Stary 10.12.2023, 18:16   #946
RichL101
Data rejestracji: 10.12.2023
RichL101 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello Team - New to the Forums...
I have the following 2 drives and would like to know if possible can these drives types be cross-flashed to enable 4K UHD disc ripping with MakeMKV and any recommendations what would be the best firmware. Also would it be possible to get a copy of bdrflash?
Drive #1 BDR-209DBK
Drive Information OS device name: D: Manufacturer PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: MJDL003624WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 77
LibreDrive Information
Status: Enabled
Drive platform: RS8600
Firmware name: PIONEER BDR-209
Firmware type: Original (unpatched)
Firmware version: 1.51/ID61
DVD all regions: Yes BD raw data read: Yes
BD raw metadata read: Yes Unrestricted read speed: Yes
Drive #2 BDR-XD05TB
Product: BD-RW BDR-XD05
Revision: 3.10 Serial number: NJDL000830WL
Firmware date: 2017-06-22 Bus encryption flags: 1B
Status: Enabled
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Kind regards,
Rich
Ostatnio zmieniany przez RichL101 : 10.12.2023 o godz. 20:09 Powód: Typo
RichL101 jest offline
Stary 10.12.2023, 21:13   #947
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez RichL101 Podgląd Wiadomości
Drive #1 BDR-209DBK
Revision: 1.51
Status: Enabled
Drive #2 BDR-XD05TB
Status: Enabled
Kind regards,
Rich
Welcome to the forums, RichL101! PM sent.
jadburner jest offline
Stary 11.12.2023, 14:10   #948
Sillywilly
Data rejestracji: 06.12.2023
Sillywilly w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Welcome to the forums, Sillywilly! PM sent.
Hello jadburner,
Thank you very much for helping out!!!
I read out the drive information of my Pioneer drive.
What confused me a little was, that the check marks for BD-R XL and BD-RE XL were already set.
Nevertheless I tried to start the flashing process and it stopped with the message "Drive and firmware hardware types don't match."
Any idea what could be wrong with this drive?
Kind regards
SillyWilly
Sillywilly jest offline
Stary 11.12.2023, 19:51   #949
jadburner
Napisany przez Sillywilly Podgląd Wiadomości
Hello jadburner,
Kind regards
SillyWilly
Sillywilly - Please check your PM.
Stary 20.12.2023, 15:55   #950
RichL101
Hi Jadburner
Any chance a BDR-XD04T fw v1.30 can be cross-flashed forUHD capability such as the BDR-XD06J-UHD?
Drive Information OS device name: D: Manufacturer: PIONEER
Product: BD-RW BDR-XD04
Revision: 1.30 Serial number: LHDL008501WL
Firmware date: 2012-09-05
Highest AACS version: 81
Status: Possible, but very unlikely to happen
Drive platform:
Pioneer RS8130
Firmware version: GENE
Thanks,
Rich
Stary 20.12.2023, 17:37   #951
RichL101
Hi again Jadburner,
Additionally, how to dump the original kernel &firmware files as backup on USB Pioneer BDR XD/S drives before cross-flash?
Thanks
Rich
Stary 20.12.2023, 19:19   #952
jadburner
Hi Jadburner
Drive platform:
Pioneer RS8130
Thanks,
Rich
Unfortunately, no. XD04 drives can only be crossflashed into drives in the same series.
Stary 20.12.2023, 19:26   #953
jadburner
Hi again Jadburner,
Thanks
Rich
PM sent.
Stary 22.12.2023, 02:50   #954
Wenne
Data rejestracji: 22.12.2023
Wenne w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Firmware foe Pioneer S12U
Hi i have a Pioneer BDR-S12U burner. Is it possible to flash it from firmware 1.05 back to a firmware 1.01 or 1.02? Please help me to solve this problem.
Many thanks
Wenne jest offline
Stary 22.12.2023, 06:17   #955
jadburner
Napisany przez Wenne Podgląd Wiadomości
Many thanks
I wish we could help, but the 1.05 firmware on your drive prevents crossflashing or downgrading. So you will have to wait until there is a workaround for that issue. Sorry.
Stary 24.12.2023, 22:33   #956
StaNDarD
StaNDarD w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi jadburber,
I have the following drive:
pioneer bdr-208dbk
Drive Information
OS device name: /dev/sr0
Current profile: BD-ROM
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: LKDL007115WL
Firmware date: 2012-08-22
Highest AACS version: 68
Status: Enabled
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
As far as I understood, it should be possible to flash this drive to read UHD-Blurays.
Can it be flashed using Linux or only with Windows?
Thanks in advance.
StaNDarD jest offline
Stary 25.12.2023, 05:57   #957
jadburner
Napisany przez StaNDarD Podgląd Wiadomości
Hi jadburber,
Thanks in advance.
Welcome to the forums, StaNDarD! PM sent.
Stary 26.12.2023, 06:10   #958
penpenpen
Data rejestracji: 26.12.2023
penpenpen w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi! New to the forum.
I've got an external iodata drive (iodata brp-ut6le) which contains a Pioneer BDR-UD03. 1.10 firmware from 2017. Works great for FHD.
I believe it's possible to cross flash a BDR-UD04 firmware to enable UHD, is that correct?
Drive Information
OS device name: G:
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: QKDL112976WL
Firmware date: 2017-04-18
Status: Enabled
Drive platform: RS8511
Firmware name: PIONEER BDR-US03
penpenpen jest offline
Stary 26.12.2023, 19:47   #959
Sammy56
Sammy56 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi!
I have BDRFlashtool , but i would need a Firmware files for Buffalo BRXL-16U3
I know it can be Flashed to BDR-211 so it can read UHD Disc´s .
So, i need a compatible FW files that Flash the BDR-209M (RS8600 HW) to BDR-211
Heres the Drive information from Make MKV:
Drive Information
OS device name: L:
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: NEDL018813WL
Firmware date: 2014-01-16
Highest AACS version: 72
Status: Enabled
Firmware version: 8.11/ID52
-Sammy
Sammy56 jest offline
Stary 26.12.2023, 21:17   #960
jadburner
Napisany przez penpenpen Podgląd Wiadomości
Drive Information
OS device name: G:
Revision: 1.10
Status: Enabled
Welcome to the forums, penpenpen! PM sent.
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 20:23.
