Stary 26.03.2023, 21:03   #1
jhill1977
Data rejestracji: 26.03.2023
jhill1977 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Need assistance flashing slim PATA CD drive to slave
I have two older Toshiba notebooks running Win98 that I'd like to upgrade to a DVD-RW or DVD-ROM/CD-RW drive.
It seems both machines require the optical drive set as SLAVE. I remember years ago using a utility on CDFREAKS to change the master/slave assignment in the firmware on a Dell slim optical drive.
Can someone recommend a slim PATA/IDE drive that can be easily changed to SLAVE via firmware or third part tool?
Thanks in advance.
jhill1977 jest offline   Odpowiedz cytując ten post
Stary 27.03.2023, 00:27   #2
jhill1977
After some hunting, it appears my Sony DW-D56A is a rebadged LiteOn SOSW-852S.
That said, I'm not seeing a source for a binary firmware for the drive, either Sony or LiteOn. It seems the DOS version of MTK Flash can assign the drive as a slave device, but I'm not sure how to proceed. Thank you
Stary 27.03.2023, 11:02   #3
misiozol
Avatar użytkownika misiozol
Data rejestracji: 26.10.2008
It might be hard, most of users from that era have moved on and are no longer here, only few of passionate are left as you can see. Unfortunately most tools are gone from servers you can try find something in history by looking specific model for this notebook.
Stary 27.03.2023, 16:20   #4
blackened2687
CDRinfoTeam
Data rejestracji: 19.04.2014
If I remember correctly, LiteOn slim drives master/slave mode is configured in LtnFlash, but I need to check it myself to be sure.
assistance, cd, drive, flashing, pata, slave, slim
Wszystkie czasy w strefie CET. Aktualna godzina: 10:15.
