Stary 13.03.2004, 00:34   #1
mani
Data rejestracji: 12.03.2004
mani zaczyna zdobywać reputację <1 - 49 pkt>
Mam wielki problem z Teacem :( - Power calibration error
Jesli ktos wiec niech mi pomoze. Podaje log:
Joanna Miklewska
Akademia Rolnicza
1A23-0004-9030-1877-1057-5511
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06
Nero version: 6.3.0.2
Recorder: <TEAC DW-224E> Version: 1.0A - HA 1 TA 0 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 1658kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <TEAC DW-224E >Version: 1.0A - HA 1 TA 0 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : IC25N040ATCS04-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TEAC DW-224E atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : Generic STEALTH DVD st3wolf Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
TEAC DW-224E E: CDRom0
Generic STEALTH DVD F: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 32505856 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 189MB (194032kB)
Free physical memory: 36MB (36916kB)
Memory in use : 80 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
12.3.2004
CD-ROM (ISO)
23:21:55 #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
23:21:55 #2 Phase 75 File dlgbrnst.cpp, Line 1800
JustLink activated
23:21:55 #3 Text 0 File Reader.cpp, Line 118
Reader running
23:21:55 #4 Text 0 File Writer.cpp, Line 124
Writer TEAC DW-224E running
23:21:55 #5 ISO9660GEN -11 File geniso.cpp, Line 3882
23:21:56 #6 Text 0 File Burncd.cpp, Line 3101
Turn on Track-at-once, using CD-R/RW media
23:21:59 #7 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 348911 ( 77:34.11)
23:21:59 #8 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
23:21:59 #9 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: TEAC DW-224E;
CDR code: 00 97 24 11; OSJ entry from: SONY Corporation
ATIP Data:
Special Info [hex] 1: D0 40 98, 2: 61 18 0B (LI 97:24.11), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
23:21:59 #10 Text 0 File DlgWaitCD.cpp, Line 406
Insert the disc to write to.
(Medium in drive: CD-R. Medium required by compilation: CD-R/RW.)
23:21:59 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 348912 (348912) = #348912/77:32.12
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 348910 blocks [TEAC DW-224E ]
23:21:59 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [TEAC DW-224E ] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 714878976, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
348912 | lead-out | 1 | 0x00 | 0x41
23:21:59 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994
Removed 2 run-out blocks from end of track 1. Length: 348912 -> 348910.
23:22:00 #14 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
23:22:00 #15 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
23:22:00 #16 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
23:22:00 #17 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (600 KB/s)
23:22:00 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264
23:22:00 #19 Text 0 File Mmc.cpp, Line 19451
Set BUFE: JustLink -> ON
23:22:23 #20 SCSI -1106 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x06F70000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
23:22:23 #21 CDR -1106 File Writer.cpp, Line 301
23:22:23 #22 Text 0 File ThreadedTransfer.cpp, Line 229
23:22:23 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
23:22:23 #24 CDR -201 File WriterStatus.cpp, Line 196
Invalid write state
TEAC DW-224E\H1 T0
23:22:23 #25 TRANSFER -18 File WriterStatus.cpp, Line 196
Could not perform EndTrack
23:22:24 #26 Text 0 File Mmc.cpp, Line 14287
<TEAC DW-224E > start Close Session
23:22:24 #27 SCSI -1176 File Cdrdrv.cpp, Line 1171
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x04
23:22:24 #28 CDR -1176 File WriterStatus.cpp, Line 245
Session fixation error
23:22:24 #29 TRANSFER -19 File WriterStatus.cpp, Line 245
Could not perform Fixation
23:22:24 #30 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
23:22:24 #31 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
23:22:24 #32 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (600 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2003-10-28 11:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.5376, size=86704 bytes, created 2000-08-08 08:08:00 (Adapter driver for rec)
Registry Keys:
Po prostu nie wiem co robic, nagrywalem na kilku plytach, pliki po 1mg nawet na predkosci 4x i nic, zawsze ten sam problem.
Otoz ta nagrywarka jest w laptopie, kiedys mi dzialala, ale cos sie skopalo .
Prosze o pomoc.
mani jest offline
Stary 13.03.2004, 02:15   #2
Y@nkee_PL
Maciek: Reaktywacja
Avatar użytkownika Y@nkee_PL
Data rejestracji: 18.11.2002
ahh ta fiksacja
w wyszukiwarce wpisz FIKSACJA
jeden z wynikow:
http://forum.cdrinfo.pl/showthread.php?t=28567
Y@nkee_PL jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 02:44.
