Stary 03.10.2026, 18:48   #31
mattjackson
Data rejestracji: 29.09.2026
mattjackson zaczyna zdobywać reputację <1 - 49 pkt>
https://freemkv.org/docs/pioneer-firmware/
mattjackson jest offline   Odpowiedz cytując ten post
Stary 04.10.2026, 06:54   #32
froggi
Data rejestracji: 19.03.2026
froggi zaczyna zdobywać reputację <1 - 49 pkt>
A quick catch-up since my last update: trev.bot beta.84 is available. Recent releases have added these flashing options for matching drives:
  • BDR-212DBK 1.02/1.03 to BDR-S12U 1.02.
  • BDR-212EBK 1.05 to BDR-212U 1.05.
  • BDR-XS07 1.01/1.04 and BDR-XS07U 1.04 to BDR-XS07U 1.01.
  • BDR-X12 1.04 to BDR-X12U 1.04.
  • More BDR-XD07 1.06 variants, plus BDR-XD07U 1.06, to BDR-XD07U 1.04.
  • BDE-PR1JAME 1.01, BDR-209MIO 1.54 and more BDR-209M 1.54 variants to BDR-211M 1.53.
Firmware surveys have expanded too, including Epson PR1EPDV 1.10, BDR-X12U 1.04 and BDR-208M 1.51, alongside improved Epson EP3 and BDR-TD05 survey handling. Thanks to everyone sending reports and feedback.
If you're already using the app, update from within it. Run the free Check to see which options apply to your exact drive and firmware.
Full release notes:
For anyone who prefers following updates in a feed reader, there's an RSS feed:
Hey Matt, could you move updates about your flasher to its own thread so this one stays on topic? Thanks.
Ostatnio zmieniany przez misiozol : 14.10.2026 o godz. 09:47 Powód: Expanded recent release details and added the RSS feed.
froggi jest offline   Odpowiedz cytując ten post
Stary 05.10.2026, 22:08   #33
Coopervid
Avatar użytkownika Coopervid
Data rejestracji: 04.09.2024
Coopervid w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Napisany przez Stingray Podgląd Wiadomości
Could you tell me why many people choose the Pioneer BDR-212U firmware (or similar) instead of the S12JX? Personally, I install the MAX S11/S12 firmware versions to use the Pioneer utility for enabling Silent Mode foremost. To be honest, I almost never need UHD, since I mostly burn discs
Yes. JX is just for audio purposes but the firmware is not supported by Mike to support Libredrive.
Coopervid jest offline   Odpowiedz cytując ten post
Stary 06.10.2026, 00:23   #34
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
Napisany przez froggi Podgląd Wiadomości
could you please create a portable version
Stingray jest offline   Odpowiedz cytując ten post
Stary 13.10.2026, 23:36   #35
Coopervid
Wyszła wersja 1.0: obsługa LG, wiele platform, jedna licencja na wszystkie Twoje napędy zamiast licencji na jedno flashowanie. Szczegóły w nowym wątku:. czary2mary, skyrider, dzięki za pomoc.
Version 1.0 is out: LG support, cross platform, one license for all your drives instead of a license per flash. Details in the new thread: . czary2mary, skyrider, thanks for your help.
So? LG drives haven't been an issue for years. Marty's flasher just works fine.
Stary 14.10.2026, 09:40   #36
misiozol
Avatar użytkownika misiozol
Data rejestracji: 26.10.2008
This forum Is here to help users NOT TO MAKE MONEY, all links will be cleared, and post about licensees now have been moved to buy sell section.
ANY FURTHER post containing links to price or paid subscription will be subsequently DELETED
Ostatnio zmieniany przez misiozol : 14.10.2026 o godz. 09:52
Stary wczoraj, 20:52   #37
froggi
Napisany przez Coopervid Podgląd Wiadomości
You're right. Marty's flasher has worked for LG drives for years, and I wasn't suggesting otherwise. LG support in 1.0 means trev.bot now handles supported LG drives through the same guided check and flash flow as Pioneer. If Marty's flasher already works well for you, there's no reason to switch.
12/2022+, drives, firmware, flashing, pioneer
Wszystkie czasy w strefie CET. Aktualna godzina: 10:54.
