| Flashowanie/Firmware/Podkręcanie napędów optycznych Tematy poświęcone modyfikacjom biosów i nagrywarek |
#16 |
Data rejestracji: 25.01.2025
i downloaded your freemkv software. thanks.
but i noticed that to rip a uhd disc, the program doesnt have the keydb incorporated within your program. any chance you could include the keydb keys into your program to work straight out of the box? something like what makemkv has done? it has automatic keydb's incorporated in it. Ostatnio zmieniany przez joujoujou : 29.09.2026 o godz. 23:59 |
#17 |
Data rejestracji: 29.09.2026
i am choosing to not distribute keys. they are easily obtained anyways, keydbs website literally had a download zip button. that said there is an online key server you can register for and use, then no keydb needed. Info on discord. But no I wont be putting keys in the app itself.
also for reference makemkv doesnt use keydb it has its own key sources it bundles. not the public keys from keydb. The online key server freemkv works with is also not keydb but a larger collection. Ostatnio zmieniany przez joujoujou : 29.09.2026 o godz. 23:59 |
#18 |
ah, okie. thanks. anyway do keep up the good work done.
#19 |
trev.bot flash
Moje przetestowane napędy na sofcie od Trevor-a = Good job
![]() Pioneer XD05JP2 fw.3.11 do Pioneer XD06U UHD 1.11 ![]()
#20 |
trev.bot flash
![]() Pioneer BDR-212BK do Pioneer BDR-212U UHD 1.05 ![]()
#21 |
We should be trying to backup oem drives before we crossflash imo. Otherwise we lose the original firmware that may not exist in the public domain. Is anybody saving their original firmware or just flashing?
#22 |
Data rejestracji: 12.02.2024
Could you tell me why many people choose the Pioneer BDR-212U firmware (or similar) instead of the S12JX? Personally, I install the MAX S11/S12 firmware versions to use the Pioneer utility for enabling Silent Mode foremost. To be honest, I almost never need UHD, since I mostly burn discs
#23 |
Data rejestracji: 08.11.2022
Thanks!
![]() I downgraded my S13U with firmware 1.05 to 1.02 using beta 62, then I crossflashed it to S13J-X 1.02 with BDRFlash 1.00 and updated to 1.03 using the official Pioneer updater: |
#24 |
Now I hope I could do the same with my 212M @ S12 1.04.
#25 |
"I downgraded my S13U with firmware 1.05 to 1.02 using beta 62, then I crossflashed it to S13J-X 1.02 with BDRFlash 1.00 and updated to 1.03 using the official Pioneer updater:"
Thats a great test workflow for me to look into! Downgrade + cross flash + upgrade, Amazing. |
#26 |
Added a couple hundred more firmwares btw to the site
| Tagi |
| 12/2022+, drives, firmware, flashing, pioneer |
