| Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
DVRTool 1.0298j Beta
| #ads | |
I also have a BDR-XS05T, but I'm still looking for it.
Excellently .
![]() We ask you to dump Eeprom and settings. The rest of the information and soft send to PM. |
2017-05-15_18-52-52.png 2017-05-15_18-53-17.png 2017-05-15_18-54-49.png 2017-05-15_18-55-45.png |
CDRinfoTeam
![]() Data rejestracji: 19.04.2014
jadburner, thank you very much for the data dumps! Helped me a lot to figure out some drive settings.
A question: have you got any slim TEAC drive from DV-W28xxxx series? There is a rumor that some of these drives are rebadged Pioneer drives, but I don't have access to any of them to check it out. |
#8 | |
Ktoś mnie się kiedyś na PW pytał o ten model ..jak znajdę wiadomość to spytam się czy zakupił ... ![]() @jadburner wspominał mi coś że na urlop się wybiera ![]() Jak się odezwie na PW to spytam się go czy przypadkiem nie ma w szafie TEAC DV-W28xxxx-
#11 |
#12 | |
![]() I'm pretty sure I have a couple hiding around here somewhere. I'll try to find them for you. Good to hear from you. |
#13 |
#14 |
CDRinfoTeam
jadburner, thank you!
To gather the necessary drive information more easily, I've made a small one-button program (called it Pioneer Data Dumper): http://www60.zippyshare.com/v/Tt8wTvdO/file.html The usage is simple as possible: enter the drive letter followed with a colon and click [Dump Data]. Resulting file is something that I need to properly add the drive support. ![]() To everybody: If you will find some slim Pioneer BD drive from the list below, please dump its data using the Pioneer Data Dumper and send the file to czary2mary or to me. It will greatly help to add the most of existing Pioneer drives to the program. ![]() Wszystkim: Je***347;li ktokolwiek znajdzie jaki***347; nap***281;d slim Pioneer BD z poni***380;szej listy, serdecznie prosz***281; o dump danych za pomoc***261; Pioneer Data Dumper i o wysy***322;ce plika do czary2mary lub do mnie. Bardzo to pomo***380;e mi w dodaniu wi***281;kszo***347;ci istniej***261;cych nap***281;dów Pioneer do programu. ![]() List: BDR-TD02 (BDR-TD02VA) BDC-TD02 (BDC-TD02VA, BDC-TD02RS) BDC-TS02 (BDC-TS02PB) BDR-TS04 (BDR-TS04FAD, TEAC BD-W26SS-BM3) BDC-US01 (BDC-US01VA, TEAC BD-C16SS-A90) BDR-UD02 (BDR-UD02AS, BDR-UD02B, BDR-UD02FAN, BDR-UD02TBD, BDR-UD02VA, BDR-UD02VB) BDC-UD02 (BDC-UD02AS, BDC-UD02TBD, BDC-UD02VA) BDC-UD03 (BDC-UD03AS) BDR-UD04 (Logitec LBD-PUD6U3L) Ostatnio zmieniany przez blackened2687 : 17.12.2017 o godz. 17:59 |
#15 |
Found one of them.
![]() Teac DV-W28S-V42 From DVRTool: Drive Information: Model Name : TEAC DV-W28S-VS Firmware Rev : G.V0 Extra Info : Serial Number : XXXXXXXXXX**** Buffer Size : 2000 kiB Additional Drive Information: Label Code : **************** Hardware Rev : STE 0282 Kernel Type : TEAC Firmware Type : TEAC Kernel Version : 0001 Drive is in normal mode. Firmware flashing support : YES Firmware dumping support : YES Drive Capabilities: CD-ROM : R BD-ROM : - CD-R : R/W BD-R : - CD-RW : R/W BD-R XL : - DVD-ROM : R BD-RE : - DVD-R : R/W BD-RE XL : - DVD-R DL : R/W HD DVD-ROM : - DVD-RW : R/W HD DVD-R : - DVD+R : R/W HD DVD-R DL : - DVD+R DL : R/W HD DVD-RW : - DVD+RW : R/W LabelFlash : NO DVD-RAM : R/W LightScribe : YES Drive Region Settings: RPC Scheme : RPC-2 Current Region : 0 Changes Left : 5 (available to user) Resets Left : 4 (available only to vendor) Region State : Region is not set |
| Tagi |
| dvrtool, pioneer |
| Pioneer BD Drive Utility | czary2mary | Programy do nagrywania, testowania, diagnostyki | 16 | 05.02.2022 09:55 |
| Linkownia\ firmware do CD\DVD\BluRay | czary2mary | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 24.08.2019 18:09 |
| [Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | -Sid-The-Rat=> | Flashowanie/Firmware/Podkręcanie napędów optycznych | 209 | 10.02.2006 16:01 |
| Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | SoBal | Flashowanie/Firmware/Podkręcanie napędów optycznych | 0 | 28.09.2003 22:37 |
