Ricoh 2,4x (no name, lusterko) za 1,40 zł palony 8x na NEC-2500A+ :)
Media Information Region information N/A not a DVD-VIDEO Media code/Manufacturer ID RICOHJPNR00 Media Product Revision Number 01h Format Capacity Not Formatted Free Blocks 405405696 Free Capacity 4.38GB(4.70GB) Book Type DVD+R Media Type DVD+R Media Id Code Speed 2.4x 3324KBps Available Write Descriptor CLV 8.0x 11080KBps Available Write Descriptor CLV 5.9x 8112KBps Available Write Descriptor CLV 4.0x 5540KBps Available Write Descriptor CLV 2.4x 3324KBps Linear Density Blank Disc Track Density Unknown Number of Layers 1 00000000 01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.? 00000010 00 00 00 00 00 00 00 52 49 43 4F 48 4A 50 4E 52 .......RICOHJPNR 00000020 30 30 01 38 23 54 37 0C 00 50 6C 00 C8 66 16 18 00.8#T7..Pl..f.. 00000030 0B 0B 0A 0B 01 19 1B 0B 0B 0E 0F 01 00 00 00 00 ................ Ps. Po przejściu na 8x sporo błędów, ale na stacjonarce jest OK, lepiej jednak palić je max x6 :) |
Ricoh 2,4x (no name, lusterko) za 1,40 zł palony 2,4x na LITE-ON 401s@811s HS0P mod v4 :)
Media Information Region information N/A not a DVD-VIDEO Media code/Manufacturer ID RICOHJPNR00 Media Product Revision Number 01h Format Capacity Not Formatted Free Blocks 405405696 Free Capacity 4.38GB(4.70GB) Book Type DVD+R Media Type DVD+R Media Id Code Speed 2.4x 3324KBps Available Write Descriptor CLV 8.0x 11080KBps Available Write Descriptor CLV 5.9x 8112KBps Available Write Descriptor CLV 4.0x 5540KBps Available Write Descriptor CLV 2.4x 3324KBps Linear Density Blank Disc Track Density Unknown Number of Layers 1 00000000 01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.? 00000010 00 00 00 00 00 00 00 52 49 43 4F 48 4A 50 4E 52 .......RICOHJPNR 00000020 30 30 01 38 23 54 37 0C 00 50 6C 00 C8 66 16 18 00.8#T7..Pl..f.. 00000030 0B 0B 0A 0B 01 19 1B 0B 0B 0E 0F 01 00 00 00 00 ................ |
Jeśli kupisz firmowe BOXy to TDK +R x4 jest RICOHJPN, inaczej CMC, czyli taniej wyjdzie kupić Dysany OEM ;PPPp
Ktoś ma TDK -R ScrachProof i może podesłać test i producenta nośnika? |
Najlepsze sa chyba plyty Plextora. W Polsce ich jeszcze nie widzialem. W Polsce do niedawna najlepsze byly Verbatimy +R Pastel w slimach, ale tez juz ich nie ma. Digital Movie od Verabtima to kaszana oprocz ladnego wygladu (produkuje to MBI). Te TDKi chyba sa lepsze, chociaz sa malo sprawdzone. TDK mozna za to dostac nie od ricoha, a to tez nie fajnie. Ja bym zapolowal na te Pastele Verbatima.
Przeczytalem watek, testy ok, ale wlasnie jesli chodzi o DROZSZE nosniki... Potrzebuje PEWNEJ plytki na "rodzinne" filmy. Widze ze testy wykazuja roznie ale dotycza plytek ponizej 15PLN. Poniewaz cena nie jest az tak istotna,predkosc nie wazna, wazne to zebym mogl to obejrzec za kilka lat... co w tej chwili Robs polecasz ? Znalazlem jakies nowosci: http://www.arcomp.com.pl/index.php?p...3&details=4972 http://www.arcomp.com.pl/index.php?p...1&details=7650 ale czy to juz wystarczajaca jakosc ? cena taka dosc niska. Moze "te lepsze" trzeba szukac na specjalne zamowienie ? Pale na NEC 1300A. Ogladam na Pioneer 444. Pozdrawiam. Andrzej. |
plytka tdk,jak widac bez rewelacji.trzeba bedzie moze przejsc na 832
Nie jest zle. Pierwszy wykres bardzo dobry. Na drugim wykresie widac ten problem o ktorym piszesz, ale wydaje mi sie ze jeden wykres to za malo zeby tragizowac.
Jeszcze ja przedstawie swoje wyniki na platinum od RICOHJPN R02 (palnik 832s) z takimi cholernymi pierscieniami na czystych plytach (nie wiem czy to wada czy urok tych plyt)...
palone x4: http://republika.pl/czupak/platinum x4.PNG palone x8 (i jak widac strefa palenia x6 niezbyt, ale tam sa te pierscienie): http://republika.pl/czupak/platinum x8.PNG Na TDK x4 (+R) mam jesli chodzi o pif zblizone wyniki, ale pi mam 10razy mniejsze... Prosze o skomentowanie powyzszych wynikow. Nagrywarke posiadam od 2 tyg... i sami rozumiecie zielony jestem troche... Z gory dziekowa. pozdro! |
[/QUOTE] Cytat:
Teorycznie jest tak jak napisal slawek. Przy starym probie gdzie bylo ECC 8/8 przyjmowalo sie PI 280 , PO 32 teraz przy ECC 8/1 przyjmuje sie PI 280 PIF 4 (oba przy predkosci 4x). Co do ASPI najbardziej niezawodne ASPI znajduje sie w pakiecie ForceASPI 1.7 (nie pamietam dokladnie wersji ale chodzi o to starsze ForceASPI) |
A czy masz wgraną odpowiednią wersję ASPI? Najnowsza to 4.7.2. |
Czy jest jakiś inny program co daje w miare wiarygodne wyniki??. |
Witam,
Jestem początkujący w wypalaniu DVD i mam pare pytań. Ad.1 Czy te wykresy są dobre ??. http://www.heros120.webpark.pl/dvd01-kprobe.jpg http://www.heros120.webpark.pl/dvd02-kprobe.jpg http://www.heros120.webpark.pl/dvd03-kprobe.jpg !!Każdy wykres to inna płyta!! Są to płytki "Plus Platinum" DVD+R cena OEM--> Bez pudełka 3,20zł Typ nośnika RICOHJPNR02 czyli niby b.dobre ale chce się upewnić czy ktoś na nie narzekał po np. 6 miesiacach po wypaleniu. Ad.2 Co oznaczają w KProbe symbole PI, PIF czym mniej to lepiej??. AD.3 Jakie dajecie normy dla płyty DVD aby była według was dobrze nagrana??. pzdr, Robert |
| Wszystkie czasy w strefie CET. Aktualna godzina: 06:06. |
