Stary 17.08.2025, 04:50   #1
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Ritek Archival Grade 4x BD-R
Test burn @ 4x on BDR-PR1CPB with OPC=no.
Stary 17.08.2025, 09:11   #2
@Is Jadburner the American release?
The Japanese version has slightly different graphics, with the logo.
The disc is manufactured using Panasonic MEIT02 BD-R 25GB technology, using Panasonic machines and materials purchased by RItek Conexx when MEI discontinued Blu-ray disc production. MID codes were not purchased because they have their own registered RITEKBR/DR/TL.
The disc has also passed certification by the Japanese Archive Center Test Center association.
Stary 22.08.2025, 20:25   #3
pepst
Data rejestracji: 15.02.2010
pepst niedługo stanie się sławny ;) <50 - 149 pkt>pepst niedługo stanie się sławny ;) <50 - 149 pkt>
Załącznik 215049
Załącznik 215050
Załącznik 215051
I didn't know that Ritek bought machinery and process know-how from Panasonic. Thanks for the info.
pepst jest offline   Odpowiedz cytując ten post
Stary 17.08.2025, 19:35   #4
jadburner
Yes, the first photo you included is what mine look like. If they're made using Panasonic's process and materials, I would have hoped for better results.
Stary 28.10.2025, 10:23   #5
The same media in the JVC edition
JVC BD-R 25GB 6X ARCHIVAL PRINTABLE WATERPROOF PHOTO GLOSS
Pioneer BDR-PR1 ML fw.1.75
AnyBurn 6.6 x 4
Stary 22.08.2025, 20:24   #6
pepst
Thanks for the test. Where did you manage to buy it?
Stary 23.08.2025, 00:07   #7
jadburner
Napisany przez pepst Podgląd Wiadomości
Greetings, pepst. I bought mine from eBay. They now also have Ritek archival DVD-R and BD-R DL. I will be testing them soon.
Stary 08.09.2025, 11:26   #8
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
Could you please share vinpower's scan of this new RITEK if you have
Stingray jest offline   Odpowiedz cytując ten post
Stary 08.09.2025, 19:19   #9
jadburner
Napisany przez Stingray Podgląd Wiadomości
Sorry, I didn't make a VPTools scan of this test burn.
Stary 15.09.2025, 01:31   #10
Brukernavn
Data rejestracji: 21.08.2023
Brukernavn w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Any chance for a disc quality scan with OptiDriveControl as well ?
For quick and easy comparison.
(I am struggling to interpret that PioneerErrorRateUtility data)
PS: And then there are these, who every seller seems to claim are 'archival grade', but I see no trace of that mentioned on the spindle/name ?
https://www.amazon.com/Ritek-Archiva...dp/B0C3SNB2FV/
And at 'only' $125, seems relatively cheap vs those 25GB ones (?)
Ostatnio zmieniany przez Brukernavn : 15.09.2025 o godz. 02:38
Brukernavn jest offline   Odpowiedz cytując ten post
Stary 15.09.2025, 07:08   #11
jadburner
Napisany przez Brukernavn Podgląd Wiadomości
Not for this particular burn, but I will be posting some new scans from this same spindle later in the week using a different drive. They will include ODC scans.
Stary 15.09.2025, 22:20   #12
Brukernavn
Thankyou!
Stary 15.09.2025, 07:12   #13
jadburner
Those are RITEK-TL2 BDXL discs. You can find several scans of them in the forums. They burn reasonably well, but not great.
Stary 15.09.2025, 22:20   #14
Brukernavn
Ah, so not really 'Archival grade' then I take it.
Really annoying that all the sellers (incl Amazon themselves) then misinform about this so badly, even if the label on the spindle clearly does not back this up. (compared to the 25GB archival ones, I mean)
Stary 01.03.2026, 13:36   #15
DennisOlof
Avatar użytkownika DennisOlof
Data rejestracji: 25.06.2023
DennisOlof w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Smile
I recently found this media and I am wondering if this would be better than Verbatim M-Disc media. I am talking about the "Ritek Archival Grade 4x BD-R" media and not DL discs.
It seems that some hardware like Lite-On have problems reading back M-Disc media.
DennisOlof jest offline   Odpowiedz cytując ten post
4x, archival, bd-r, grade, ritek
Wszystkie czasy w strefie CET. Aktualna godzina: 06:21.
