http://www.cdrinfo.pl/hardware/20801...ioneer-DVR-A04 Can you ask for pictures like looks and factory labels? Is it possible to factory update to newer firmware? I have DVR-A04 and DVR-104 \ 2 Pioneer DVR-A04 Pioneer DVR-104\2 |
Ilość załączników: 4
I got the drive off of eBay a few years ago. Apparently it came from a Compaq desktop. I have not tried any burns yet, since I was hoping to upgrade the firmware first. I tried flashing with Pioneer firmware, bit it would not work.
Here's some photos of the drive: Załącznik 98390 Załącznik 98391 Załącznik 98392 Załącznik 98393 |
jadburner, thank you very much for the screenshots and drive photos!
If you will decide to crossflash the drive, I will advice not to do it with DVRTool, until I'll test it personally on this drive. We had troubles with DVR-105 crossflashing twice - both times something went wrong and DVRTool hung after sendng the first part of kernel file (apparently waiting the response from the device) - as a result, two drives now require to flash the system controller using an external hardware (which I don't have). Since DVR-104 drives are rare, i will advice not to use DVRTool for their crossflashing, until everything will be tested. |
@jadburner :spoko:
Thank you very much for the photos. I have never met a version with a black front panel. @blackened2687 Do you have any kernel for DVR-A04 \ 104 ? I have never met nor seen anywhere? |
I recently watched Pioneer DVR-S201 but it was so damaged and damaged that I could not fix it. Załącznik 98643 |
We have practically no Pioneer DVR-S101 \ S201. I know only one place in Poland that used to have and used DVR-S201 .... Too bad you no longer have a SCSI or SCSI adapter working .... Please put this unique model with a picture in our museum. Muzeum\Mauzoleum DVD |
DVRTool 1.0298j Beta
Ilość załączników: 3
I'll see if I can do about getting it hooked up... |
I only have the oldest DVR-103 \ A03. Here is a sample test @ Blackened2687 [Muzeum] Pioneer DVR-A03 - 2001r |
Wszystkie czasy w strefie CET. Aktualna godzina: 11:14. |
