Stary 08.09.2005, 11:39   #1
luzi
Data rejestracji: 08.09.2005
luzi w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Liteon 523252 problem pomocy
Hej mam takiego liteona 1,5roku i teraz się zepsuło coś.Czyta płyty ale nie wszystkie,nie rozpędza się wogóle nagrywanie tez sie zepsuło Wklęje loga z nero moze cos wyczytacie z niego
Lucek
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\PROGRA~1\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:34
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15h
Recorder: <LITE-ON LTR-52327S> Version: QS0E - HA 0 TA 1 - 6.6.0.15
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 2 TA 0 - 6.6.0.15
Adapter driver: <d347prt> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0411N atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON LTR-52327S atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON LTR-52327S D: CDRom0
Generic DVD-ROM E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 28311552 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 159MB (163312kB)
Free physical memory: 51MB (52320kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
8.9.2005
CD-ROM (ISO)
10:19:33 #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
10:19:33 #2 Text 0 File Burncd.cpp, Line 2946
LITE-ON LTR-52327S
Buffer underrun protection activated
10:19:33 #3 Text 0 File Reader.cpp, Line 127
Reader running
10:19:33 #4 Text 0 File Writer.cpp, Line 122
Writer LITE-ON LTR-52327S running
10:19:33 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
10:19:33 #6 Text 0 File Burncd.cpp, Line 3231
Turn on Track-At-Once, using CD-R/RW media
10:19:34 #7 Text 0 File DlgWaitCD.cpp, Line 269
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 346026 ( 76:55.51)
10:19:34 #8 Text 0 File DlgWaitCD.cpp, Line 281
10:19:35 #9 Text 0 File DlgWaitCD.cpp, Line 2477
Recorder: LITE-ON LTR-52327S;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
10:19:35 #10 Text 0 File DlgWaitCD.cpp, Line 447
10:19:35 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 346027 (346027) = #346027/76:53.52
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 346025 blocks [LITE-ON LTR-52327S]
10:19:35 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [LITE-ON LTR-52327S] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 708970496, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
346027 | lead-out | 1 | 0x41 | 0x00
10:19:35 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 346027 -> 346025.
10:19:36 #14 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
10:19:36 #15 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
10:19:36 #16 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
10:19:36 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 52x (7 800 KB/s)
10:19:37 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643
10:19:37 #19 Text 0 File Mmc.cpp, Line 21663
Set BUFE: Buffer underrun protection -> ON , SMART-BURN : ON
10:20:52 #20 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03E60000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0xAC 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
10:20:52 #21 CDR -1135 File Writer.cpp, Line 311
Write error
10:20:52 #22 Text 0 File ThreadedTransfer.cpp, Line 228
10:20:53 #23 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
10:20:53 #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
LITE-ON LTR-52327S\H0 T1
10:20:53 #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
10:20:53 #26 Text 0 File Mmc.cpp, Line 16311
<LITE-ON LTR-52327S > start Close Session
10:21:50 #27 SCSI -1176 File Cdrdrv.cpp, Line 1182
Sense Code: 0x72
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x00
10:21:50 #28 CDR -1176 File WriterStatus.cpp, Line 249
Session fixation error
10:21:50 #29 TRANSFER -19 File WriterStatus.cpp, Line 249
Could not perform Fixation
10:21:50 #30 Text 0 File WriterStatus.cpp, Line 258
falling back to disc fixation
10:21:53 #31 Text 0 File Mmc.cpp, Line 16311
10:21:53 #32 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 52x (7 800 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 23:51:54 (Adapter driver for rec)
File 'Drivers\d347prt.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 2004-08-22 16:31:48 (Adapter driver for src)
Registry Keys:
Ostatnio zmieniany przez Y@nkee_PL : 13.09.2005 o godz. 11:38
luzi jest offline
Stary 09.09.2005, 12:22   #2
luzi
Nikt nie pomoze??
luzi jest offline
Stary 09.09.2005, 13:49   #3
Wojtek Toruń
Jak może to pomoże
Data rejestracji: 02.02.2003
Wojtek Toruń zaczyna zdobywać reputację <1 - 49 pkt>
A może przydałoby się czyszczenie soczewki lasera ?
Przez 1.5 roku mogła się zakurzyć.
No chyba że jeszcze gwara to nie zrywać plomb i serwisik.
Wojtek Toruń jest offline
Stary 09.09.2005, 13:55   #4
MacGyver
Team Member
Avatar użytkownika MacGyver
Data rejestracji: 14.05.2002
Spróbuj jeszcze nagrać na lepszym nośniku z mniejszą prędkością.
MacGyver jest offline
Stary 09.09.2005, 14:18   #5
andy
logged out
Avatar użytkownika andy
Data rejestracji: 12.07.2003
Zawsze staraj się nagrywać mniejszą prędkością.
Czyżby problem z fiksacją?
andy jest offline
Stary 09.09.2005, 19:07   #6
luzi
Czyszczenie nic nie daje juz probowałem.Nagrywanie na innych prędkościach czy na innych nośnikach to samo czyli "fixation error"
luzi jest offline
Stary 09.09.2005, 21:30   #7
Piterniel
Cichy mod
Avatar użytkownika Piterniel
Data rejestracji: 16.03.2003
Czytaj sobie topic o fiksacji!
http://forum.cdrinfo.pl/showthread.php?t=28567
Piterniel jest offline
Stary 12.09.2005, 22:05   #8
luzi
Probuję i dalej nie działa:/ Zmiana firmware,zmiana aspi,odinstaowanie nero,odinstalowanie ide i ponowna instalacja według wskazówek z tego forum,włączenie dma i dalej to samo :/Probowałem nagrywac u kumpla to nie było błędu odczytywała tez szybko a u mnie lipton.Co robic??
luzi jest offline
Stary 12.09.2005, 22:17   #9
Piterniel
Cichy mod
Serwis
Stary 12.09.2005, 22:56   #10
Pawel_k
User
Avatar użytkownika Pawel_k
Data rejestracji: 25.09.2002
moze kontroler ide jest szczelony
nie bedzie niczego
Pawel_k jest offline
Stary 12.09.2005, 22:59   #11
luzi
Hmm wiem zostaje serwis i znów problem :/ Gwarancje mam do 1 stycznia 2006 tylko ze sklep w ktorym kupiłem nagrywarke juz zlikwidowali:/Ale gwarancji udziela przeciez dystrybutor liteon'a a nie ten sklep-tak mi sie zdaje ale pewnie się mylę znów nie wiem co robić :/
A co do kontrolera IDE to jak poznac ze jest zepsuty??Teraz podpiąłem nagrywarke na drugim ale dalej to samo:/
Ostatnio zmieniany przez luzi : 12.09.2005 o godz. 23:02
luzi jest offline
Stary 12.09.2005, 23:03   #12
Pawel_k
User
przepnij nagrywarke na kanal gdzie masz dysk twardy, skoro u kolegi dziala dobrze to zapewne cos na plycie glownej strzelilo
nie bedzie niczego
Stary 13.09.2005, 10:48   #13
luzi
Ale wcześniej miałem podpiętą na tym głownym kontrolerze razem z dyskiem i było to samo :/ Musze zrobić format bo mam juz taki syf w kompie ze szkoda gadac.Napiszcie co i w jakiej kolejności instalować po formacie.Dzieki za dotychczasową pomoc.
luzi jest offline
Stary 13.09.2005, 12:52   #14
Pawel_k
User
a wiec tak windows xp -> service pack 2 -> sterowniki do plyty gownej -> inne sterowniki sprzetu -> antwirus -> firewall -> aplikacje
jak po formacie dalej beda problemy to chyba zostaje wymiana plyty glownej
nie bedzie niczego
Wszystkie czasy w strefie CET. Aktualna godzina: 22:47.
