| Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
Data rejestracji: 27.07.2023
Successfully cross-flashed BD-RW BDR-212V to BD-RW BDR-S12UHT thanks to jadburner. Now I can write our family album to BDXL M-Disk. Thank you very much jadburner!
Data rejestracji: 07.08.2023
Hi!
I recently found this forum and it seems like I might be able to crossflash my BDR-209EBK to BDR-211EBK and gain UHD support! Could someone help me with this cross-flash?
Data rejestracji: 31.08.2023
Hello, everybody. Came here for your help with crossflashing 209ebk to 211ubk. Recently i've ruin my 211ubk with the latest firmware. I can't use it to watch 4k discs anymore. So i bought 209ebk as replacment and need to crossflash it to 211 to make it UHD friendly. Your help will be much appreciated.
#6 | |
Data rejestracji: 08.09.2023
Hi.
I don't know Polish, so I hope I registered OK. I also have an old 209M that does not read UHD discs. As I understand it, it can be cross flashed and become UHD friendly. Is that correct. And if so how? Best regards rco133 |
Data rejestracji: 10.09.2023
Hi.
Is it possible to cross-flush BDR-212DBK to BDR-S12UHT? |
#11 |
Thank you for a reply.
But I have a problem. I tried to cross-flash with DVR Tool v1.02, but it display this drive is not supported. Do I have to be newer than this version? Ostatnio zmieniany przez 666mk6 : 11.09.2023 o godz. 15:30 Powód: Garbled text |
#12 |
#13 |
I need to clarify my comment: the BDR-212DBK can be crossflashed into a BDR-S12UHT as long as the firmware on the BDR-212DBK is dated earlier than December 2022. So the firmware would have to be version 1.02 or earlier.
#14 | |
The obstacle before me now is that I do not have the BDR-S12UHT kernel on hand. Is there a way to obtain it? |
#15 |
| Tagi |
| dvrtool, pioneer |
| Pioneer BD Drive Utility | czary2mary | Programy do nagrywania, testowania, diagnostyki | 16 | 05.02.2022 08:55 |
| Linkownia\ firmware do CD\DVD\BluRay | czary2mary | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 24.08.2019 18:09 |
| [Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | -Sid-The-Rat=> | Flashowanie/Firmware/Podkręcanie napędów optycznych | 209 | 10.02.2006 15:01 |
| Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | SoBal | Flashowanie/Firmware/Podkręcanie napędów optycznych | 0 | 28.09.2003 22:37 |
