Data rejestracji: 28.07.2005
lg 4163b problem z nagrywaniem dvd
nagrywarka ma 2,5 roku i od okolo tygodnia zaczela robic problemy z nagrywaniem dvd mianowicie soft pokazuje ze nagyrwanie zakonczylo sie sukcesem a na odtwarzaczu pokaszanione menu, koniec na poczatku itp, albo ze nie moze zakonczyc plyty w trybie dao. cdr nagyrwa normalnie. soft nero, dvd shrink, clone dvd, plytki tdk. czy to koniec nagrywarki?
przykladowy log z nero: ================================== Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 8.1.1.0 Internal Version: 8, 1, 1, 0 Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A105 - HA 1 TA 0 - 8.1.1.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default CD-ROM: <HL-DT-ST DVDRAM GSA-4163B>Version: A105 - HA 1 TA 0 - 8.1.1.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : SAMSUNG SP1604N nvatabus Port 0 ID 0 DMA: Off CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B nvatabus Port 0 ID 2 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GSA-4163B H: CdRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte BUFE : 0 Physical memory : 511MB (523568kB) Free physical memory: 247MB (253172kB) Memory in use : 51 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 18.12.2007 Nagraj obraz DVD 20:24:52 #1 Text 0 File SCSIPTICommands.cpp, Line 450 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 20:24:52 #2 Text 0 File Burncd.cpp, Line 3530 Turn on Disc-At-Once, using DVD media 20:24:53 #3 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2285870 (507:58.20, 4464MB) 20:24:53 #4 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD DVD) 20:24:53 #5 Text 0 File DlgWaitCD.cpp, Line 2972 Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R Disc Manufacturer ID: <AML>, Media Type ID: <002>, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 20:24:53 #6 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 20:24:53 #7 Text 0 File ThreadedTransferInterface.cpp, Line 785 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Tryb 1, ISO 9660) 2 indices, index0 (150) not provided original disc pos #0 + 2285871 (2285871) = #2285871/507:58.21 not relocatable, disc pos for caching/writing not required/not required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2285871 blocks [H: HL-DT-ST DVDRAM GSA-4163B] -------------------------------------------------------------- 20:24:53 #8 Text 0 File ThreadedTransferInterface.cpp, Line 986 Prepare [H: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681463808, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 2285871 | 2285871 | 0x00 2285871 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 20:24:53 #9 Text 0 File SCSIPTICommands.cpp, Line 240 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 20:24:53 #10 Text 0 File Burncd.cpp, Line 4316 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 20:24:53 #11 Phase 24 File dlgbrnst.cpp, Line 1764 Caching of files started 20:24:53 #12 Text 0 File Burncd.cpp, Line 4435 Cache writing successful. 20:24:53 #13 Phase 25 File dlgbrnst.cpp, Line 1764 Caching of files completed 20:24:53 #14 Phase 36 File dlgbrnst.cpp, Line 1764 Burn process started at 8x (11*080 KB/s) 20:24:53 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2735 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 20:24:53 #16 Text 0 File Cdrdrv.cpp, Line 10026 ---- Disc Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: AML..... Media type ID: 002 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..783]: 00 00 03 41 4D 4C 00 00 - 00 00 00 30 30 32 00 38 ...AML.....002.8 23 54 37 10 02 4E 72 02 - 8C 63 16 16 0B 0B 0A 0A #T7..Nr..c...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 01 00 38 38 02 34 63 13 - 05 22 22 10 0E 12 12 01 ..88.4c..""..... 00 00 02 34 63 13 05 22 - 22 10 0E 12 12 01 00 00 ...4c..""....... 02 00 54 70 02 4E 64 4A - 20 11 08 08 01 18 00 00 ..Tp.NdJ........ 00 00 02 67 64 4E 20 10 - 08 08 01 18 00 00 00 30 ...gdN.........0 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 20:24:53 #17 Text 0 File DVDR.cpp, Line 6525 Drive: HL-DT-ST DVDRAM GSA-4163B Book Type request [LG]: DVD-ROM Changing the Book Type was finished successfully, return code 0 20:24:53 #18 CDR -1211 File DVDR.cpp, Line 6442 Book Type set to: DVD-ROM 20:24:53 #19 Text 0 File DVDPlusRW.cpp, Line 675 Start write address at LBA 0 DVD high compatibility mode: Yes 20:24:53 #20 Text 0 File ThreadedTransfer.cpp, Line 268 Pipe memory size 74390400 20:37:37 #21 Text 0 File WriterStatus.cpp, Line 113 <H: HL-DT-ST DVDRAM GSA-4163B> start writing Lead-Out at LBA 2285871 (22E12Fh), length 0 blocks 20:38:08 #22 SPTI -1194 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1194) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x04 CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 10 35 20 00 0E 73 04 20:38:10 #23 Text 0 File DVDPlusRW.cpp, Line 935 EndDAO: Last written address 2285872 20:38:10 #24 CDR -1194 File ThreadedTransferInterface.cpp, Line 1883 PMA update failure H: HL-DT-ST DVDRAM GSA-4163B 20:38:10 #25 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1883 Could not perform end of Disc-at-once 20:38:39 #26 SPTI -1194 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1194) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x04 CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 10 35 20 00 0E 73 04 20:38:39 #27 Phase 127 File dlgbrnst.cpp, Line 1764 Generating DVD high compatibility borders 20:38:40 #28 Text 0 File DVDPlusRW.cpp, Line 935 EndDAO: Last written address 0 20:38:40 #29 CDR -1194 File WriterStatus.cpp, Line 162 PMA update failure H: HL-DT-ST DVDRAM GSA-4163B 20:38:40 #30 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 20:38:40 #31 Phase 38 File dlgbrnst.cpp, Line 1764 Burn process failed at 8x (11*080 KB/s) 20:38:40 #32 Text 0 File SCSIPTICommands.cpp, Line 287 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 20:38:40 #33 Text 0 File Cdrdrv.cpp, Line 11276 DriveLocker: UnLockVolume completed 20:38:40 #34 Text 0 File SCSIPTICommands.cpp, Line 450 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) =============================================== |
Data rejestracji: 14.05.2005
M***243;g***322;by***347; poczyta***263; stare w***261;tki, troch***281; ju***380; by***322;o o tej nagrywarce. Zadam standardowe pytanie: na jakich p***322;ytach nagrywasz? Po podaniu dok***322;adnej odpowiedzi, b***281;dzie mo***380;na zastanowi***263; sie jeszcze jak Ci pom***243;c, lecz my***347;l***281;, ***380;e to po prostu czas Twojego palnika mija
Racja jest jak d..., każdy ma swoją ![]() PIONEER 112 ![]()
palilem na platinum, titanium, esperanza, tdk, lg, verbatim, ostatnio kupilem paczke jakichs z tesco bo juz szkoda mi bylo lepszych po wystapieniu tego problemu 1 na 5 jest ok
Czyli oprócz verbatimów paliłeś na słabych płytach, więc nie dziwne, że z czasem występują z nimi problemy. A jak z płytami verbatim? Ile ich wypaliłeś i czy masz z nimi problemy?
#6 | |
co do plytek verbatim to ostanio pale dvd+rw 1-4x serl (tak na wszelki wypadek) sprobuje za chwile cos wypalic i podam jaki efekt no i na verbatimie ok!!! kurcze nie sadzilem ze tdk beda takie lipne.... w sumie najwiecej dvd wypalilem na titanium i smigaja bez zarzutu, a tu masz... Ostatnio zmieniany przez mevil : 19.12.2007 o godz. 12:38 |
I co powiesz więcej doktorku?? Poza tym za wolno wypalasz płyty dvd. Obecnie hasło "wypalać wolniej, znaczy lepiej" mija się z prawdą. Palanie na słabych płytach jest tylko pozorną oszczędnością. Nośniki się zmieniają TDK obecnie to prawie titanium.
No i na co to jest dow***243;d?
![]() ***379;e szlachta znowu rozpija ch***322;op***243;w ![]()
DiskPeripheral : SAMSUNG SP1604N nvatabus Port 0 ID 0 DMA: Off CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B nvatabus Port 0 ID 2 DMA: Off jeszcze z tym trzeba co***347; zrobi***263;. jak? jest w FAQ
kupilem kilka verbatimow i dla porownania jakies bluepopy, takie z pieskiem
no i te bluepopy smigaja az milo, a mam je pierszy raz i byly to najtansze jakie mieli w sklepie
#11 |
A za jakiś czas będziesz znowu szukał pomocy na forum?? Szkoda czasu dla takich "odkrywców".
#12 | |
Człekokształtny
Data rejestracji: 27.12.2004
chłopak się pobawi i zrozumie.. chyba większość z nas przez to przechodziła.
Seny, pit i collons! |
#13 |
Sense Key: 0x03 (KEY_MEDIUM_ERROR) ...typowy b***322;***261;d dla lipnych p***322;yt.
Jak mądrze zadawać pytania |
#14 |
No cóż stwierdzić pewnych już nie można?? A do zabawy są ciekawsze rzeczy
