Data rejestracji: 04.09.2007
laptopowa matSHITa UJ-860S - problem
No tak, zapeszylem. Pisalem, na jednym forum, ze po zakupie zmartwilo mnie to ze w moim laptopie wsadzono nagrywarke matshity. i masz babo placek! Przy probie nagrania pierwszej plyty dvd w nero 7 wyskakuje "Power Calibration Error"... Co prawda nagrywalem na jakims tanim lipnym dvd, bo takie mialem 'pod reka', ale wszedzie mozna je bylo nagrac bez problemow, tylko oczywiscie nie na matSHITcie!. Co z tym począć, mozliwe ze plyty, a co jesli nie?? Moze log z nero komus pomoze:
Kod:
4C85-2017-4045-0001-0009-7640-0800-1400-0000-4049-233C-**** (*) Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 7.9.6.2 Internal Version: 7, 9, 6, 2 (Nero Express) Recorder: <MATSHITA DVD-RAM UJ-860S>Version: 1.00 - HA 1 TA 0 - 7.9.6.2 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: <MATSHITA DVD-RAM UJ-860S >Version: 1.00 - HA 1 TA 0 - 7.9.6.2 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === CdRomPeripheral : MATSHITA DVD-RAM UJ-860S atapi Port 0 ID 0 DMA: On DiskPeripheral : ST9120822AS atapi Port 1 ID 0 DMA: On === CDRom-Device-Map === MATSHITA DVD-RAM UJ-860S E: CdRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 1023MB (1047756kB) Free physical memory: 382MB (391628kB) Memory in use : 62 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 9.2.2008 ISO compilation 21:32:43 #1 Text 0 File SCSIPTICommands.cpp, Line 424 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 21:32:43 #2 Text 0 File Isodoc.cpp, Line 6663 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 21:32:43 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343 First writeable address = 0 (0x00000000) 21:32:43 #4 Text 0 File Burncd.cpp, Line 3508 Turn on Disc-At-Once, using DVD media 21:32:43 #5 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2150991 (477:59.66, 4201MB) 21:32:43 #6 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 21:32:43 #7 Text 0 File DlgWaitCD.cpp, Line 2964 Recorder: MATSHITA DVD-RAM UJ-860S, Media type: DVD+R Disc Manufacturer ID: MCC, Media Type ID: 003, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 21:32:43 #8 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 21:32:43 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2150992 (2150992) = #2150992/477:59.67 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2150992 blocks [E: MATSHITA DVD-RAM UJ-860S] -------------------------------------------------------------- 21:32:46 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995 Prepare [E: MATSHITA DVD-RAM UJ-860S] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4405231616, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 2150992 | 0 | 0x00 2150992 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 21:32:46 #11 Text 0 File SCSIPTICommands.cpp, Line 215 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 21:32:46 #12 Text 0 File Burncd.cpp, Line 4294 Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB) 21:32:46 #13 Phase 24 File dlgbrnst.cpp, Line 1762 Caching of files started 21:32:46 #14 Text 0 File Burncd.cpp, Line 4413 Cache writing successful. 21:32:46 #15 Phase 25 File dlgbrnst.cpp, Line 1762 Caching of files completed 21:32:46 #16 Phase 36 File dlgbrnst.cpp, Line 1762 Burn process started at 8x (11 080 KB/s) 21:32:46 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 21:32:46 #18 Text 0 File Cdrdrv.cpp, Line 9872 ---- Disc Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: MCC..... Media type ID: 003 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 03 4D 43 43 00 00 - 00 00 00 30 30 33 00 38 ...MCC.....003.8 23 54 37 15 02 52 6C 02 - B4 63 15 15 0B 0A 08 08 #T7..Rl.***9508;c...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 21:32:46 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 Buffer x0649bf00: Len x648 21:32:46 #20 Text 0 File DVDPlusRW.cpp, Line 675 Start write address at LBA 0 DVD high compatibility mode: Yes 21:32:46 #21 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 21:33:10 #22 SPTI -1106 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 00 00 03 00 00 00 20 00 00 00 Sense Area: 0xF1 00 03 00 00 00 00 0A 00 00 00 CD 73 03 Buffer x08ad0640: Len x10000 0xC0 29 95 70 7C 59 CA FD ED 55 41 92 AA 06 2B 71 0x85 70 7F 85 D9 60 33 2A 81 8A C3 25 37 43 2A E7 0x30 30 64 63 CB 0B 00 00 00 00 01 B6 58 F0 43 69 21:33:10 #23 CDR -1106 File Writer.cpp, Line 303 Power calibration error E: MATSHITA DVD-RAM UJ-860S 21:33:22 #24 SPTI -1106 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 70 91 73 03 21:33:22 #25 SPTI -1106 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 70 91 73 03 21:33:22 #26 Phase 127 File dlgbrnst.cpp, Line 1762 Generating DVD high compatibility borders 21:33:45 #27 Text 0 File DVDPlusRW.cpp, Line 935 EndDAO: Last written address 768 21:33:45 #28 CDR -1106 File WriterStatus.cpp, Line 162 Power calibration error E: MATSHITA DVD-RAM UJ-860S 21:33:45 #29 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 21:33:46 #30 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 8x (11 080 KB/s) 21:33:46 #31 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 21:33:47 #32 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 21:33:47 #33 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
| #ads | |
#2 | |
![]() Co wcale niestety nie znaczy, ***380;e inne polubi, bo ten typ tak ma.
no coz, zaopatrze sie chyba w verbatimy (lepsze beda + czy -?).... a moze orientujecie sie, co matSHITy lubia najbardziej?
Ostatnio zmieniany przez grigori : 10.02.2008 o godz. 04:04 |
Weź po dwa, tak na próbę.
Na pewno chcesz wiedzieć? ![]() Nie będziesz zadowolony. ![]()
boje sie, ale dzis mam dzien odwagi i zaryzykuje...(chociz=az sie domyslam)
... a joujoujou, a wiec?...
Skoro nalegasz...
![]() Moim zdaniem to - albo to - a najlepiej od razu
Tak tez myslalem, no ale raczej nie da rady zazadac wymiany nagrywarki w laptopie na inna na zasadzie gwarancji...
Dlaczego nie?
Je***347;li si***281; oka***380;e (co wielce prawdopodobne), ***380;e na innych no***347;nikach zajdzie ta sama sytuacja, to jak najbardziej.
'wymienia mi najwyzej na inna sztuke bo to nie jest zwykly 'slim' tylko specjalnie wyprofilowany akurat do tego lapka, a z tego co mi wiadomo to w moim lapku nie instaluja dvd innych firm...
Nie by***322;bym tego taki pewien.
![]() Wprawdzie jest kilka standard***243;w okre***347;laj***261;cych rozmiary laptopowych nap***281;d***243;w, ale nie jest ich znowu tak du***380;o. Wyprofilowany pewnie jest tylko zewn***281;trzny panel, a ten zazwyczaj mo***380;na prze***322;o***380;y***263; (najcz***281;***347;ciej jest na zatrzaskach).
#11 |
Data rejestracji: 21.02.2008
nie chwaląc się (bo nie ma czym) posiadam taki sam napęd i palę płyty od poł roku już na przeróżnych śmieciach (jara nawet plyty z tesco
) ale zawsze na minusach i jeszcze nie wysypało mi si e wypalanie ani razu ale może to szczęście że trafiłem na taką specjalną sztukę (być może mastszita to tak jak kiedyś napędy cd 52x firmy LG większość nie żyła dłużej niż rok czasu ale jak trafileś na sztukę to i 5 lat bez zarzutu potrafiły chodzić) |
#12 |
Wygl***261;da na to, ***380;e masz wyj***261;tkowe szcz***281;***347;cie.
#13 |
Data rejestracji: 17.03.2003
witam
rowniez posiadam ta nagrywarke, moj problem polega na tym, ze jest zbyt dlugi czas wypalania p***322;yt, x4 ok 23:32min, x8 jest chyba tyle samo, co zrobic? czy to wina plyt (w chwili obecnej mam pod reka tylko mediastore)? skoro nagrywa to chyba problem tkwi w czyms innym. Bios w wersji 1.0, jest to laptop Asus F3SV: Core2Duo T7500 2.2Ghz, 3GB DDR2 667Mhz, 250GB, GeForce 8600GS 256MB, Vista Premium 32bit prosze o pomoc
#14 |
#15 | |
Data rejestracji: 07.01.2007
![]() (oczywiście mówię o już nagranych przez matSHITę) |
