Data rejestracji: 08.09.2005
Liteon 523252 problem pomocy
Hej mam takiego liteona 1,5roku i teraz się zepsuło coś.Czyta płyty ale nie wszystkie,nie rozpędza się wogóle nagrywanie tez sie zepsuło
Wklęje loga z nero moze cos wyczytacie z niego ![]() Lucek ***-***... Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\PROGRA~1\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:34 Nero Version: 6.6.0.15 Internal Version: 6, 6, 0, 15h Recorder: <LITE-ON LTR-52327S> Version: QS0E - HA 0 TA 1 - 6.6.0.15 Adapter driver: <atapi> HA 0 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 2 TA 0 - 6.6.0.15 Adapter driver: <d347prt> HA 2 === Scsi-Device-Map === DiskPeripheral : SAMSUNG SP0411N atapi Port 0 ID 0 DMA: On CdRomPeripheral : LITE-ON LTR-52327S atapi Port 0 ID 1 DMA: Off CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off === CDRom-Device-Map === LITE-ON LTR-52327S D: CDRom0 Generic DVD-ROM E: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 28311552 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 159MB (163312kB) Free physical memory: 51MB (52320kB) Memory in use : 67 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 8.9.2005 CD-ROM (ISO) 10:19:33 #1 Text 0 File Isodoc.cpp, Line 6314 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 10:19:33 #2 Text 0 File Burncd.cpp, Line 2946 LITE-ON LTR-52327S Buffer underrun protection activated 10:19:33 #3 Text 0 File Reader.cpp, Line 127 Reader running 10:19:33 #4 Text 0 File Writer.cpp, Line 122 Writer LITE-ON LTR-52327S running 10:19:33 #5 ISO9660GEN -11 File geniso.cpp, Line 3309 First writeable address = 0 (0x00000000) 10:19:33 #6 Text 0 File Burncd.cpp, Line 3231 Turn on Track-At-Once, using CD-R/RW media 10:19:34 #7 Text 0 File DlgWaitCD.cpp, Line 269 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 346026 ( 76:55.51) 10:19:34 #8 Text 0 File DlgWaitCD.cpp, Line 281 Write in overburning mode: NO (enabled: CD) 10:19:35 #9 Text 0 File DlgWaitCD.cpp, Line 2477 Recorder: LITE-ON LTR-52327S; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid) 10:19:35 #10 Text 0 File DlgWaitCD.cpp, Line 447 >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:19:35 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 346027 (346027) = #346027/76:53.52 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 346025 blocks [LITE-ON LTR-52327S] -------------------------------------------------------------- 10:19:35 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043 Prepare recorder [LITE-ON LTR-52327S] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 708970496, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 346027 | lead-out | 1 | 0x41 | 0x00 10:19:35 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111 Removed 2 run-out blocks from end of track 1. Length: 346027 -> 346025. 10:19:36 #14 Phase 24 File dlgbrnst.cpp, Line 1832 Caching of files started 10:19:36 #15 Text 0 File Burncd.cpp, Line 4116 Cache writing successful. 10:19:36 #16 Phase 25 File dlgbrnst.cpp, Line 1832 Caching of files completed 10:19:36 #17 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 52x (7 800 KB/s) 10:19:37 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 10:19:37 #19 Text 0 File Mmc.cpp, Line 21663 Set BUFE: Buffer underrun protection -> ON , SMART-BURN : ON 10:20:52 #20 SCSI -1135 File Cdrdrv.cpp, Line 1436 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03E60000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0xAC 0x60 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x0C 0x00 10:20:52 #21 CDR -1135 File Writer.cpp, Line 311 Write error 10:20:52 #22 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:20:53 #23 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 10:20:53 #24 CDR -201 File WriterStatus.cpp, Line 200 Invalid write state LITE-ON LTR-52327S\H0 T1 10:20:53 #25 TRANSFER -18 File WriterStatus.cpp, Line 200 Could not perform EndTrack 10:20:53 #26 Text 0 File Mmc.cpp, Line 16311 <LITE-ON LTR-52327S > start Close Session 10:21:50 #27 SCSI -1176 File Cdrdrv.cpp, Line 1182 SCSI Exec, HA 0, TA 1, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x72 Sense Qual: 0x00 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x72 0x00 10:21:50 #28 CDR -1176 File WriterStatus.cpp, Line 249 Session fixation error 10:21:50 #29 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 10:21:50 #30 Text 0 File WriterStatus.cpp, Line 258 falling back to disc fixation 10:21:53 #31 Text 0 File Mmc.cpp, Line 16311 <LITE-ON LTR-52327S > start Close Session 10:21:53 #32 Phase 38 File dlgbrnst.cpp, Line 1832 Burn process failed at 52x (7 800 KB/s) Existing drivers: File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 23:51:54 (Adapter driver for rec) File 'Drivers\d347prt.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 2004-08-22 16:31:48 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Ostatnio zmieniany przez Y@nkee_PL : 13.09.2005 o godz. 11:38 |
Nikt nie pomoze??
Jak może to pomoże
Data rejestracji: 02.02.2003
A może przydałoby się czyszczenie soczewki lasera ?
Przez 1.5 roku mogła się zakurzyć. No chyba że jeszcze gwara to nie zrywać plomb i serwisik. |
Team Member
![]() Data rejestracji: 14.05.2002
Spróbuj jeszcze nagrać na lepszym nośniku z mniejszą prędkością.
#5 | ||
logged out
Data rejestracji: 12.07.2003
Czyszczenie nic nie daje juz probowałem.Nagrywanie na innych prędkościach czy na innych nośnikach to samo czyli "fixation error"
Cichy mod
Data rejestracji: 16.03.2003
Czytaj sobie topic o fiksacji!
http://forum.cdrinfo.pl/showthread.php?t=28567
lite [at] jabber.gda.pl Ciekawy blog LiTEa <-- Click | Jak utrzymać się na stronie torrentowej ![]() Jak używac google ? | Lite-on 52327S | BenQ DW1640@EW164B Zanim zadasz pytanie - przeczytaj! [v1.0] | Jak odwiesic CD w Nero? Typ folderow w XP, rejestr | Konto w XP do gier TIMEOUT w autostart | O-T-W-I-E-R-A-M-Y |
Probuję i dalej nie działa:/ Zmiana firmware,zmiana aspi,odinstaowanie nero,odinstalowanie ide i ponowna instalacja według wskazówek z tego forum,włączenie dma i dalej to samo :/Probowałem nagrywac u kumpla to nie było błędu odczytywała tez szybko a u mnie lipton.Co robic??
Cichy mod
Serwis
User
Data rejestracji: 25.09.2002
moze kontroler ide jest szczelony
nie bedzie niczego |
#11 |
Hmm wiem zostaje serwis i znów problem :/ Gwarancje mam do 1 stycznia 2006 tylko ze sklep w ktorym kupiłem nagrywarke juz zlikwidowali:/Ale gwarancji udziela przeciez dystrybutor liteon'a a nie ten sklep-tak mi sie zdaje ale pewnie się mylę znów nie wiem co robić :/
A co do kontrolera IDE to jak poznac ze jest zepsuty??Teraz podpiąłem nagrywarke na drugim ale dalej to samo:/ Ostatnio zmieniany przez luzi : 12.09.2005 o godz. 23:02 |
#12 |
User
przepnij nagrywarke na kanal gdzie masz dysk twardy, skoro u kolegi dziala dobrze to zapewne cos na plycie glownej strzelilo
#13 |
Ale wcześniej miałem podpiętą na tym głownym kontrolerze razem z dyskiem i było to samo :/ Musze zrobić format bo mam juz taki syf w kompie ze szkoda gadac.Napiszcie co i w jakiej kolejności instalować po formacie.Dzieki za dotychczasową pomoc.
#14 |
User
a wiec tak windows xp -> service pack 2 -> sterowniki do plyty gownej -> inne sterowniki sprzetu -> antwirus -> firewall -> aplikacje
jak po formacie dalej beda problemy to chyba zostaje wymiana plyty glownej
