Stary 01.07.2026, 05:00   #1
MonetJack
Data rejestracji: 01.07.2026
MonetJack w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Smile Pioneer X12JBK, XD05 and BDE-PR1EP Crossflash problems
Hello everyone. I started getting into optical disc drives and discs this year, and I learned about this forum through the English reviews of the 211 and 212 series. Thank you all for your dedication.
Now I own several drives: the Pioneer X12JBK, XD05 and BDE-PR1EP, all purchased from the second-hand market in Japan.
I have encountered some problems during my exploration and would like to ask for your help.I have bought some UHD discs. UHD playback on computers is very poorly optimized right now, and my drives do not support UHD natively, so I want to perform crossflashing.
First question: I downloaded EXE firmware update packages from Pioneer's official Japanese website and extracted them using Resource Hacker. Pioneer does not encrypt the firmware. Some update packages contain both Kernel and Firmware, while others only include Firmware.
I wonder if I failed to extract the full contents? After all, the official EXE installers can complete the update process normally.
Second question: I tried to flash the firmware extracted from the official website with DVRTool, and I also modified the firmware via WinHex to match the target model name and identifier, but the flashing failed. I would like to ask: does Pioneer have any other verification mechanisms besides the device ID?
Third question: For this EPSON-customized BDE-PR1EP drive, I found another firmware from the same product line -BDE-PR1EP2, which has an ID of 75, while the BDE-PR1EP has an ID of 76.
This drive does not support BD-RE or BDXL formats, and I ran into the same failure when attempting crossflashing.It appears that its main controller chip is identical to the one in the S11J-X. Is there any chance it can be crossflashed to work as a 211M?
Below is the drive information read by DVRTool. Thank you for your patience and for reading through my post.
Model Name : PIONEER BD-RW BDR-XD05
Firmware Rev : 3.10
Extra Info : 17/06/22
Serial Number : SHDL015522CN
Buffer Size : 4000 kiB
Additional Drive Information:
Label Code : ----
Hardware Rev : SAT 8232
Kernel Type : ID34
Firmware Type : ID34
Kernel Version : 0000
Drive is in normal mode.
Firmware flashing support : NO
Firmware dumping support : NO
Drive Capabilities:
CD-ROM : R BD-ROM : R
CD-R : R/W BD-R : R/W
CD-RW : R/W BD-R XL : R/W
DVD-ROM : R BD-RE : R/W
DVD-R : R/W BD-RE XL : R/W
DVD-R DL : R/W HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R/W LightScribe : NO
Drive Information:
Model Name : PIONEER BDE-PR1EP PP100
Firmware Rev : 1.00
Extra Info : 18/11/30
Serial Number : UADL032865WL
Label Code : ----
Hardware Rev : SAT 8801
Kernel Type : ID76
Firmware Type : ID76
Drive Capabilities:
CD-RW : R/W BD-R XL : -
DVD-ROM : R BD-RE : -
DVD-R : R/W BD-RE XL : -
DVD-RW : R HD DVD-R : -
DVD+RW : - LabelFlash : NO
DVD-RAM : - LightScribe : NO
DVRTool does not support the X12JBK. Below is the information output from MakeMKV.
Drive Information
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-X12
Revision: 1.02
Serial number: TGDL001983WL
Firmware date: 2020-01-22
Bus encryption flags: 1B
Highest AACS version: 76
LibreDrive Information
Status: Enabled
Drive platform: RS9000
Firmware name: PIONEER BDR-X12T
Firmware type: Original (unpatched)
Firmware version: 1.02/ID15
DVD all regions: Yes
BD raw data read: Yes
BD raw metadata read: Yes
Unrestricted read speed: Yes
Dołączone pliki
File Type: zip BDE-PR1EP2_FW202.zip (7.18 MB, 56 oglądane)
Ostatnio zmieniany przez MonetJack : 01.07.2026 o godz. 05:09
MonetJack jest offline   Odpowiedz cytując ten post
Stary 01.07.2026, 07:38   #2
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez MonetJack Podgląd Wiadomości
Firmware Rev : 3.10
Label Code : ----
Kernel Type : ID34
Drive Capabilities:
Drive Information:
Firmware Rev : 1.00
Label Code : ----
Kernel Type : ID76
Drive Capabilities:
Drive Information
OS device name: G:
Revision: 1.02
Status: Enabled
Check your PM.
bde-pr1ep, crossflash, pioneer, problems, x12jbk, xd05
Wszystkie czasy w strefie CET. Aktualna godzina: 10:01.
