Yamaha CRW-F1 2002r.
Odczyt CD-ROM\ zapis CD-R 650\700MB
Maxell Music XL-II 80 AudioCD-R Ritek MID:97m15s17f Made in China
Yamaha CRW-F1 fw..1.0g ImgBurn 2.5.8.0 x8 W przypadku błędów E12 sprzęt "wymiata " ![]() log : Kod:
I 13:53:58 ImgBurn Version 2.5.8.0 started! I 13:53:58 Microsoft Windows 8 Professional x64 Edition (6.2, Build 9200) I 13:53:58 Total Physical Memory: 4*189*108 KiB - Available: 1*873*160 KiB I 13:53:58 Initialising ElbyCDIO... I 13:53:58 ELBYCDIO.DLL - Elaborate Bytes CDRTools - ElbyCDIO DLL - Version 6.1.9.1 I 13:53:58 Searching for SCSI / ATAPI devices... I 13:53:58 -> Drive 1 - Info: HL-DT-ST DVDRAM GT30N 1.01 (D:) (ATAPI) I 13:54:00 -> Drive 2 - Info: YAMAHA CRW-F1E 1.0g (F:) (USB) I 13:54:00 Found 1 CD-RW and 1 DVD***177;RW/RAM! I 13:55:20 Operation Started! I 13:55:20 Building Image Tree... I 13:55:21 Checking Directory Depth... I 13:55:21 Calculating Totals... I 13:55:21 Preparing Image... I 13:55:22 Checking Path Length... I 13:55:22 Contents: 4 Files, 0 Folders I 13:55:22 Content Type: Data I 13:55:22 Data Type: MODE1/2048 I 13:55:22 File System(s): ISO9660, UDF (1.02) I 13:55:22 Volume Label: Nero 9-10 iso Plex PREM Nero 5,5 I 13:55:22 Size: 590*061*144 bytes I 13:55:22 Sectors: 288*118 I 13:55:22 Image Size: 590*643*200 bytes I 13:55:22 Image Sectors: 288*400 I 13:55:23 Operation Successfully Completed! - Duration: 00:00:03 I 13:55:23 Operation Started! I 13:55:23 Source File: -==/\/[BUILD IMAGE]\/\==- I 13:55:24 Source File Sectors: 288*400 (MODE1/2048) I 13:55:24 Source File Size: 590*643*200 bytes I 13:55:24 Source File Volume Identifier: Nero 9-10 iso Plex PREM Nero 5,5 I 13:55:24 Source File Volume Set Identifier: 4AD66EEA00046682 I 13:55:24 Source File Application Identifier: IMGBURN V2.5.8.0 - THE ULTIMATE IMAGE BURNER! I 13:55:24 Source File Implementation Identifier: ImgBurn I 13:55:24 Source File File System(s): ISO9660; UDF (1.02) I 13:55:24 Destination Device: [0:0:0] YAMAHA CRW-F1E 1.0g (F:) (USB) I 13:55:24 Destination Media Type: CD-R (Disc ID: 97m15s17f, Ritek Co.) I 13:55:24 Destination Media Sectors: 359*843 I 13:55:24 Write Mode: CD I 13:55:24 Write Type: SAO I 13:55:24 Write Speed: 8x I 13:55:24 Lock Volume: Yes I 13:55:24 Test Mode: No I 13:55:24 OPC: Yes I 13:55:24 BURN-Proof: Enabled I 13:55:24 Write Speed Successfully Set! - Effective: 1*411 KB/s (8x) I 13:55:34 Filling Buffer... (513 MiB) I 13:55:40 Writing LeadIn... I 13:56:03 Writing Session 1 of 1... (1 Track, LBA: 0 - 288399) I 13:56:03 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 288399) I 14:03:58 Synchronising Cache... I 14:04:15 Exporting Graph Data... I 14:04:15 Graph Data File: C:\Users\czary2mary\AppData\Roaming\ImgBurn\Graph Data Files\YAMAHA_CRW-F1E_1.0g_22-CZERWIEC-2017_13-55_97m15s17f_8x.ibg I 14:04:15 Export Successfully Completed! I 14:04:15 Operation Successfully Completed! - Duration: 00:08:51 I 14:04:16 Average Write Rate: 1*216 KiB/s (7.1x) - Maximum Write Rate: 1*232 KiB/s (7.2x) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Maxell Music Printable CD-R Audio ATIP\MID 97m17s09f tłocznia Moser Baer
Yamaha CRW-F1 fw..1.0g Feurio x Advanced Audio Master Quality Recording (x4) Z testem discquality z tak nagraną płytą na wielu urządzeniach jest problem - wszystkie BenQDW1620\1625\1640\1650\1655 - zawieszają ten w losowych miejscach , nowsze modele na chipsetach MediaTek w programach testujących widzą "cuda" ale płyta w stacjonarnym sprzęcie działa idealnie . Oczywiście przyczyną są wydłużone maksymalnie pity i landy przez co na wiele napędów źle to interpretuje . ![]() Maxell Music Printable CD-R Audio ATIP\MID 97m17s09f tłocznia Moser Baer Yamaha CRW-F1 fw..1.0g Feurio x Advanced Audio Master Quality Recording (x4) ![]() ![]() ![]() ![]() ![]() ![]()
#5 | |
Udało się zrobić test discquality na BenQ DW1640 z firmware BSLB w Nero Speed Disc . W Opti Drive Control dalej losowo błąd testu. ![]() ![]()
PlexDisc MEDICAL DISC CD-R Printable CMC Magnetic Tajwan ATIP:97m26s66f
Yamaha CRW-F1 fw..1.0g ImgBurn 2.5.8.0 x8 ![]() ![]() ![]() ![]() ![]() ![]()
Memorex Music CD-R AUDIO 700MB CMC Magnetic 97m26s66f
Yamaha CRW-F1 fw..1.0g Nero 5.5 Edycja specjalna Yamaha- Advanced Audio Master Quality Recording x8 ![]() ![]() ![]() ![]() ![]()
JVC CD-R Music CD-R Audio Taiyo Yuden Made in Japan ATIP\MID: 97m24s01f
Yamaha CRW-F1 fw..1.0g Nero 5.5 Edycja specjalna Yamaha- Advanced Audio Master Quality Recording x4 ![]() ![]() ![]() ![]() ![]()
![]() Data rejestracji: 21.02.2014
Jak ona pali!
#11 |
#12 |
| CRW F1 do użytkowników i nie tylko | walu | Napędy optyczne CD | 1 | 31.08.2003 00:03 |
| Yamaha F1 i super niska cena... ?? | Martin_TP | Napędy optyczne CD | 23 | 11.01.2003 11:46 |
| YAMAHA CRW F1 NOWY Firmware | zorg | Napędy optyczne CD | 0 | 05.10.2002 05:20 |
| yamaha crw f1 | gips | Napędy optyczne CD | 0 | 13.09.2002 19:18 |
| yamaha crw f1 | gips | Napędy optyczne CD | 4 | 06.09.2002 11:41 |
