Stary 22.07.2017, 09:53   #1
The only DVR-104M drives I've seen on eBay were always DVR-104MB, so I assume all of the Compaq versions were black.
Got something else from the first Pioneer models?
I recently watched Pioneer DVR-S201 but it was so damaged and damaged that I could not fix it.
czary2mary jest offline
Stary 22.07.2017, 20:26   #2
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Załącznik 98643
I have a DVR-S201 also. It's in good condition, but I no longer have a SCSI connection to test it.
jadburner jest offline
Stary 21.07.2017, 19:28   #3
jadburner
Napisany przez blackened2687 Podgląd Wiadomości
jadburner, thank you very much for the screenshots and drive photos!
If you will decide to crossflash the drive, I will advice not to do it with DVRTool, until I'll test it personally on this drive. We had troubles with DVR-105 crossflashing twice - both times something went wrong and DVRTool hung after sendng the first part of kernel file (apparently waiting the response from the device) - as a result, two drives now require to flash the system controller using an external hardware (which I don't have). Since DVR-104 drives are rare, i will advice not to use DVRTool for their crossflashing, until everything will be tested.
blackened2687, thank you for the warning. I'm in no rush to kill the drive, so I will wait until there's a safe way to update or crossflash the drive.
Stary 22.07.2017, 22:38   #4
jadburner
Pioneer DVR-X152 external drive:
Stary 27.07.2017, 07:43   #5
jadburner
Pioneer DVD-116LJ:
Stary 28.07.2017, 07:05   #6
jadburner
Pioneer A09XLB1:
Stary 31.07.2017, 18:39   #7
zaq99
Data rejestracji: 31.07.2017
zaq99 zaczyna zdobywać reputację <1 - 49 pkt>
s08-s09-s11 Same device opn 8342
208-209-211 Same device opn 8343 - 8344
RENESAS R8J32740FP42
yss.la.coocan.jp/bdrs09j/bdrs09j_top.htm
yss.la.coocan.jp/bdrs11j/bdrs11j_top.htm
yss.la.coocan.jp/bdrs08j/bdrs08j_top.htm
http://yss.la.coocan.jp/index.html
my device s09xlt opn 8342 RENESAS R8J32740FP42
209ebk Opn 8344 RENESAS R8J32740FP42
s09- 209m dump OK
PioneerDataDumper_v0.01
209ebk dump : OK
I. D.: OK
S.D.K
E.D.K
E. D.K
http://www60.zippyshare.com/v/Tt8wTvdO/file.html
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives
S11J-X test pls. dump PioneerDataDumper_v0.01
s08-s09 crossflash s11 ):
208-209 crossflash 211 ):
dvrtool 1.0298 link pls
Ostatnio zmieniany przez czary2mary : 01.08.2017 o godz. 19:57
zaq99 jest offline
Stary 01.08.2017, 20:03   #8
Napisany przez zaq99 Podgląd Wiadomości
s
DVRTool Beta 1.0298
The beta test is not public and is not available.
It is impossible to do crossflash of new models Pioneer BDR-207 \ 208 \ 209 \ 211 \ S07 \ S08 \ S09 \ S11.
The software of these drives has a special security feature that allows the software to be installed exclusively on the factory model.
Stary 01.08.2017, 21:56   #9
zaq99
[QUOTE=czary2mary]QUOTE]
pity. 208 \ 209 \ 211 - S08 \ S09 \ S11 completely same device 4k software fw.
zaq99 jest offline
Stary 04.08.2017, 07:40   #10
DVRTool 1.0298j Beta
Stary 06.08.2017, 09:24   #11
Stary 07.08.2017, 04:01   #12
jadburner
Pioneer DVR-106PC:
Stary 09.08.2017, 07:39   #13
Stary 12.08.2017, 06:31   #14
Stary 12.08.2017, 10:32   #15
Payti
Avatar użytkownika Payti
Data rejestracji: 28.10.2004
Payti zaczyna zdobywać reputację <1 - 49 pkt>
@czary2mary nie ma szans na crossflash S09->S11?
pozdr,
BLU-RAY: BD-RE LG BH10LS30 FW 1.02-A0 Patched & BD-RE LG WH16NS48 FW 1.D3 & LiteOn iHBS112 FW PL06 & Pioneer BDR-S11J-X FW 1.53 & LG WH16NS58 FW 1.V5 MK
& Pioneer BDR-S12UHT FW 1.02
Payti jest offline
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 09:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 16:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 19:50.
