| Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
CDRinfoTeam
![]() Data rejestracji: 19.04.2014
Wow!!! And even the LightScribe version!
![]() So, it's true: DV-W28S-Vxx series drives does appear to be rebadged DVR-TD09 drives, and that is very good! Thank you very much! Would be great to find more drives from these series! |
| #ads | |
CDRinfoTeam
jadburner, thank you very much for more dumps! Could you please also dump additional data with Pioneer Data Dumper from DV-W28SLC?
And is it possible to look at the full name of the drive on the label? With all the hyphens and additional numbers outside the square frame. Of course, if the drive is not installed in the laptop or if it's not too difficult to remove. If it's installed in the laptop, then i need the full laptop model code. Drive full model code should be like DV-W28SL-C-1D2. DV-W28SL is in the square, and C-1D2 is outside on one line with main model name. Thanks in advance! I'm amazed to find that DV-W28SLC is also a Pioneer drive - 0072 is the hardware code of DVR-K17 drives - but DVR-K17 is a tray loading drive! I assume, that the slot loader itself is made by different manufacturer - Pioneer made only the board, firmware and optical pickup. Interesting drive - definitely worth to have! Ostatnio zmieniany przez blackened2687 : 04.06.2017 o godz. 07:21 |
CDRinfoTeam
#7 | |
Teac DV-W28S-V42 Label.jpg Teac DV-W28SLC Label.jpg |
CDRinfoTeam
Wow! Thank you very much for the photos and the dump!
More info: I've researched a bit about slim TEAC drives and can now suggest which series used the Pioneer hardware: DV-W28ECxx - DVR-K17 DV-W28SLCxx - DVR-K17 (with slot loader not made by Pioneer) DV-W28E-Rxx - DVR-KD08 DV-W28S-Rxx - DVR-TD08 DV-W28S-Vxx - DVR-TD09 DV-W28U-Vxx - DVR-TD09 (external drive) Maybe there are more rebadged Pioneer drives, we have yet to figure it out. ![]() jadburner, have you ever heard of Toshiba Portable SuperMulti Drive PA3834U? It seems that this drive is also a rebadged Pioneer, but I've failed to find any firmware for it to check out. |
#9 | |
#11 |
CDRinfoTeam
jadburner, thanks, but I've already got the firmware dumps
I've asked additionally about the data dump made by Pioneer Data Dumper from DV-W28SLC - that 1,45 kbytes file. ![]() Would be great if you will find that external Toshiba drive as well ![]() Thanks for the info about DV-W28S-WTN drive! |
#12 |
#13 |
CDRinfoTeam
Thank you very much! That is exactly what I need.
#14 |
#15 |
DVRTool 1.0298j Beta
Crossflash Pioneer BDC-207DBK do Pioneer BDR-BDR-PR1EPDV PP100 Epson
![]() 2017-06-05_13-03-09.png 2017-06-05_13-03-45.png 2017-06-05_13-04-51.png 2017-06-05_13-05-22.png 2017-06-05_13-06-42.png |
| Tagi |
| dvrtool, pioneer |
| Pioneer BD Drive Utility | czary2mary | Programy do nagrywania, testowania, diagnostyki | 16 | 05.02.2022 09:55 |
| Linkownia\ firmware do CD\DVD\BluRay | czary2mary | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 24.08.2019 18:09 |
| [Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | -Sid-The-Rat=> | Flashowanie/Firmware/Podkręcanie napędów optycznych | 209 | 10.02.2006 16:01 |
| Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | SoBal | Flashowanie/Firmware/Podkręcanie napędów optycznych | 0 | 28.09.2003 22:37 |
