-   -   NOSNIKI DVD-R/+R (https://forum.cdrinfo.pl/f28/nosniki-dvd-r-r-25947/)
cookie 30.08.2004 01:46
Mala ciekawostka moze nie dokonca zgoda z tematem
Verbatim 2.4x DVD+R D/L Review
As always, please ensure your DVD Writer has the latest firmware to get the best compatibility with this new media.
Many thanks must to go to BigPockets.co.uk for sending us this media to review for our CDR-Zone readers. In this review we get to look at the 'Verbatim 2.4x DVD+R D/L Media.
Features
Packaging and presentation
DVD+R D/L information
Burning
Verification and error checking
Conclusion
"The new 2.4x DVD+R media expands the data storage capacity from 4.7GB to a massive 8.5GB on a single side. This means that consumers will be able to record up to four hours of DVD-quality. Of utmost importance is the fact that compatibility is maintained with existing DVD video players and DVD ROM drives. Verbatim is an active member of the DVD+RW Alliance and this development clearly illustrates its desire and ability to work closely with hardware manufacturers."
Features:
Manufacturer: Verbatim
Lead In Info: MKM-001-00
Top Surface Colour: Silver with Verbatim logo
Writing Surface Colour: Dark purple
Write Speed: 2.4X ( 4x in drives capable of Over Burning ) !!!!!!!
Max Storage Data: 8.5Gb
Max Storage Time: 4 hours
kowanski 29.08.2004 00:21
Napisany przez Nuno1971
Gdzie kupiles te plytki ??
Nuno
We Wrocku na giełdzie :)
Nuno1971 29.08.2004 00:03
Napisany przez kowanski
Ricoh 2,4x (no name, lusterko) za 1,40 zł palony 8x na NEC-2500A+ :)
Nuno
pawelblu 28.08.2004 21:53
Napisany przez Jabba the Hutt
W Delfinie płytki Verbatim x4 po 2,95 zł. Niby w cake 25 sztuk ale sprzedali mi pojedyńczo.
Jabba
CDRland sprzedaje po 2 zl netto (2.44 brutto). Niesety tylko w Cake (25 i 50).
Jabba the Hutt 28.08.2004 21:34
Jabba
pawelblu 28.08.2004 18:13
Napisany przez dk75
Właśnie czytam cdfreaks, TDK-R x4, TTG01, startegia zapisu x4 ale deskryptor zapisu CLVx2 tylko.
Fajne ekstra firmowe dyski TDK Corp. ;PPPp
Na DigitalFAQ.com zaklasyfikowane jako nośniki pierwszej jakości (x4 mozna palić tylko x2) wraz z TDKG02000000 podczas gdy RICOHJPN zaklasyfikowane jako nośniki drugiej jakości (x4 można palić x8) ;PPPp
I mówisz że nie ma żadnej naciąganej teorii?
Nie nie ma.
TDK Corp. to srednia fabryka. Juz kiedys pisalem jak wedlug mnie powinno wygladac tamto zestawienie, bo to co tam jest, nie odzwierciedla poprawnej oceny jakosci nosnikow. Dalej nie widze problemu.
dk75 28.08.2004 17:55
dk75 28.08.2004 17:28
To poszukaj sobie na cdfreaks i w zachodnich sklepach - dość często przewija się tam informacja że TTG01 to OEM CMC dla TDK.
pawelblu 28.08.2004 16:40
Tu nie ma zadnej naciaganej teorii. TTG01 nawet w kprobie jest identyfikowany jako TDK Corp. Podobnie w wiekszych specyfikacjach produncentow ktore mozna spotkac na roznych stronach.
dk75 28.08.2004 12:02
Nie za bardzo.
TTG01 to znacznik nośnika TDK. ktoś tu pisał że TDK może produkować nośniki DVD bo CD produkował... raczej mi na to nie wygląda ponieważ:
1. raczej nie ma tak małych linii produkcyjnych żeby tak mało płytek robić
2. ze względu na pkt.1 na rynku byłyby innej marki płytki z nośnikiem TDK, a raczej nic o tym nie wiadomo
3. ze względu na pkt.1 TDK raczej nie kupowałby nośników u innych producentów tylko by na swoim tłukł płytki
To że produkował TDK własne nośniki do CD nie znaczy że na tej samej linii może robić DVD - to całkiem inne linie, i dużo producentów którzy robili CD nie robi jeszcze DVD.
Na sieci widziałem opisy jakoby TTG01 to były OEMy robione dla TDK przez Tayo Yuden (superb) jak i CMC ( :( ). Jednak można dostać płytki TDK z ID CMC i TY więc wygląda na to, że do tych nośników żaden z producentów nie chce się przyznać i musi to robić TDK... coś na rzeczy?
qba01 28.08.2004 11:47
Mam takie pytanie: kupiłem w Tesco płytki TDK-R za 4,99 w pudełkach, po sparwdzeniu producenta pokazuje mi TTG01, czy są to dobre płytki czy nie za bardzo, bo mam też wcześniej kupione TDK-R gdzie producent to TYG01. Wie ktoś jaka jest różnica między nimi? wszystkie te płytki to 1-4X. Płytki te używam tylko do nagrywania gier na PS2.
Dzięki z góry za odpowiedż.
kowanski 27.08.2004 18:40
Napisany przez barte_k
Kowanski uaktualnij może KProb'a do wersji 2.4.0 :taktak: :spoko:
Mogę zrobić test na Kprobe 2.4.0, ale jakoś nie wierze tej wersji :( Przeważnie jest mniej błędów niż na Kprobe 1.1.29
dd8 27.08.2004 17:36
Ktoś ma TDK -R ScrachProof i może podesłać test i producenta nośnika?[/QUOTE]
mam TDK-R ScrachProof, ale ma TDK 880N
wiec kProbe chyba nie ruszy.
jest jakas inna metoda ?
dd
B@rtek 27.08.2004 15:32
Media Information
Media code/Manufacturer ID RICOHJPNR00
Media Product Revision Number 01h
Format Capacity Not Formatted
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 2.4x 3324KBps
Available Write Descriptor CLV 8.0x 11080KBps
Available Write Descriptor CLV 5.9x 8112KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Linear Density Blank Disc
Track Density Unknown
Number of Layers 1
00000000 01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00000010 00 00 00 00 00 00 00 52 49 43 4F 48 4A 50 4E 52 .......RICOHJPNR
00000020 30 30 01 38 23 54 37 0C 00 50 6C 00 C8 66 16 18 00.8#T7..Pl..f..
00000030 0B 0B 0A 0B 01 19 1B 0B 0B 0E 0F 01 00 00 00 00 ................
Ps. Po przejściu na 8x sporo błędów, ale na stacjonarce jest OK, lepiej jednak palić je max x6 :)
Heros120 27.08.2004 14:57
Napisany przez Heros120
Witam,
Jestem początkujący w wypalaniu DVD i mam pare pytań.
Ad.1
Czy te wykresy są dobre ??.
http://www.heros120.webpark.pl/dvd01-kprobe.jpg
http://www.heros120.webpark.pl/dvd02-kprobe.jpg
http://www.heros120.webpark.pl/dvd03-kprobe.jpg
!!Każdy wykres to inna płyta!!
Są to płytki "Plus Platinum" DVD+R cena OEM--> Bez pudełka 3,20zł
Typ nośnika RICOHJPNR02 czyli niby b.dobre ale chce się upewnić czy ktoś na nie narzekał po np. 6 miesiacach po wypaleniu.
Ad.2
Co oznaczają w KProbe symbole PI, PIF czym mniej to lepiej??.
AD.3
Jakie dajecie normy dla płyty DVD aby była według was dobrze nagrana??.
pzdr,
Robert
-----------------------UPDATE--------------------------------------
Witam,
Te same testy ale przy prędkości x4 nagrywane z speed x2
Niestety przy jakichkolwiek innych sterownikach ASPI ten sam błąd zwiecha kompa :'( .Oczywiście tylko przy tym programie.
I proszę o ponowną ocenę tych płyt.
www.heros120.webpark.pl/dvd01-kprobenew.jpg
www.heros120.webpark.pl/dvd02-kprobenew.jpg
www.heros120.webpark.pl/dvd03-kprobenew.jpg
PS. Czy jest jakas duża różnica w testach przy Driverach w kprobe na SPTI zamiast na ASPI ??? .
pzdr,
ROB
Wszystkie czasy w strefie CET. Aktualna godzina: 09:21.
