Stary 05.02.2007, 22:12   #1
mikiel
Data rejestracji: 05.02.2007
mikiel w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
problem z liteOnem - Błąd w procedurze zapisu!
No wiec, mam problem z zapisem obrazu plyty log jest ponizej
plis help
########################### System Information ###########################
Windows XP Professional 5.1 Dodatek Service Pack. 1 (Build 2600)
Processor info: AMD Athlon(tm) XP 2000+ (1670MHz)
Memory Available to Windows: 523 760 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: Alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2006 Alcohol Soft Development Team
Version: 1.9.6 ( Build 4719 )
Date: 2006/11/20
Hash: acb0e8df5073c1afd4400844a78bbf6c
Loader: c:\windows\explorer.exe
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Company Name: Alcohol Soft Co., Ltd.
Description: Alcohol virtual device control library
Original: alcoholx.dll
Product: Alcohol
Copyright: Copyright (C) 2000-2006
Version: 4.8.0 ( Build 0 )
Date: 2006/11/18
Hash: 83eeec45bf18fbd60c56a2e3a0191057
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Version: 2.5.1 ( Build 2317 )
Date: 2006/11/17
Hash: a0f7ad7f40c6f36e240f295bcc99de20
########################### User Information ###########################
Licensed to: UN-REGISTERED ( 2007-02-04 )
Registered User ID: UN-REGISTERED
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: No
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: Polish
############################ Device(s) List ############################
(E LITEON CD-ROM LTN525 (nvidesm, Port 0, Bus 1, Target 0, Lun 0)
(F LITE-ON DVDRW SHW-16H5S (nvidesm, Port 0, Bus 1, Target 1, Lun 0)
(G RD1170V NBS159L (an47ywen, Port 2, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
a7xmhi9u.SYS ACPI.sys afd.sys amdk7.sys an47ywen.SYS
Aspi32.SYS atapi.sys audstub.sys Beep.SYS BOOTVID.dll
Cdfs.SYS cdrom.sys CLASSPNP.SYS cmuda.sys disk.sys
dmio.sys dmload.sys drmk.sys dump_diskdump.sys dump_nvidesm.sys
Dxapi.sys dxg.sys dxgthk.sys Fastfat.SYS fdc.sys
Fips.SYS flpydisk.sys Fs_Rec.SYS ftdisk.sys gameenum.sys
hal.dll i8042prt.sys imapi.sys ipsec.sys isapnp.sys
kbdclass.sys KDCOM.DLL kmixer.sys ks.sys KSecDD.sys
mnmdd.SYS mouclass.sys MountMgr.sys mrxdav.sys mrxsmb.sys
Msfs.SYS msgpc.sys msmpu401.sys Mup.sys NAVENG.Sys
NavEx15.Sys NDIS.sys ndistapi.sys ndisuio.sys ndiswan.sys
NDProxy.SYS netbios.sys netbt.sys NPDRIVER.SYS Npfs.SYS
ntdll.dll Ntfs.sys ntoskrnl.exe Null.SYS nv_agp.sys
nv4_disp.dll nv4_mini.sys nvidesm.sys parport.sys PartMgr.sys
ParVdm.SYS pci.sys pciide.sys PCIIDEX.SYS portcls.sys
psched.sys ptilink.sys rasacd.sys rasl2tp.sys raspppoe.sys
raspptp.sys raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys
redbook.sys RTL8139.SYS SAVRT.SYS SAVRTPEL.SYS SCSIPORT.SYS
serenum.sys serial.sys sfdrv01.sys sfhlp02.sys sfsync02.sys
sptd.sys sr.sys srv.sys swenum.sys SYMEVENT.SYS
SYMREDRV.SYS SYMTDI.SYS sysaudio.sys tcpip.sys TDI.SYS
termdd.sys update.sys USBD.SYS usbehci.sys usbhub.sys
usbohci.sys USBPORT.SYS vga.sys VIDEOPRT.SYS VolSnap.sys
wanarp.sys watchdog.sys wdmaud.sys win32k.sys WMILIB.SYS
################## Detailed Information of Device(s) ##################
(E LITEON CD-ROM LTN525(0:0) detail information.
Vendor Identification: LITEON
Product Identification: CD-ROM LTN525
Production Revision Level: KL17
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 01h
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Read CD-R Fixed Packet: Yes
Test Write: No
DVD-ROM Read: No
DVD-R Read/Write: No/No
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: No
R-W De-interleaved and Corrected: No
C2 Pointers Support: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
(F LITE-ON DVDRW SHW-16H5S(0:1) detail information.
Vendor Identification: LITE-ON
Product Identification: DVDRW SHW-16H5S
Production Revision Level: LS0W
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: SMART-BURN
Auto-Select best write speed: SMART-BURN
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: Yes
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
(G RD1170V NBS159L(2:0) detail information.
Vendor Identification: RD1170V
Product Identification: NBS159L
Production Revision Level: 1.0
Version: ANSI X3.131:1994 (SCSI-2)
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
P through W in Lead-In: No
###################### Source Disc/Image Information ######################
Typ: Plik obrazu Media Descriptor
Ścieżka: C:\Documents and Settings\Tomek\Pulpit\
Nazwa: etherlords2.MDS
etherlords2.mdf
Rozmiar: 4478.97 MB
Ilość sesji: 1
Ilość ścieżek: 1
Sesja 01:
Ścieżka 01: DVD, Rozmiar: 2293232(4.37 GB), Adres: 000000
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 2007-02-05 21:09:42 *********
21:09:42 Procesor: AMD Athlon(tm) XP 2000+ (1670MHz)
21:09:42 Pamięć dostępna dla systemu: 523 760 KB
21:09:42 Rozmiar bufora pamięci: 4 MB
21:09:42 Ładowanie obrazu płyty: C:\Documents and Settings\Tomek\Pulpit\etherlords2.MDS
21:09:42 DVD Informacje o źródle: Sesja: 1, Ścieżka: 1, Rozmiar: 4.37 GB / 509:36:32
21:09:42 (F LITE-ON DVDRW SHW-16H5S(0:1): Tryb zapisu/Prędkość
21:09:42 Nieprawdiłowa prędkość 8.0X (11080 KB/s) dla tego nośnika, ustawiona prędkość 3.2X (4432 KB/s)
21:09:42 Zapis - DVD DAO - 3.2X (4432 KB/s)
(F LITE-ON DVDRW SHW-16H5S(0:1) - Media format: DVD+R
21:10:04 (F LITE-ON DVDRW SHW-16H5S(0:1) - [Write ERROR] LBA: 0, Length: 16
S:KEY - 00/00/00 - "No Additional Sense Information"
21:10:08 (F LITE-ON DVDRW SHW-16H5S(0:1): Zapis nie powiódł się!
21:10:08 Ładowanie obrazu płyty przerwane!
21:10:12 Błąd w procedurze zapisu! Sprawdź plik z logiem i wyślij informacje o błędach do Pomocy Technicznej.
mikiel jest offline   Odpowiedz cytując ten post
Stary 05.02.2007, 22:32   #2
http://forum.cdrinfo.pl/search.php?searchid=1191191
http://forum.cdrinfo.pl/showthread.p...se+Information
Czy tak si***281; dzieje na ka***380;dym no***347;niku?
Stary 05.02.2007, 23:32   #3
mikiel
No dobra ale nie moge znalesc dokladnie tego moje problemu;/ moze ktos mi pomodz?
Wszystkie czasy w strefie CET. Aktualna godzina: 19:23.
