Data rejestracji: 23.09.2008
1C80-0000-19E5-MA2X-4006-8055-****
Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 Recorder: <SAMSUNG CD-R/RW SW-224B> Version: R205 - HA 1 TA 0 - 7.10.1.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <SAMSUNG CD-R/RW SW-224B >Version: R205 - HA 1 TA 0 - 7.10.1.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : Maxtor 32049H2 atapi Port 0 ID 1 DMA: On CdRomPeripheral : SAMSUNG CD-R/RW SW-224B atapi Port 1 ID 0 DMA: On === CDRom-Device-Map === SAMSUNG CD-R/RW SW-224B E: CdRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 1279MB (1310196kB) Free physical memory: 877MB (898724kB) Memory in use : 31 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 24.9.2008 CD-ROM (ISO) 12:23:54 #1 Text 0 File SCSIPTICommands.cpp, Line 424 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 12:23:55 #2 Text 0 File Isodoc.cpp, Line 6666 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : TRUE Write : TRUE Finalize CD : FALSE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 12:23:55 #3 Text 0 File Burncd.cpp, Line 3196 SAMSUNG CD-R/RW SW-224B Włączono JustLink 12:23:55 #4 ISO9660GEN -11 File Geniso.cpp, Line 3343 First writeable address = 0 (0x00000000) 12:23:55 #5 Text 0 File Burncd.cpp, Line 3508 Turn on Track-At-Once, using CD-R/RW media 12:23:55 #6 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 358616 ( 79:43.41) 12:23:55 #7 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 12:23:55 #8 Text 0 File DlgWaitCD.cpp, Line 2972 Recorder: SAMSUNG CD-R/RW SW-224B; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: ? 12:23:55 #9 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 12:23:55 #10 Text 0 File ThreadedTransferInterface.cpp, Line 793 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 358617 (358617) = #358617/79:41.42 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358615 blocks [E: SAMSUNG CD-R/RW SW-224B] -------------------------------------------------------------- 12:23:56 #11 Text 0 File ThreadedTransferInterface.cpp, Line 995 Prepare [E: SAMSUNG CD-R/RW SW-224B] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 734754816, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 -150 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 358617 | 0 | 0x00 358617 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 12:23:56 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1066 Removed 2 run-out blocks from end of track 1. Length: 358617 -> 358615. 12:23:56 #13 Text 0 File SCSIPTICommands.cpp, Line 215 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 12:23:56 #14 Text 0 File Burncd.cpp, Line 4294 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 12:23:56 #15 Phase 24 File dlgbrnst.cpp, Line 1762 Caching of files started 12:23:56 #16 Text 0 File Burncd.cpp, Line 4413 Cache writing successful. 12:23:56 #17 Phase 25 File dlgbrnst.cpp, Line 1762 Caching of files completed 12:23:56 #18 Phase 32 File dlgbrnst.cpp, Line 1762 Simulation started at 24x (3 600 KB/s) 12:23:56 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 12:23:56 #20 Text 0 File MMC.cpp, Line 22363 Set BUFE: JustLink -> ON 12:23:56 #21 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 12:34:10 #22 Phase 33 File dlgbrnst.cpp, Line 1762 Simulation completed successfully at 24x (3 600 KB/s) 12:34:11 #23 Phase 36 File dlgbrnst.cpp, Line 1762 Burn process started at 24x (3 600 KB/s) 12:34:11 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 12:34:11 #25 Text 0 File MMC.cpp, Line 22363 Set BUFE: JustLink -> ON 12:34:11 #26 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 12:36:40 #27 SPTI -1135 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 00 00 03 22 C0 00 00 20 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C Buffer x05e50840: Len x10000 0xED 43 F1 E1 4C 8D E5 77 BB 18 A5 86 69 D8 F9 2D 0x91 42 02 22 6C CD B1 73 21 43 44 37 B3 2E 5D 72 0xC6 B8 4A 15 69 42 CB 16 7D DA 98 69 C8 9C 6A 0A 12:36:40 #28 CDR -1135 File Writer.cpp, Line 303 Write error E: SAMSUNG CD-R/RW SW-224B 12:36:40 #29 CDR -201 File WriterStatus.cpp, Line 195 Invalid write state E: SAMSUNG CD-R/RW SW-224B 12:36:40 #30 TRANSFER -18 File WriterStatus.cpp, Line 195 Could not perform EndTrack 12:36:40 #31 Text 0 File MMC.cpp, Line 17131 <SAMSUNG CD-R/RW SW-224B > start Close Session 12:37:07 #32 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 24x (3 600 KB/s) 12:37:07 #33 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 12:37:10 #34 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 12:37:10 #35 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Dodam ze symulacja przechodzi pomyslnie ![]() |
Problem Samsung SHW08A | Mufas | Napędy optyczne DVD | 6 | 27.04.2008 18:49 |
Benq dw 1640 problem z nagrywaniem CD | Fso | Napędy optyczne DVD | 3 | 16.11.2006 22:52 |
problem z nagrywaniem plyt audio na HP 8x | kornol | Napędy optyczne CD | 0 | 11.12.2001 22:36 |
Problem z nagrywaniem plyt na Plextor W1610A | Tomasz Wrzesinski | Napędy optyczne CD | 1 | 17.11.2001 17:32 |
Mam problem z nagrywaniem mp3 w Nero oraz w Easy CD Creator 5 | El Force | Napędy optyczne CD | 4 | 30.10.2001 07:14 |
