Stary 06.10.2023, 00:07   #1
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez Oinker Podgląd Wiadomości
Pioneer released a bunch of new firmwares for 212 & 213 series drives V1.05, changes:
Added a new function "Damage Prevention mode for music CD"
Improved operational stability
Still NOT recommended to update due to downgrade & crossflash protections.
Thank you, Oinker. You are correct. Pioneer is doing everything they can to trick owners into flashing and crippling their drives with newer firmware.
jadburner jest offline
Stary 22.10.2023, 01:29   #2
JuliusC
Data rejestracji: 14.05.2023
JuliusC w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello,
I just got a Pioneer BDR-209EBK... and I'd like to crossflash it so it can read UHD disks. From what I read, others have been able to do so. Any help would be greatly appreciated.
Drive details (from MakeMKV):
Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.30
Firmware date: 2014-12-05
Bus encryption flags: 13
Highest AACS version: 77
LibreDrive Information
Status: Enabled
Drive platform: RS8600
Firmware name: PIONEER BDR-209
Firmware type: Original (unpatched)
Firmware version: 1.30/ID60
Big thanks in advance!
JuliusC jest offline
Stary 22.10.2023, 05:58   #3
jadburner
Napisany przez JuliusC Podgląd Wiadomości
Hello,
Drive Information
Revision: 1.30
Status: Enabled
JuliusC - PM sent.
Stary 22.10.2023, 21:46   #4
JuliusC
It's working!
Big THANKS to all those involved in this tool, and to Jadburner for the help and support.
Stary 26.10.2023, 17:21   #5
dev
Data rejestracji: 26.10.2023
dev w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi, I have this BDR-UD03ASC slim drive:
Drive Information
Product: BD-ROM BDCUD03AS
Revision: 1.00
Serial number: NHDL000680WL
Firmware date: 2014-04-01
Bus encryption flags: 1B
Status: Possible, not yet enabled
Drive platform: Pioneer RS8590
Firmware version: ID23
Is it possible to crossflash it to enable LibreDrive? Thanks in advance.
dev jest offline
Stary 27.10.2023, 00:38   #6
jadburner
Napisany przez dev Podgląd Wiadomości
Drive Information
Revision: 1.00
Welcome to the forums, dev. Unfortunately, your drive is a BDC-UD03 combo drive, not a BDR-UD03. BDRFlash only supports crossflashing to BDR drives. You will need to work with the MakeMKV developers to see if they can enable support for it.
Stary 27.10.2023, 00:59   #7
dev
Hello jadburner and thank you very much.
I'm not sure which type applies to this drive, because the sticker says BDR, but MakeMKV reads BDC.
dev jest offline
Stary 29.10.2023, 18:56   #8
jadburner
Thanks for the extra information you provided, dev. We'll work with you to see if we can get your drive crossflashed to a BDR drive. Check your PM.
Stary 09.11.2023, 05:09   #9
HotDrive
Data rejestracji: 09.11.2023
HotDrive w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi guys, thanks for letting me join this awesome forum :-)
I am running a Pioneer BDR-209EBK (listed as BDR-209M) with firmware 1.20
Can you help me flashing it to something UHD compatible?
Many thanks in advance
HotDrive jest offline
Stary 09.11.2023, 19:11   #10
jadburner
Napisany przez HotDrive Podgląd Wiadomości
Welcome to the forums, HotDrive! PM sent.
Stary 09.11.2023, 19:43   #11
HotDrive
Tried to reply but cant find my message in the Sent box. Have you received anything from me? Tried multiple times, hope I didnt flood you, sorry for that if so
Stary 09.11.2023, 20:41   #12
jadburner
Yes, I got your replies. As I recall, there's a setting to save copies of messages in your Sent folder. Check your PM for my reply.
Stary 09.11.2023, 21:17   #13
HotDrive
I was 100% sure I checked the box to save the sent copy but didnt work. Now it works, so looks like I was to lame to use it correctly ;-)
Reply sent
Stary 19.01.2024, 11:36   #14
utarefson
Data rejestracji: 19.01.2024
utarefson w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Cześć!
Poszukuję crossflash dla nagrywarki Verbatim slimline 43890 (BDR-UD03) do BDR-UD04,a by umożliwić obsługę UHD. Czy jest taka możliwość?
Z góry dziękuję!
Producent: PIONEER
Produkt: BD-RW BDR-UD03
Wersja: 1.11
Numer seryjny: SJDL270081WL
Data firmware: 2018-11-28
Flagi szyfrowania bus: 1B
Drive platform: RS8511
Firmware name: PIONEER BDR-US03
Firmware version: 1.11
Ostatnio zmieniany przez utarefson : 19.01.2024 o godz. 12:23
utarefson jest offline
Stary 19.01.2024, 23:53   #15
jadburner
Napisany przez utarefson Podgląd Wiadomości
Cześć!
Z góry dziękuję!
Producent: PIONEER
Wersja: 1.11
PM sent.
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 16:40.
