
***164; chat.dll v.0.7.0.1 [02 Jul 2007] - Chat
***164; clist_nicer.dll v.0.7.2.0 [02 Jul 2007] - CList Nicer+
***164; dbx_mmap.dll v.0.7.4.0 [02 Jul 2007] - Miranda mmap database driver
***164; GG.dll v.0.0.4.5 [02 Jul 2007] - Gadu-Gadu Protocol
***164; IEHistory.dll v.0.0.1.4 [22 Apr 2007] - IEView History Viewer
***164; ieview.dll v.1.0.9.10 [13 Jun 2007] - IEView
***164; import.dll v.0.9.2.2 [02 Jul 2007] - Import contacts and messages
***164; jabber.dll v.0.7.0.10 [02 Jul 2007] - Jabber Protocol
***164; scriver.dll v.2.5.9.18 [02 Jul 2007] - Scriver
***164; smileyaddw.dll v.0.1.12.14 [05 Jul 2007] - SmileyAdd Unicode
***164; VersionInfo.dll v.1.4.2.0 [22 Jun 2007] - Version Information
I w***322;a***347;nie nie mam tam opcji offline :(
http://img469.imageshack.us/img469/9...2258uw1.th.png
I tak podsumowywuj***281;. Wiem, ***380;e jest forum mirki. Staram si***281; tam tam szuka***263; odpowiedzi na w***322;a***347;ciwym forum, ale pisz***261;c takie b***322;ache problemy, nara***380;am si***281; na ostre s***322;owa itd. Przeczyta***322;em ichniejszy FAQ, ale tam s***261; tylko og***243;lne informacje.
Zmiana z SimpleAway na NewStatusNotify 1.1.2.2
NeoFighter 06.07.2007 00:02
Napisany przez Piterniel (Post 805983)
Database Editor++
Da sie, da ;p
dokladniej usluga MS_DB_CONTACT_ADD
mozna sobie przycisk dodac do listy kontaktow :taktak: :)
@IceManSpy
co to za wtyczka do statusow?
sprobuj dac np. '.' (kropke) dla offline
nie dokonca pusty satus, ale juz bez wiadomosci :)
IceManSpy 06.07.2007 00:02
Mam troch***281; inny widok:
http://img234.imageshack.us/img234/5...0041th1.th.png
A przy ustawieniu na empty wywala mi mirke.
Sorka, ***380;e tutaj pisz***281;, ale na forum mirki nie potrafi***281; znale***378;***263; intersuj***261;cych mnie rzeczy. Wi***281;c zapytam si***281; do***347;wiadczonych u***380;ytkownik***243;w:
1. Jak wy***322;***261;czy***263; tego "X" ?
http://img292.imageshack.us/img292/7...0348mv2.th.png
2. Dlaczego simplyadd ma dziwne znaczki?
http://img461.imageshack.us/img461/3...0439iw5.th.png
3. Jest paczka z emotkami z gg 6?
P.S. Czy wy wszyscy u***380;ywacie mirki?
Piterniel 05.07.2007 23:40
I czy mo***380;na dodawa***263; kontakty bez szukania ich?
Database Editor++
Da sie, da ;p
NeoFighter 05.07.2007 23:35
Napisany przez IceManSpy (Post 805904)
Konfiguruję sobie (bardzo) powoli mirkę, ale mam problem z emotkami. Mam wgraną wtyczkę IEView w wersji 1.0.9.10 i mam ściągnięte emotki. I w readmi pisze:
IEview (ver. < 1.0.5.0):
w Opcjach Mirandy - Sesja rozmowy - IEview na zakładce Emotikony wskaż plik GG.asl.
Domyśliłem się, że potrzebuję wersji mniejszej niż 1.0.5.0, więc jak odpalić emotki?
do emotek
SmileyAdd Unicode 0.1.12.14
IEView 1.0.9.10 (nie wiem skad pomysl zeby nizszej wersji uzywac)
w tym samym folderze, gdzie znajduje sie plik asl powinny byc rowniez trzy foldery z emotkami '1', '2' i '3'
plik asl mozna konfigurowac w notatniku
jak ustawic emotki w smiley add pisalem pare postow wyzej
I może taka mała propozycja. Może napiszecie z jakich wtyczek korzystacie i do czego one służą. Dzięki temu można będzie łatwiej znaleźć coś fajnego/użytecznego (IMO).
jestem za tym, zeby samemu dodawc do mirandy opcje, ktorych aktualnie sie oczekuje od programu
obecnie mam ponad 60 wtyczek, mirande 'buduje' od ponad dwoch lat
kazdy oczekuje czego innego od mirandy i ustawia ja do wlasnych oczekiwan
zobacz dzial dodatkow na oficjalnej stronie, moze znajdziesz cos ciekawego ;)
I czy można dodawać kontakty bez szukania ich?
:nie:
I jak wyłączyć po rozłączeniu że ukrywam się przed mafia?
http://img68.imageshack.us/img68/389...board01ca9.jpg
zmien wiadomosc dla statusu 'niewidoczny'(invisible)
ja do obslugi statusow uzywam New Away System
Napisany przez joujoujou (Post 805923)
Sprawdziłem tego multikontakta - wbrew temu, co piszą, NIE obsługuje skype, na dokładkę nie importuje kontaktów GG, a to już zupełne kuriozum:
Załącznik 41185
EDIT: Ze statusów działają tylko "dostępny" i "niedostępny" - pozostałe się nie włączają.
ale kicha :haha: :rotfl:
plugin do mirandy uzywa api skypa
skype musi byc uruchomiony w tle, ale moze byc zminimalizowany
do rozmow txt wykorzystuje sie mirande, tak jak do kazdego innego protokolu
wykonujac polaczenie glosowe rowniez nie trzeba uzywac okienka skypa, tylko klikac z listy kontaktow mirandy
SpeedFreaK 05.07.2007 22:39
:rotfl:
joujoujou 05.07.2007 22:36
Sprawdzi***322;em tego multikontakta - wbrew temu, co pisz***261;, NIE obs***322;uguje skype, na dok***322;adk***281; nie importuje kontakt***243;w GG, a to ju***380; zupe***322;ne kuriozum:
Załącznik 41185
EDIT: Ze status***243;w dzia***322;aj***261; tylko "dost***281;pny" i "niedost***281;pny" - pozosta***322;e si***281; nie w***322;***261;czaj***261;.
IceManSpy 05.07.2007 22:07
Konfiguruj***281; sobie (bardzo) powoli mirk***281;, ale mam problem z emotkami. Mam wgran***261; wtyczk***281; IEView w wersji 1.0.9.10 i mam ***347;ci***261;gni***281;te emotki. I w readmi pisze:
w Opcjach Mirandy - Sesja rozmowy - IEview na zak***322;adce Emotikony wska***380; plik GG.asl.
Domy***347;li***322;em si***281;, ***380;e potrzebuj***281; wersji mniejszej ni***380; 1.0.5.0, wi***281;c jak odpali***263; emotki?
I mo***380;e taka ma***322;a propozycja. Mo***380;e napiszecie z jakich wtyczek korzystacie i do czego one s***322;u***380;***261;. Dzi***281;ki temu mo***380;na b***281;dzie ***322;atwiej znale***378;***263; co***347; fajnego/u***380;ytecznego (IMO).
I czy mo***380;na dodawa***263; kontakty bez szukania ich? I jak wy***322;***261;czy***263; po roz***322;***261;czeniu ***380;e ukrywam si***281; przed mafia?
NeoFighter 05.07.2007 20:10
Napisany przez andy (Post 805794)
Nie każdy klient IM jest zbudowany na wtyczkach ;-)
kazdy program bez wtyczek, jest juz na starcie slabszy od tego, ktory oferuje mozliwosc dadania rozszerzen
taka moja opinia :)
joujoujou 05.07.2007 20:07
Napisany przez andy (Post 805778)
Multikontakt umożliwia realizację bezpłatnych połączeń głosowych i wideo pomiędzy użytkownikami tej aplikacji."
A co z użytkownikami aplikacji, które zastępuje? :pytanie:
Wszystkie czasy w strefie CET. Aktualna godzina: 00:46.
