| Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
Data rejestracji: 17.11.2023
Hi! I'd like access to BDRFlash to cross flash a BDR-XS07S on firmware 1.01. Thanks!
Data rejestracji: 23.11.2023
Hey!
I just found these forums. I'm looking to crossflash my verbatim slimline 43890 (BDR-UD03) to BDR-UD04 to enable UHD support. If that's possible? Any help would be appreciated. Thanks! Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 68 Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 |
#4 | |
Data rejestracji: 24.11.2023
Hello,
I'm looking for a way to crossflash my new Pioneer BDR-X13JBK to a UHD-friendly BDR-X13J-S. I stumbled across DVRTool, which my drive doesn't support, and am now looking for the newer BDRFlash. Can you help me flashing it to something UHD compatible? Many thanks in advance |
#7 | |
Thanks to jadburner's follow-up, I succeeded in crossflash.
thank you very much. Thanks also to Blackened2687, the author of BDRFlash. Manufacturer: PIONEER Product: BD-RW BDR-X13U Revision: 1.02 Firmware date: 2022-07-26 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS9401 Firmware name: PIONEER BDR-213T Firmware type: Original (unpatched) Firmware version: 1.02/ID43 |
Data rejestracji: 27.11.2023
Hi there, I would like to crossflash BDR-212EBK to either BDR-212UBK or BDR-S12UHT. Whichever would most reliably crossflash and read UHD discs.
Model Name : PIONEER BD-RW BDR-212M Firmware Rev : 1.02 Extra Info : 22/03/09 Serial Number : ALDL014027WL Buffer Size : 4000 kiB Additional Drive Information: Label Code : ---- Hardware Rev : SAT 8F00 Kernel Type : ID56 Firmware Type : ID56 Kernel Version : 0000 Many thanks Ostatnio zmieniany przez rippah212 : 27.11.2023 o godz. 13:34 Powód: typo |
#10 | |
#11 |
Data rejestracji: 29.11.2023
Hi I'd like to cross-flash Medion DVR-109DB into DVR-109 with newest firmware, please help.
Drive Information: Model Name : PIONEER DVD RW DVR-109 Firmware Rev : 1.09 Extra Info : 05/01/19 PIONEER Serial Number : DLDL095798WL Buffer Size : 2000 kiB Additional Drive Information: Label Code : DVR-109DB Hardware Rev : ATA 0009 Kernel Type : MEDION Firmware Type : MEDION Kernel Version : 0001 Drive is in normal mode. Firmware flashing support : YES Firmware dumping support : NO Drive Capabilities: CD-ROM : R BD-ROM : - CD-R : R/W BD-R : - CD-RW : R/W BD-R XL : - DVD-ROM : R BD-RE : - DVD-R : R/W BD-RE XL : - DVD-R DL : - HD DVD-ROM : - DVD-RW : R/W HD DVD-R : - DVD+R : R/W HD DVD-R DL : - DVD+R DL : R/W HD DVD-RW : - DVD+RW : R/W LabelFlash : NO DVD-RAM : R LightScribe : NO Drive Region Settings: RPC Scheme : RPC-2 Current Region : 0 Changes Left : 5 (available to user) Resets Left : 4 (available only to vendor) Region State : Region is not set |
#12 | |
#13 | |
Can you send me that version? Thanks. |
#14 | |
#15 |
| Tagi |
| dvrtool, pioneer |
| Pioneer BD Drive Utility | czary2mary | Programy do nagrywania, testowania, diagnostyki | 16 | 05.02.2022 08:55 |
| Linkownia\ firmware do CD\DVD\BluRay | czary2mary | Flashowanie/Firmware/Podkręcanie napędów optycznych | 2 | 24.08.2019 18:09 |
| [Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | -Sid-The-Rat=> | Flashowanie/Firmware/Podkręcanie napędów optycznych | 209 | 10.02.2006 15:01 |
| Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN | SoBal | Flashowanie/Firmware/Podkręcanie napędów optycznych | 0 | 28.09.2003 22:37 |
